whiplash pushrods
Old 12-06-2002, 03:24 PM
jetsett
Default whiplash pushrods
I would like to know what kind of pushrods your using for your whiplash. I was thinking of getting the CF pushrods from Art's hobby with the titanium ends. Are they thin enough to get around the fins.
Old 12-06-2002, 06:08 PM
George
My Feedback: (57)
Default Pushrods
I used 4-40 with ball-link at the servo horn, Sullivan S.S. end soldered on, Sull. horn and connector.
Pics attached.
Old 12-06-2002, 06:09 PM
George
My Feedback: (57)
Default Pic
Another
Old 12-06-2002, 06:20 PM
ChuckAuger
My Feedback: (12)
Default Hey George..
I grabbed a couple of those Sullivan steel control horns while at the (not so) local hobby shop...and they are both the same..do they make a right and left, or do you just move one over a bit??
Old 12-06-2002, 06:32 PM
George
My Feedback: (57)
Default Yes & No
Hey Chuck, In the 3/4" they only make the one. The big ones; (1 1/8" I think) they make left and right, but they are too big for our Lashes IMHO. I just positioned the one a little over like you said; works great!
George
Old 12-06-2002, 08:07 PM
Dustflyer
My Feedback: (13)
Dustflyer's Avatar
Default Control rods
You don't have to spend that much money.
My local hobby shop had some carbon fiber rods for around two bucks. Dubro 4-40 threaded couplers JB welded into the ends work perfectly.
I used Air Wild 1" servo arms with Dubro ball links. This drops the control rods low enough so they clear the fins easily. Just to make sure I moved the servos out about 1/8".
Old 12-07-2002, 12:12 AM
RCLIVIN
My Feedback: (46)
If you order the sullivan horns you can order a pull pull set, you will then have a left & right. They are stainless & impossible to drill, I used a metal hole punch & opened the hole to 4-40, I then used a swivel ball link on both ends of the 4-40 pushrods.
Gil
Old 12-08-2002, 09:55 PM
BAGOSTIX
My Feedback: (178)
BAGOSTIX's Avatar
Default pushrods
We have custom C/F push rods sets on the website that are specifically for the whiplash, look under whiplash accessories..
www.aerojetmodels.com
