Glass the wing of a world models dago red or not?
Hi just bought a world models dago red and was wondering about glassing the wing because im going to use it as a pylon racer but if i do glass it i would have to take the center ultracote out and that would look crappy. because i cant glass it on top of the ultracote or can i?
thanks
reinaldo
thanks
reinaldo
My Feedback: (50)
Hmm..?
Well, I have never had the Dago but anything I fly other than a slow flyer , I glass the center section for strength!
I would remove the covering to get a better bond, but $5 bucks says others will recommend going right over it (and it probably works also.. )
I would use .75 oz. glass and Z-Poxy, or regular epoxy thinned by rubbing alcohol. (You probably already knew that but what the heck..)
Let us know how it works out either way! BTW>> What's goin' on the nose??
james
james
61fx
on the nose im putting a 61fx with tunned pipe. im going to give a couple of flights this weekend and then im going to glass the center on top of the covering. if i do that the fiberglass becomes clear right?
reinaldo
reinaldo
My Feedback: (50)
Yup..
The glass will be transparent to an extent. It does leave a dull finish over whatever color you are over.
Let us know how it works over the covering!
Good luck with the Maiden
james
james
