Outlaw Power
Reply
Old 03-26-2006, 09:38 PM
BullardRM
My Feedback: (39)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Outlaw Power
I'm building Jerry Smith's Outlaw. His original used a Weber 32, but told me he had switched to OS for better reliability. Who is the US dealer for Weber? Would the OS be a better option? Anyone with experience to share would be appreciated. Thanks in advance.
BullardRM is offline
Old 03-27-2006, 08:12 AM
petec
My Feedback: (58)
petec's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Outlaw Power
I had a Webra .36GT on mine with no reliability issues. Horizon Hobby has them for $109 according to their website.
petec is offline
Old 03-29-2006, 08:59 PM
Rocketman612
My Feedback: (84)
Rocketman612's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: BullardRM
If your thinking about an OS 32 FX the remote needle valve on the backplate is a problem. The fix is to get the OS 32FX HELI carb and swap it out and your good to go. A friend ran this setup on several Outlaws with great results.
Pete
Rocketman612 is offline
Old 03-31-2006, 12:02 PM
rmenke
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bullard;
I'm not much of a OS fan, shades of the first GM diesel sort of thing. Have two Webra speed 35's. One is in a Krangke F3d and has been very reliable and does scoot with a Jett Engineering pipe on it. Goofed one day and ran it so lean, there was no compression left right after the flight! Next day I started to pull it off intended for the trash. Woa, the compression was back. Still running reliably and strong.
rmenke is offline
Old 04-02-2006, 02:42 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I suppose you are talking about a WEBRA .32... well, if you can get one new or nearly new, go for it: they are very good engines. And they work even better with the Dynamix slide carb: best throttle response you've ever seen. If I manage to find anohter Dykes ringed .32... I will not hesitate.
Rudeboy is offline
Old 04-03-2006, 02:36 PM
1bettenu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi guys...i wanna go fast too........where can i get plans for the outlaw. i have bee all over the web looking for it ...i find jerry this and jerry that and stiil no outla.. presently flying a dd. that i modified and dont loke the results....modified it with the os 91 ducted fan with pipe....way too much weight...lots of power but just toooooooooo heavy....
1bettenu is offline
Old 01-25-2007, 02:44 PM
modifyit15
My Feedback: (27)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys what do you think about a 46 AX, could I get it to balance on the CG with this motor. it weighs 17.2 oz with the muffler.
modifyit15 is offline
Old 01-25-2007, 02:46 PM
modifyit15
My Feedback: (27)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I want to Go Really fast
Old 01-25-2007, 03:02 PM
Rocketman612
My Feedback: (84)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: modifyit15
The OS 32 SX weighs 12.32 with muffler. So your up 5 oz there and balancing will be a problem. Unless you add a bigger tank the 4 oz Hayes tank isn't going to last long either.
The airfoil of the Outlaw is thicker than the Whiplash or Diamond Dust so there will be a limit to how fast it will go.
They are pretty hot already if you use the Webra 36. But it's only time and money, go for it and keep us posted
Pete
Old 01-25-2007, 11:05 PM
ChuckL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a TT36 on mine I wasn't real impressed with that combo so I put a JETT 35 on it and what a difference that engine brought the Outlaw to life.
ChuckL is offline
Old 01-26-2007, 01:06 AM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All of the engines listed are good ones and are great when used with a peformance exhaust. Just don't compare two engines, one with a stock muffler and the other with a tuned pipe, mousse can or jett/ultrathrust, isn't fair. And different brand engines of the same displacment may perform best with different props. Take the time to break-in, peak & tweak in a test stand than finally in the air. It can make the differnce between a dog and a screamer.
freakingfast is offline
Old 01-26-2007, 01:36 AM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Rudeboy
Webra made a ringed 35 a few years ago. Strong, takes a while to break-in. It's sort of long stroked and won't winde as high as a OS 32 FX so prop it accordingly. I found it can generate a lot of vibration so watch for foaming. I have two of these engines, one in an Outlaw and the other is homeless, it was in a now deceased Krange F3D. I really like these engines.
Old 01-26-2007, 07:31 AM
Rocketman612
My Feedback: (84)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: freakingfast
Well said.
Pete
Old 01-26-2007, 10:01 AM
Julian537
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go all out and put an JETT SJ 40 on one! IT will really haul the mail!! I have seen it first hand.
Julian537 is offline
Old 01-26-2007, 12:47 PM
Flyfalcons
Flyfalcons's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Webra .36 with a Mousse can pipe is the perfect enine for the Outlaw. You can get them at Horizon.
Flyfalcons is offline
Old 01-27-2007, 06:07 PM
evan-RCU
evan-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Rudeboy
I bought two of these out of Hong Kong years ago(maybe 5) and I put one in a Menace, great for a long stroker, and never got it to make compression. They took one back but I still have the one that I ran, almost new in a box, I'll probably never use it....
The .32 SX is a great motor, I have a half dozen of them...
evan-RCU is offline
Old 01-28-2007, 12:27 AM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have two OS 32SX 's. One has been though hell on my PBF and won't die. The other is N.I.B. wanting a plane. It may go in my LR-1 that's almost ready. The most powerful 30 sized weight class motor Iv'e ever come across is the Thunder Tiger Pro 39 Heli motor. The heads been turned down to get rid of the large square heat sink and a prop drive was made in place of the clutch. Loves to scream on 30% heli fuel. It was originally purchased for a diamond dust, but I think I'll try it and the can exhaust on the Outlaw.
ID:	608142   Click image for larger version
Old 01-28-2007, 12:20 PM
modifyit15
My Feedback: (27)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok I tested it today. Outlaw with a O.S. 46 AX stock muffler weighin @ 48 1/2 oz. total weight including the 2 1/2 oz. I added to the tail. She flies great. The fastest I flew it today was 3/4 throttle and she was out of sit quick. Brought it back in close trim ed it out and flew it at 1/2 throtle for the rest of the perfect first outlaw flight. I think I am going to really like this plane . if I didnt have to work right now I would be flying now
Old 01-28-2007, 02:33 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that .46 must look HUGE on this airframe. Any pix ? Glad it worked out ok
Strykaas is offline
Old 01-28-2007, 03:23 PM
modifyit15
My Feedback: (27)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ill post some tonight I'm at work now. it doesnt look to big it does fill the whole engine bay though
Old 01-28-2007, 06:51 PM
modifyit15
My Feedback: (27)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here are the photos
ID:	608711   Click image for larger version
ID:	608712   Click image for larger version
ID:	608713   Click image for larger version
Old 01-28-2007, 08:32 PM
Rocketman612
My Feedback: (84)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm servicing my Outlaw and cheking my 350mah NiCad battery to see if it's still good (80% of rated capacity). Was wanting a larger capacity battery what have you stuffed in yours?
Pete
Old 01-28-2007, 09:18 PM
modifyit15
My Feedback: (27)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your right "SUFFED"
I have a futaba 600MAH 4 cell Pack
Old 01-28-2007, 09:36 PM
Rocketman612
My Feedback: (84)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your right "SUFFED"
LOL,
Like Jerry said you really have to want to get it all in there. Thanks for the photo. After some "Reorganization" I got a "NoBS" 800mah NiCad in mine. Only 1 oz added weight over the 350mah pack. I'm telling the plane to exhale when I put the hatch back on
Pete
Old 01-29-2007, 03:16 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
modifyit15 ,
you've opened the door to a new generation of outlaws
Strykaas is offline
