Ducted Fan fuel??
Reply
Old 07-07-2006, 10:07 AM
kmtranmd
My Feedback: (71)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ducted Fan fuel??
I'm getting into the ducted fan scene and need help with fuel questions. I have a BVM aggressor with bvm motor. They recommend Wildcat jet A which I cannot get locally. I wonder if anyone has good experience using other brands and what oil addition (still castor?) that they add to get the magic 23% content for ducted fan motors. I can get access to Magnum, Sig fuels. Thanks.
kmtranmd is offline
Old 07-07-2006, 11:41 AM
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Ducted Fan fuel??
I have used normal 15% nitro with 1 oz per gallon of turbine oil added. This was recommended by Larry Wolfe of Jet Hangar Hobbies. The logic being that turbine oil do not evaporate at the glow engine temperatures.
I know other people have used 30% nitro helicopter, which is close to 23% oil.
Good luck,
Edgar
Edgar Perez is offline
Old 07-08-2006, 01:00 AM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What Edger said ! A little turbine oil works just fine. On inspection my d.f engines have vary little carbon in the combustion area and the bearings are lasting longer it seems. I noted a 200 rpm gain and a drop of 50 *F vs a ducted fan fuel. I'm about to test run this on on some sport motors too.
B.W.C. I. H.
freakingfast is offline
Old 07-08-2006, 10:20 AM
Kaos1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check out this thread I asked a while back...
http://www.rcuniverse.com/forum/%25N...1480292/tm.htm
Kaos1
Kaos1 is offline
Old 07-09-2006, 12:52 AM
kmtranmd
My Feedback: (71)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It seems that the concensus is to add a popular turbine oil lube, 1 oz per gallon to 23% blend oil mix using 5-10% nitro and the key being to keep motor on rich side, leaving a little trail of smoke. Fuel brand seems less critical, as guys are using Wildcat, Sig or even Powermaster without wiping out the motors as long as they avoid a lean run. I found a couple sites to try out that BP 2380 turbine oil they raved about.
http://oilstore.stores.yahoo.net/bpturoil231q.html
http://www.pikeoilco.com/bp_turbine.htm
kmtranmd is offline
