If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 71
Thread: Hot engines
  1. #26
    Join Date
    Nov 2005
    Broichweiden, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    @ rmenke
    Tuned pipe header: The Alley Cat fuse offers so much space that it’ll be easy to mount the OS .91 VR-DF inverted and using a straight header (0 degrees) in combination with an inside placed tuned pipe. I recommend buying the rear exhaust header # 3890 by MACS products. It is a bolt on zero degrees header.
    However- it turned out that the pair of stock M 3.5 header mounting screws delivered with the OS .91 are prone to shear-off. This can be avoided easily by using two M4 screws instead, having a steel grade of at least 10.9. There won’t occur any problems while cutting the β€œnew” M4 thread into the aluminum of the OS .91 exhaust flange.
    Those high strength M4 screws will survive all stresses during an entire engine lifespan.
    Exhaust gasket: Please don’t use an exhaust flange gasket since heat transfer from the cylinder case to the exhaust header will be obstructed. Metal to metal contact is desired here.
    Changing head screws: Again talking about changing screws. You’ll do your OS .91 a favour by exchanging the 6 stock M3.5 head screws by grade 10.9 M 3.5 screws. The original screws elongate by-and-by due to heat leading to a slightly loosened cylinder head.
    Other than the above described screw problems the OS .91 VR-DF does not need any changes, presumed you don’t want to have it modded to run 24000 or more rpm in flight.
    Fuel tank size and position: The Alley Cat tank bay, although reduced in size by the tuned pipe tunnel, will provide enough space for a 300 to 400 ml (10 to 13.5 oz) tank. If using the recommended bubbless tank you can position the tank nearer to the CG!
    If you want to place the tank nearby or into the CG you can install the Perry VP-30 pump. It provides a strong enough pumpage, even for the OS .91.
    Tuned pipe: If your pipe features same internal volume like the MACS # 1190 and a similar geometry, then you can use it for the OS .91. If your pipe is designed for a smaller engine size your OS .91 will run too hot potentially damaging your piston (up to aluminum melting –> piston hole).
    If your club does have noise restrictions I would like to recommend the JetModelProducts JMP System 2 tuned pipe. This is a high volume tuned pipe with a fixed length resulting in a peak rpm of about 22000 rpm. Unfortunately it is no light pipe and the cost of the complete set consisting of tuned pipe, machined header, retaining clip, pipe hook and heat seal is US$ 170.
  2. #27
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    ORIGINAL: Cyclic Hardover
    MIke-Curious here, Always wanted to build a DD, would that OPS.60 I have be to much in weight? Verses a jett .50 or similar
    Hello Cyclic Hardover,
    Before installing a hot .60 I would consider to reinforce the DD airframe. What about a fully balsa sheeted DD? - Still light, but very torsion proof.
    That would not take much time and would ensure safe operation and no more covering hazzle.
    Because your OPS .60 FIRE has the high torque liner, I also recommend rising the exhaust timing and using a non-muffled tuned pipe like the MACS #1160. A 9*8 or 9*9 prop would be ideal then.
  3. #28
    HaveBlue's Avatar
    Join Date
    Jan 2005
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    ORIGINAL: slowmo777
    well I must admit, as those in the know have acknowledged, this is good information... but lets say I did want to turn an os 91VR-DF up around 24,000 rpm, what am I looking at doing to the engine to achieve this?.......
    roughly calculations tell me 24,000 rpm should be in the vinicity of around 220 mph given a super clean frame with correct wing..and calculated on the 9 X 10 prop...
    and while I'm at it..I'll go for broke..Ive seen one topic on making carbon fiber props.
    http://134.169.96.2/~modellflug/klau.../prop/prop.htm
    is this the same procedure you use or are there other ways ..looks pretty straight forward.. though the hub thickness is something I'd like to look at more closely
    thanks
    HB
    if your still in control....you aint goin fast enough
    **Revver Bro 95**
  4. #29
    Cyclic Hardover's Avatar
    Join Date
    May 2002
    New Mexico,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Flight report and a video? I can see this coming. At least the video may help me find the remains! Probably look like a Quail shot down by a 12 guage.
    ORIGINAL: Mike Connor
    If you build one with a OPS 60 I would sure like a flight report and video
    Retired Army Aviator - Where the heck have I been?
  5. #30
    Mike Connor's Avatar
    Join Date
    Jan 2002
    Tulsa, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    I does seem that most DD's do not survive for long. I somehow got well over 100 flights on my first one before it could not be repaired.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  6. #31
    Join Date
    Mar 2002
    Hilton Head Isl, SC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    The prop diameter was actually 10.5 inches... my error. However, the speed was correct.
  7. #32
    Join Date
    May 2002
    New Mexico,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Very good idea. I'm sure there will be enough power to overcome a little extra weight.
    ORIGINAL: slowmo777
  8. #33
    proptop's Avatar
    Join Date
    Oct 2002
    Rome, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Bump...
    I found this thread, while looking for nothing in particular....some interesting (flashback ) reading...
    < Wrongway Feldman's Kreider-Reisner KR-21...(on Gilligan's Island)
  9. #34
    combatpigg's Avatar
    Join Date
    Nov 2003
    arlington, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Guys like SloMo wasted their words on Americans who are afraid/too lazy to do any "hot rod" work on their engines..plus doing any prop work to marry the engine to the plane.
    The few REAL hotrodders that are still around on this continent are still building hotrod cars. Maybe in Germany automotive hotrodding is too restrictive and that is why they have so many "speed freak hotrodders" in RC..?
    That's not an Indian movie man, that's a test pattern....
  10. #35
    Join Date
    Dec 2011
    Holland Patent, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    All,
    I am seeking parts for the OS 91 VR-DF to help a beginner in glow DF modeling.
    Specifically, we need: Hi-grade M3.5 head bolts, Plug for the stock needle valve assembly ( a remote needle will be used), Machined throttle are to replace the stock one which breaks from vibration (JMP used to sell these but no longer in stock.)
    Kindly replyor send me a PM. Thanx.
    Art ARRO
  11. #36
    Rudeboy's Avatar
    Join Date
    Dec 2002
    Kortessem, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    A vast selection of fasteners can be obtained from "Modelfixings" in the UK...I don't quite know where you can get decent quality metric stuff in the US. I do believe either Dubro or Sullivan carry some M3.5 hex bolts (and they are good, because I once used them to keep a muffler from rattling loose on an ST S90K engine).
    The throttle arm should be no big deal...if all else fails, make one yourself from a suitable wheel collar, a small piece of sheet steel and some silver solder.
    Take a look at the heli stuff, these guys drool over anodized alu bits...perhaps you can find a throttle arm there that fits the engine.
    As for a plug for the needle valve...I'm pretty sure OS has something exactly for that purpose...maybe for another engine, but I'm 99.5% sure I once saw something like that as a spare somewhere.
    Revver Brother #33
    ...I think it needs more power...
  12. #37
    combatpigg's Avatar
    Join Date
    Nov 2003
    arlington, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    To plug off needle valve holes I've threaded the case and used nylon hardware to act as filler plugs. You can even try a mismatched thread [10-32 thread with a 10-32 nylon screw] to make it a permanent "one shot" deal.
  13. #38
    MJD's Avatar
    Join Date
    May 2003
    Orangeville, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    ORIGINAL: Rudeboy
    A vast selection of fasteners can be obtained from ''Modelfixings'' in the UK...I don't quite know where you can get decent quality metric stuff in the US. I do believe either Dubro or Sullivan carry some M3.5 hex bolts (and they are good, because I once used them to keep a muffler from rattling loose on an ST S90K engine).
    Dubro does: http://shop.dubro.com/c/car-trucks_f...g=3&pp=12&pg=3
    I have made replacement throttle arms for a few engines from plastic servo arms.. dunno if that is a viable option here though.
    Can you plug the needle valve opening by Dremeling off the needle from the needle valve and screwing what's left into place?
    Marine GOOP = magic faerie boogers in a tube, sticks everything.
    Revver Bro #231
  14. #39
    Rudeboy's Avatar
    Join Date
    Dec 2002
    Kortessem, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    ORIGINAL: MJD
    I just realised Webra, and now West engines have alu throttle arms that could fit with no or litttle modification...
    And servo arms are good for a lot of stuff... i once made a throttle arm for the slide carb on my OPS 60 SP VAE Speed engine from an old JR servo arm...works like a charm, no slop what so ever.
    Revver Brother #33
  15. #40
    Join Date
    Dec 2011
    Holland Patent, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Guys, thanks for all the replacement part options for the OS 91 VR-DF.
    I know DuBro and others offer M3.5 bolts but don't know their grade or hardness. The stock OS ones stretch with running and this causes problems- like a loose head and a lean run.
    Will try re-threading theneedle assembly in the carb and plugging the hole-good tip.
    Also, somejet guys used to double up on the throttle arms and braze/silver solder themtogether but eventually these broke also. The machined arms from JMP really solved this problem.
    Be aware the DF usage is hard on these partsdue tothe accumulated runtimefor this application. Typically we burn 22-28 oz per flight withmany flights logged. These are the known weak points of the OS 91 VR-DF, otherwise a fine engine,except for the ABN liner material.
    Art ARRO
  16. #41
    Rudeboy's Avatar
    Join Date
    Dec 2002
    Kortessem, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Well, Modelfixings has them bolts in 12.9 grade...they're reasonably priced too, order a bag of them, that way you're set for life, lol ;-)
    Revver Brother #33
  17. #42
    Join Date
    Dec 2001
    Sacramento,, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Sorry to intrude. I normally don't come by here often, but I used to fly planes and thought I'd give a little friendly input. If you're lookin for OS 91, OS 65, OPS 67, OPS 80 parts a good place to look might be US boat racers and where they hang out. Like International Waters for sale forum. Many used to run OPS 67/80's (me included). and have bunches of parts accumulated that are now obsolete. There used to be a titanium rod made in Canada for the OPS67/80. Nelson used to make aftermarket P/S and rods for the OS 65 and 90. Maybe you can try and find some of these wonderful old parts for your endevour. Of course I see whole engines go on e-bay for very modest prices, sometimes for less than a P/S rod combination new. I got a ton of old style OS 65 parts, disc rotor style before the drum rotor, 7F carb neck style carb. These won't interchange with the drum rotor model, they changed just about every thing, though they look near identical. The boaters that used OS 46/65 and 90's used to cut the ports quite often and had virtually no trouble with the plating. 60% Nitro is the norm in US nitro boat racing. Rudy
    Rudy
  18. #43
    Join Date
    Dec 2001
    Sacramento,, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Also please be reminded that Novarossi makes a speed 60 FIRE for those wanting a more plug and play experience and don't mind being spendy. Check thier website. They've been know to have great mettalurgy and fit and finish. I've had trouble keeping up with all thier 21 models and variants, which has been the problem (for me at least) in getting parts, but usually the parts are available, I just can't seem to figure out which ones will fit.
    Rudy
  19. #44
    f3d's Avatar
    Join Date
    Dec 2002
    Konz, Germany, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Hallo speedfreaks,
    here some pictures from my aktuell OS 60 speed engine.
    A very powerfull engine with Nelson AAC piston an cylinder and different intake systems. Always more than 14 mm intake for good breathing. Mostly parts are selfmade.
    Have fun
    Best regards Michael
ID:	1844153   Click image for larger version.
ID:	1844154   Click image for larger version.
ID:	1844155   Click image for larger version.
ID:	1844156   Click image for larger version.
ID:	1844158   Click image for larger version.
ID:	1844159   Click image for larger version.
  20. #45
    combatpigg's Avatar
    Join Date
    Nov 2003
    arlington, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Michael, very nice..!
    Can you tell me how much exhaust timing this engine uses..?
    Do you use a inflight fuel mixture valve between the engine and the fuel tank..?
    14 mm intake looks very impressive........[8D]
  21. #46
    f3d's Avatar
    Join Date
    Dec 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Hallo,
    the engines have 192 degree exhaust timing.
    Also inflight mixture control from BVM.
    30 % nitro, 20 % oil
    25000 rpm on the ground.
  22. #47
    combatpigg's Avatar
    Join Date
    Nov 2003
    arlington, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Thanks Michael..!
    Do you think 192 degrees is a fairly "universal" number for speed .60 engines that turn the size of prop that you like to use..?
    I ask this because I know a guy with a Picco .60 pattern engine who would like to modify it to the same level of performance as the Speed or Fan engines. The pattern engines are easy to find.
    The hope is that with a little bit of work a low timed .60 FIRE could be modified to turn a 8.75x9 prop fast enough to make the small investment in time and money worth trying. I advised him to try 180 degrees to begin with and to use a 8x9 while testing it on the ground.
  23. #48
    f3d's Avatar
    Join Date
    Dec 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    I agree with you to start 180 degree , not more.
    The biggest handicap is the small bore in the crakshaft. Mostly 12mm or less. This is to small for a good performing engine.
    My front intake OS on the picture has a 17 mm gas passage !!
  24. #49
    MJD's Avatar
    Join Date
    May 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Those pipes are a much "peakier" design than the standard MAC pipes I think!
    OMG look at the size of the intake on the rear rotary version.. That's what it takes to flow 4l of air per second..
    Revver Bro #231
  25. #50
    vicman's Avatar
    Join Date
    Dec 2002
    Valdese, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hot engines
    Those are pretty sick looking set-ups![8D]
    A guy who used to live on this site and now is rarely here due to the "upgrade".
    Most likely fading away till the My Forums is fixed. Too bad.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
