How heavy is your "Whiplash"
Very good friend of mine who flys them all, Imac, Scale, DF, Turbine etc flew his Whiplash today. He is running a YS .45 with a pipe. Frankly I thought it was a bust. it does not even compare to a Diamond Dust. It does not just take off out of your hands. Now once it got in the air it was impressive but launching it was not good.
* later on this afternoon, I was talking to the guy who built it and told him what happened. I asked him if he knew how much it weighed and he said 5lbs. 5lbs? I remember when the plane came in and I picked it up with nothing on it and it felt very heavy. With hit being as it is, is a hot .45 engine the right size for this flying boatanchor.
Delta weights
For the Dust,Outlaws and Wiz that I've flow anything over #3
has been sluggish on take off/landing and really jerking it around.
Most have been in the 2.25-2.7# range and let you do anything.
All above are in the 450-600sq.in. range.
5+# wow, It has to be good on the down line!
Yeh that down line was solid and the YS .45 is on the table with thebest of them but getting that thing in the air was rough. If i were to guess, it was pulling around 135ish. Like i said, before he even started installing the stuff, it was heavy.
* Actually I am glad i saw this because IMHO the DD is the way to go.
Diamond Dust weight
My second Dust weighed 2 lbs. 12 oz. ready to fly (except fuel) with a Jett 50. My first dust was a couple of ounces heavier.
There is a Whiplash at the field with a 46FX but I have not seen it in the air yet. I was told it did not compare to my Dust. I am sure the engine is part of that.
There are some positive things about the Whiplash but here are my biggest complaints. At over 4 lbs. the Whiplash is too heavy. Too much of the servos are exposed to the air flow. The vertical fins do not come with a sharp edge on them.
I have a launch video of both of my Dust on my web site. That is the way this type of plane should launch.
Re: Diamond Dust weight
[QUOTE]Originally posted by Mike Connor
[B]My second Dust weighed 2 lbs. 12 oz. ready to fly (except fuel) with a Jett 50. My first dust was a couple of ounces heavier.
Mike-As i recall, you have a Shrike also. I have the .40 Shrike runninnga TT46pro and Ultrathrust and i need you thoughts here. I do not have a whole lot of time on it. Around 15flights-all good.
*Thing is it handles like crap and can't seem to get it smooth.
1. Here is the symptom. Lets say I am up their and make a nice smooth left turn. Going into the turn is okay but coming out is a nightmare. I reallly have to pull the stick over and when i do it over corrects.
2.I have minimun throws on ailerons. even with this it rolls fast.
3. I thought i may have to much expo. i checked and had 30% and decided to take it down to 10%neg and increase my aileron travel a bit. Went back up and the same thing.
4. its like went i come out of a simple turn, it wants to keep turning to a point of inverted and need to overcorrect to get it back. Its not smooth at all... Any ideas.
Re: Re: Diamond Dust weight
My Feedback: (178)
LA
whiplash weight
I can tell you Mr. Cyclic Hardover that its the best flying and best performing flying boatanchor you'll ever fly..
Everyone has their own opinion, and its true that the whiplash is heavier than the Diamond Dust, but at least it doesnt rip to shreds or come apart after hitting a blade of grass...
They are both good airplanes, each has its own good points and bad.
Whatever your choice, have fun..
Re: whiplash weight
Just saw a clipped wing dust (new version not yet released) with a 30" span and even more rake. It has a Jett 50 and is nasty fast. 200mph +
Tom
I'm not the real expert here, I just got a peek while at Jeff Gilbert's place, (Jeff is the designer and mfg of the Diamond Dust). Basically the clipped wing dust is a diamond dust that has the wing tips pushed in to a total span of 30". this increases the rake of the wing. It uses the same carbon fiber leading edge and spars so only weighs just a touch less than the regular diamond dust. The wing area is less than 500sq in but I don't know what it is exactly. But with a very deep sweep to the delta and at less than 3#'s with a Jett 50, it is nasty fast. The Kit will sell for $65, (same as the diamond dust) and it is going to be sold as an ARF and ARC as well I think, I'm pretty sure in the prop drive delta wings it's going to be the speed demon to beat. They don't have it dialed in yet and it's beating 200mph. I'd email Jeff Gilbert at diamond dust rc to get the scoop. Maybe He'll post something here but he's a little shy about it as he is not a RCU sponsor and isn't sure how far he can go talking about his products here.
I'll see if I can get a picture this weekend.
Later
Tom
Later
Tom
smaller is better
TOMR
i built a clipped wing dust about 6 years ago. we were racing in orlando fl, at the tangerine and don miller was there with his d/d and flying it at the lunch break. we were talking about making it faster and he suggested clipping the wing like your friend.
the speed was limited to prop and rpm, no radar info as to how fast it was. webra speed 40, mac pipe, and apc 9.5x7.5 pylon. i will tell you that i did not like to turn. i might have gone to far as to how much i took off. it was only 2" or so at the tip. i did not change the span only the rake back to the tips.
i should have shortend the wing also but i didnt own it long enough to see if it would have mad a difference.
2003 Taper T.E. Dust
My latest Dust.
Swept more, clipped to 32"
and a 1" sweep in the tailing edge.
Just for looks. This is the 4th one
built like this but my fav.
It's a design form '95 as well
hmmmmmmmm
could be, i dont remember don having a 40. he likes the smaller less weight motors for the straight down pull out at 5 feet wide open blow your mind pucker factor 50g's i cant beleve it did that kind of plane.
see you in apopka. RR
My Feedback: (12)
How times change..
My Dust had a OS46VRDF, and all I hear is how slow it was LOL!
I have long since resigned myself to the fact that no matter what engine I put on a plane, regardless of what prop I can spin or how many RPM's I turn, I'll never go as fast as anybody else, no matter what they turn.
"I have long since resigned myself to the fact that no matter what engine I put on a plane, regardless of what prop I can spin or how many RPM's I turn, I'll never go as fast as anybody else, no matter what they turn." Nice looking dust, btw Hans
IL
Whiplash weight
I just finished my Whiplash(older version) w/Jett FIRE .50. It came out to 4lbs 5oz. How should this one launch? Should it pull right out of my hand at full throttle?
Craig
Craig
