Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
New Megatech Mach Racer delta wing
Old 02-17-2006, 01:54 PM
Dealspeed
My Feedback: (17)
Dealspeed's Avatar
Default New Megatech Mach Racer delta wing
Any good?? I bought one, figured for 89 buks it was worth it.
Planning on running a OS 46AX with a tuned Pipe, what prop should I run?? LHS told a 9x6 APC. would a 9x8 be better ??
and what kind of speeds should I be looking at with this setup ??
Thanks for all your input [8D]
Old 02-17-2006, 10:24 PM
dancanfly3d
Default RE: New Megatech Mach Racer delta wing
Ive just got me one to,Instead of putting the twin vertical stabs on it i made 1 single vert stab with a rudder on it Im using a os 50 with 9x8 apc prop and stock muffler ..cant wait till i get my tuned pipe from tower hobbies next week oyeah i also tossed the landing gear back in the box there a drag want to see a picture look in the photo gallery under delta wings
Old 03-04-2006, 09:43 AM
Flyboy Dave
My Feedback: (21)
Flyboy Dave's Avatar
I just got mine yesterday....It looks fast. I have a OS .45 FSR in mine, it's the
only engine I had that would fit.
FBD.
ID:	419885   Click image for larger version
ID:	419886   Click image for larger version
Old 03-04-2006, 12:40 PM
Kmot
My Feedback: (24)
Kmot's Avatar
FBD, I like that! You iron your t-shirts and your airplanes at the same time!
Old 03-04-2006, 02:17 PM
Flyboy Dave
My Feedback: (21)
....Kmot....it saves time that way....[sm=thumbup.gif]
My wife said either her, or the airplanes has to go !!!
Look at my hobby room. Man, I hate doing laundry. [sm=bananahead.gif]
FBD.
ID:	419997   Click image for larger version
Old 03-04-2006, 08:38 PM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
ORIGINAL: Flyboy Dave
FBD.
And your reply was "don't let the door hit you on your way out" ???
my wife left a few years ago.... and this is how my livingroom looks now!
ID:	420269   Click image for larger version
ID:	420270   Click image for larger version
Old 03-04-2006, 10:16 PM
cobratraxxas69
My Feedback: (31)
cobratraxxas69's Avatar
Man, you sure are Crazy for Flight!!! I'd sure wouldn't mind having that collection of jets and delta-wings.
Old 03-04-2006, 11:01 PM
Kmot
My Feedback: (24)
Kmot's Avatar
C4F: Nice collection!
FBD: how typical! The trash can is empty, but the rest of the place is trashed!
Old 03-04-2006, 11:10 PM
Flyboy Dave
My Feedback: (21)
ORIGINAL: Kmot
Yeah, but....I know where everything is !!!! (after I find it )
FBD.
Old 03-05-2006, 05:31 AM
Strykaas
Hey Flyboy, what is this strange "hollow" muffler ? Never seen that kind before [sm=confused.gif]
Old 03-05-2006, 11:43 AM
Kmot
My Feedback: (24)
Kmot's Avatar
That's a vintage Semco venturi muffler, I beleive.
Old 03-05-2006, 12:40 PM
cobratraxxas69
My Feedback: (31)
I noticed that the flying weight of the Mach Racer is 3.56 lbs. Take the gear off and you would lose a bit of that. At that point, it's weight should compare favorably to the Diamond Dust. (My clipped wing Dust weighs 3.68 lbs). Plus it appears to be as sleek as the DD.
With the landing gear removed, what will the speed of the Mach Racer be versus the Diamond Dust (given the same engine in each, for instance the OS .46 AX mentioned earlier)....
In other words, what would you guess would be the MPH of each plane with the OS .46 AX?
Old 03-05-2006, 01:49 PM
Strykaas
ORIGINAL: Kmot
At least, it seems to reduce muffler overall drag. How does it work btw ?
Old 03-05-2006, 10:32 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Well, for 'muffling sound', not very well.
It has a dual lining. The inner shape is a venturi, which when the aircraft is moving creates a low pressure, The outer lining, or body, is where the exhaust gases go. In theory anyway, the low pressure of the inner venturi would create a scavenging effect on the exaust gases, giving a boost in flow.
Old 03-06-2006, 07:54 AM
Flyboy Dave
My Feedback: (21)
Kmot has the right idea....the inner tube runs straight through, the exhaust
goes into the outer portion and out the back. They are louder than a stock
muffler, and do give better power, no doubt about that. The are cool looking.
I have about 5 of them, The one on this 45 FSR is cast. The others seem to
be spun and welded, the massaged and polished. I've heard then called Demco.
Tatone. and Macs....I got them all second hand....I don't really know where
they come from. This one is on a 60 Rossi, and a couple on OS 60 FSR's.
FBD.
ID:	421199   Click image for larger version
ID:	421200   Click image for larger version
ID:	421201   Click image for larger version
Old 03-06-2006, 11:18 AM
Kmot
My Feedback: (24)
Kmot's Avatar
FBD: If you ever want to part with them, I will give them a happy home.
Old 03-06-2006, 11:36 AM
Flyboy Dave
My Feedback: (21)
You bench is too well organized, it should look more like this....
Old 03-06-2006, 11:44 AM
Kmot
My Feedback: (24)
Kmot's Avatar
Oh I see. You mean it should look like this?
Old 03-06-2006, 12:52 PM
cobratraxxas69
My Feedback: (31)
What about the speeds of both with the Jett .50?
Old 03-06-2006, 01:34 PM
Mike Connor
Mike Connor's Avatar
ORIGINAL: cobratraxxas69
Your clipped wing Dust weighed over 3.5 lbs? My regular Dust with a Jett 50 only weighed 2 lbs 12 ozs. (no fuel). I am wondering the thickness of the Mach Racer wing. The Dust is about 5%. It also appears the mach Racer has more frontal area behind the engine. My guess is that the Dust will be faster. My first Dust started with a 46 FX and UT muffler. Speeds probably in the 125/130 range turning a 9x7 at 16,500 rpm. 150+ speeds with the Jett 50.
Old 03-06-2006, 10:06 PM
Flyboy Dave
My Feedback: (21)
I eyeballed the Mach racer at 1" thick....not bad, I think it will scoot.
I ran up the OS 45 for the first time, and it's a good one.
FBD.
ID:	421657   Click image for larger version
Old 03-06-2006, 11:59 PM
cobratraxxas69
My Feedback: (31)
I think my Dust is big-boned
Old 03-07-2006, 03:30 PM
Strykaas
Lucky guy !! Is it tight ??
Old 03-07-2006, 03:57 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Whoa- Cool looking bird--- I been gone too long! $89 bucks?
Dave with the FSR, imagine with an APC!
Old 03-07-2006, 08:53 PM
Flyboy Dave
My Feedback: (21)
Strykaas....it's a ringed engine, so it's not tight. However, it is crisp
and has excellant compression....no bearing noise. I put a new plug
in it, and primed the carb....it fired right up.
Razor....where ya' been ? I still have the bag of APC's for you.
FBD.
