whiplash pipe mount
Reply
Old 11-16-2002, 01:10 AM
jlong34016
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default whiplash pipe mount
anyone use that pipe mount from Bagostix? Did you surface mount it or go all the way thru the airframe?
jlong34016 is offline
Old 11-17-2002, 02:08 AM
BAGOSTIX
My Feedback: (178)
BAGOSTIX's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default bracket
Mr. Long its best when installed through the top skin and the base epoxied to the bottom inside of the fuse..
BAGOSTIX is offline
Old 11-19-2002, 01:53 PM
Hammbone2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I took a different approch; I took a block of maple and glued it between the servos, Tapped it to the size required and screwed a custom machined mount in place.The mount it self is an old alum modeling knife handle, Threaded the shaft to fit the tapped hole and the other end drilled a hole to run a tie-rap around,,Metal to metal was ellimated by using a piece of silicon slipped over the tail pipe of the tuned pipe. I turns out to be a very stong mount
Hammbone2 is offline
