I need Whip fins -
Reply
Old 06-07-2006, 01:06 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default I need Whip fins -
I was fortunate to get a second hand Whip but the fins were damaged during shipping, do any of you folks have a set of fins since ACM is not producing this anymore?
I repaired the originals but do not have total faith in them at high speeds, and they are now ugly- [X(]
Razor-RCU is offline
Old 06-07-2006, 01:22 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: I need Whip fins -
If you have the originals, just make a set out of Balsa.??
daven is offline
Old 06-07-2006, 03:27 PM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know who is liable to have a set just lying around, since they were shipped one set per airframe, unless someone stepped on their wing before assembly..
For all the time it would take, I'd build up a new set, and unlike on the set I received I would put the grain span wise in the center section.. and, also unlike my set, I would try to eliminate the warps in the fins while you're at it. Then I'd glass the whole affair from tip to tip, i.e. outside left tip across the center section to the outside of the right tip in one piece. Repeat for inner side. Should be fine - rocket fins that fly at several hundred mph are not made any more robustly than that.
MJD
MJD is offline
Old 06-07-2006, 08:41 PM
rconabudget
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree that it would be easiest to make your own. The originals would be as scarce as hens teeth. They are no more than glass covered balsa.
rconabudget is offline
Old 06-07-2006, 08:55 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Put one down on a copier and fax it to me and I will make them for you bro. If we do this tomorrow AM I may even get them to you for this weekend's suara.
vicman is offline
