Balsa USA Force One - Help needed
Reply
Old 05-28-2006, 01:37 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Balsa USA Force One - Help needed
Hi all
I am now working on my Force One , and something caught my eye.
On all the Force One I have seen here on RCU, the main landing gear is bent forward.
However, as per the plan sold with the kit, the mains are bent rearwards, which will in my opinion make the take off roll much longer.
What do you think ? Shall I bend a new set of mains ? Or maybe just swap them ?
Is the lg spar located at the same place on yours ? What is important is the wheel location, so please could you check on yours ? Maybe there has been several revisions of this kit with the wheels always at the same place, but different lg spars setup...
Here is a close up shot of the mains from my plan :
Strykaas is offline
Old 05-28-2006, 07:45 PM
rmenke
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Balsa USA Force One - Help needed
Bro Strakaas:
If its a tail dragger, kick forward for sure. If trike, kick backward and adjust nose wheel to level out. Should not make any difference in takeoff distance regardless. ENJOY Bro 119
rmenke is offline
Old 05-29-2006, 05:53 AM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's a trike, a tail dragger can't work because of that center prop ...
OK I will let it as per plan. thx
Strykaas is offline
Old 05-29-2006, 09:22 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Strykaas
What do you think ?
Seeing you have not been overwhelmed with responses.
Deltas take a high angle of attack to make lift, so to takeoff you really have to rotate the nose up. There's two things at work here:
1. You have to worry about a prop strike when you rotate for takeoff.
2. Deltas have very little leverage with their elverons, so you want the plane to have the wheels very close to the CG, but behind it.
From looking at the plans you provided, I would say you could take the stock LG and mount them on the opposite sides, which would move the wheels forward, and make it easier to rotate for take off, but you might want to use a 3 bladed pusher prop so you have a little more ground clearance.
soarrich is offline
Old 05-29-2006, 09:51 AM
AirGar
My Feedback: (7)
AirGar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't deviate from the plans. The mains also support the weight of the motor. Mine are facing "rearward" and the approx distance from the front hub to the rear hub is 14".
Good luck,
Gary
AirGar is offline
Old 05-30-2006, 02:49 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: soarrich
No problem, I will use some kind of wire or clear plastic sheet at the very rear end to avoid any.
ORIGINAL: soarrich
This is the opposite of what Airgar said ... Did you fly one ?
Strykaas is offline
Old 05-30-2006, 02:53 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: AirGar
Mhhhh... only for the LG
ORIGINAL: AirGar
Exactly. I've rechecked the pix of the "Panty bandit", and yep, facing rearwards. I'll go that route.
But : ...
Strykaas is offline
Old 05-30-2006, 03:08 PM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Strykaas
ORIGINAL: soarrich
No, but I have 2 DD, BTE Votex, and several homebrew deltas. It's only the opposite in that I say put the stock gear on backward, he said as the plans say, try both, it's a 10 minute change to swap them around. I think you'll fine it takes off better my way. If the eleverons have to overcome more weight, (stock configuration), you'll have to be going faster.
Check this out. http://www.rcuniverse.com/product_gu...cfm?kit_id=998
If you try it both ways let us know which you like.
soarrich is offline
Old 05-30-2006, 04:55 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Rich for posting.
I agree with you, and just as I stated in my first post, a quick swap is easy to do... But that won't be possible for me (mods), I have to decide now !
Actually you may be 100% right , and that's also why I've started this thread. I have checked a french mag Force One plan reportedly based on RCM plan. We can even see the RCM logo which has been left on the french plan. Guess what, on this plan, the mains are facing forward [X(]... So the question is, which plan is the latest version ? My plan (from the kit) has the mains bent rearwards, and a version sold by RCM features the mains bent forward.
I will shoot a picture of my french mag tomorrow for you to see. Hard to say which one is the latest design. My kit was bought one year ago only, so I would tend to say it is newer, bu who knows ?
Airgar, how much take off roll do you get with your setup ?
Strykaas is offline
Old 05-31-2006, 07:12 AM
AirGar
My Feedback: (7)
AirGar's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Strykaas
Haven't flown it for awhile, but it seems to me 'bout 150', or less.
AirGar is offline
Old 05-31-2006, 07:36 AM
burgh_guy61
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a friend with one, and the only thing i would like to add is to make sure the nose does sit with a positive attitude or it will not get off the ground. His took like said about 150' to lift, that is once he had the nose at the positive attitude.
burgh_guy61 is offline
Old 06-01-2006, 12:54 AM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My mains are rearward and it leaps into the air after a 60 foot roll. As mentioned above, do have slight nose up positive attitude about 2 degrees is all it takes, too much and it won't stay planted on landings. Note; make sure your canopy screw is secure, mine came out and the whole canopy went though the prop ( kinda sounded like a tree shredder).
Balsa and monocoat confetti in the sky, the rest of the plane landed fine engine on with some minor damage around the prop slot area.
freakingfast is offline
Old 06-04-2006, 10:44 AM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here it is guys. This accounts for a big difference ! What do you think ?
Till now, we've only heard people with mains facing rearwards [:-]. BTW where did you get yours from ? Balsa USA kit ? RCM plan ? or ... ? And when ?
Thx
Strykaas is offline
Old 06-04-2006, 12:29 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pictures of modded Force Ones I have found in my RC mag ... Would love to see the pulsejet version in action
ID:	471618   Click image for larger version
Strykaas is offline
Old 06-04-2006, 12:38 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One more, sleek nose [:-]
Strykaas is offline
Old 04-05-2007, 04:09 PM
LADDIE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The main landing gear is suppose to be bent forward as per original RCM plans.
Laddie.
LADDIE is offline
Old 04-05-2007, 04:28 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Laddie. I infer from what you've said that Balsa USA has modified the design ?
Strykaas is offline
