Balsa USA Enforcer Retracts?
Reply
Old 07-02-2006, 08:01 AM
webtech
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Balsa USA Enforcer Retracts?
Does anyone have a suggestion on what to use for retracts on this plane. I am having one built to be powered with a regular engine with a pusher prop for now. I was thinking of using mechanicals for this with 5/32 struts. Would this be sufficient enough?
-Webtech
webtech is offline
Old 07-02-2006, 10:40 AM
rmenke
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Balsa USA Enforcer Retracts?
webtech:
Robarts air or spring air would do the trick well. 5/32" is more than enough unless you are flying off a grass field, then may be a little small depending on your landing skills. ENJOY Bro 119
rmenke is offline
Old 07-04-2006, 10:22 PM
mobileraptor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
First of mechanicals are a pain, you will have to use at least two servos, One servo just isn't enough to run three retracts. Also if the is any bind you have a major drain on the battery. and last the is no fail gear down.
The spring airs are out standing, I get 7 cycles on a full tank and if you have a failure the wheels come down.
I understand that robart now has a new model with the spring down failure but I have seen or used them yet.
mobileraptor is offline
