Patriot XL weight??
Reply
Old 06-04-2006, 11:31 PM
morlove3
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Patriot XL weight??
I have a Patriot XL that is just about done. My concern is the weight. Currently it's 8.5lbs without the engine! I am putting an OS 91 FX in it so that's another 30oz with the pipe. Currently the plane has 8 Hitec standard servos and two mini Hitec 85's for the steering and the throttle. It has spring air retracts, a volt meter and a lost aircraft alarm. The wings are fully sheeted and monocoated. I have put the 12oz tank over the CG and put a 4oz hopper tank in front. I don't know how I can make it any lighter and I'm wondering what type of speed I can expect. Does anyone out there have a Patriot XL and if so how much does it weigh, what type of engine are you using, and how fast does it go? Thanks for any input.
morlove3 is offline
Old 06-05-2006, 09:23 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Patriot XL weight??
Most of the Patriot XL aircraft I have worked with so far came in between 8.5 and 9.0 lbs flying weight.
Ive seen a couple pushing 9.5 lbs, and they flew fine with .91 power.
I also saw one last summer where the owner went out of his way to put it on a diet, made a bunch of modifications, and with spring-air gear and a Jett 90L it came in at exactly 8.25 lbs ready for fuel
bob27s is offline
Old 06-05-2006, 11:23 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Morlove- Where do you fly usually? I live in San Diego and am in Temecula once in awhile...
We are going to rabbit dry lake this weekend for a campout and goof around fly-in if you are free--
As for the Pat XL, it only sounds heavy at over 10 lbs. with the 91FX, a Jett-90 and I would be less concerned-
Razor-RCU is offline
