Weston Magnum build help
Reply
Old 03-24-2006, 05:11 PM
leetony
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Weston Magnum build help
Hi, just got a unassembled Magnum combo kit. In the instruction, it mention about the throttle strengthening plate, D25. I didn't find it in the kit, is it necessary? What is it?
Tony
leetony is offline
Old 03-27-2006, 06:05 PM
mpriestley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Weston Magnum build help
Hi there,
Congrats on one of the fastest planes out there. so fun...
I no longer have my Magnum but I did not remember any re-enforcement for the throttle but I would suggest that you just make sure that the servo will not break away and that the assembly is solid.
I have a question, do you know if you have the new Magnum R? is there a checkered bottom?
I am trying to get a new one.
thank you for you help and have fun with that thing.
hint: no more than 3/4 throttle on take off ( hand launch ) keep you from torque rolling.
mike,
mpriestley is offline
Old 03-27-2006, 10:00 PM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it will be some time before WestonUSA gets the R version, I waited over a year and GAVE UP!
I guess they have a ton of them.
If you REALLLY want one and willing to spend big bux
buy one from Weston UK and have it shipped from England.
http://www.westonuk.co.uk/
Crazy4Flight is offline
Old 03-27-2006, 11:19 PM
leetony
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't think I have the R versoin. Are the included CA hinges strong enough? Should I seal the control surfaces?
Tony
leetony is offline
Old 03-27-2006, 11:54 PM
rconabudget
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tony,
The CA hinges are plenty strong enough. Make sure that you use THIN cA and at least 6 drops per side of each hinge.. I drill a small hole (1mm or less) in the middle of the hinge slot (from trailing edge of wing forward and from leading edge of control surface back) to help with the wicking. Make sure that you have the gaps as small as possible and it should not be necessary to seal the gaps.
Regards
Kerry
rconabudget is offline
Old 03-28-2006, 09:36 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My R version had no part D25 and didn't mention any throttle strengthening plate either. If you got yours from WestonUSA it is most probably the first versiosn. One thing I did notice is those diagonal webs are incredibly weak and IMHO do just about squat to strengthen that area of the fuselage in terms of compression. I added two 1/2" wide strips of 1/16" aircraft ply on either side of the throttle servo mount and spanning the width of the fuselage. Whether I needed to or not is up to the jury but it didn't hurt.
Don't feel guilty for thinking the control horns are crap and wanting to replace them, either.
MJD
MJD is offline
