P51 .40 with .91FX
QC, CANADA
P51 .40 with .91FX
It almost done. My Great Planes P51. It's a .40 size. I build it strong and right.
I want to install my OS.91 FX 2 stroke on it for speed.
For extreme speed on this kind of engine, what is your prop suggestion. The plane weight 8.2 pounds (with the engine, gear, retract, pump....)
RE: P51 .40 with .91FX
Sorry,
but don't you think that it will be overpowered?
This engine (I have my new OS 91FX ready for installation on my Corsair 60size),
will bring the wing loading too high.
With all the negatives from that.
That's my oppinion ofcourse.
If i was supposed to decide for an engine in a 40size plane (that i want to squeeze alllll speed from it ),
personally,
i would go with an OS 50SX ( APC 10x6 ) or an OS 61FX ( APC 10x6 again ).
And you can use your engine on a nigger project.
Enjoy,
Kostas.
Greece
personally,
Enjoy,
Kostas.
Greece
ORIGINAL: SitNFly
I use a 13x8 on mine. I imagine for speedburning you'd try a 12x9, or 11x10 if they are available.
Sorry,
Enjoy,
Kostas.
Greece
Enjoy,
Kostas.
Greece
Overpowering is the whole idea! Why would you use a 10-6 prop for speed? That's a general purpose prop. If you want fo go faster on a .45-.50 size sport engine, then 9-7, 9-8 would be places to start, or 8-8/8-9 on a small clean aircraft (which a P-51 is not). RPM + pitch = speed.
MJD
Yes,i meant bigger,duhhh.
Yes,if you want speed you must go down on dia and play with pitch,but i think there is no reason to try this with a 91FX!!!!
Way tooooooo BIG i think.
I mentioned in my previous post for wing loading,what do you say?
My Feedback: (54)
ORIGINAL: Kostas1
It'll be just fine. I ran a WM 40 size with a G90 for 2 years and it was a nice plane. Wing loading? Maybe a little but the wing loading is high
on these things anyways. Shoot my Saito 100 flys great in my other WM 40.
The green one here was about 7 years ago. Its the WM 40 with a G90. Lasted two years and succumed to battery failure and flew off into the South 40. The other is my current WM 40 Miss America with a Saito 100. They really do fly well
You want to see what "overpowered" flys reliable? Click on "My Models". I have had most of those planes for a few years and fly just fine
That's my oppinion,
that's your oppinion,anyway.
I mentioned what i am thinking.
Personally i wouldn't waste my 91FX for a 40 size model P-40.
If i wanted speed -S-P-E-E-D- i would buy a pylon racer or a deltawing.
Enjoy.
Kostas
Enjoy.
Kostas
I don't want to make myself sound "anti OS" here . I have owned or have most engines they make and happy with them all except that 91. I have no confidence in it at all. So with that, my general sport engine is several G90's with no complaints
MS
I think the 91 will turn the 40 size into a great sport flyer. I currently run a 61FX on a somethin extra and love it. The 91 is about the same weight as the 61 but with a little more power. The somthin extra can easily handle the 61 and could handle a 91 if I had one to install. If you don't need the power with the 91 use the throttle.
I'm not gonna give you more facts that you will have problems using the OS 91FX in a 40 size model.
YOU WILL HAVE PROBLEMS
And if you'll try it i don't want to see it.
Anyway.
It is sth like trying to fit a Ferrari's engine into a VW Polo.
Just like that.
Anyway.
Just like that.
I don't know about all the OS 91 bashing....
I own 6 of them and two have been inverted in WM 51's....Yeah I had problems....not enough fuel in the fuel tanks!
Take everything with a grain of salt. OS makes good reliable engines. I think everyone knows that they are certainly NOT the fastest engines out there!
Thats funny on the fuel tank. I have like a 16-18 oz tank stuffed in mine. I don't like to run out of fuel.
I never knocked the performance of the 91fx, just reliability. Like i said, I have darn near the whole OS line up and that engine is the only booger I ever had .
Hey, maybe if we install the ST carb???
ORIGINAL: Kostas1I'm not gonna give you more facts that you will have problems using the OS 91FX in a 40 size model.
Anyway.
Just like that.
Anyway.
Just like that.
Wing loading is what it is. If the aircraft comes out at an acceptable wing loading and the CG is where it should be, it doesn't matter if it has a .40, a .61, a .75. a .90, or a small block V8 in the nose (well maybe not the last one). Landing a properly balanced .40 size sport ship with a .90 in the nose is probably less difficult than landing a pylon racer.
Yes small deltas and pylon racers are inherently fast, but some people enjoy overpowering other aircraft designs - that's their choice.
MJD
Well, you have to hand it to Kostas, it's not the brightest move on paper but it works just fine. If you have never seen it done, it may sound rather stupid.
That .90 2 stroke or the Saito 100 or YS 110 is probably the limits here. With proper structural improvements, they hold up really well. TRY IT, YOU'LL LIKE IT
Yes,in this case yes,improvements are important are i think they are NECESSARY.
Also if you must add 10oz's on the tail to balance the model,this is just RIDICULOUS.
