Wing Fence placement
Reply
Old 07-08-2006, 01:56 AM
haze_b
haze_b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Wing Fence placement
Aloha,
Just received a Lanier F86D from Tower Hobbies. I've not seen a lot of info about this plane, but I thought it looked pretty cool and would be a great "extreme speed" trainer.
I intend to make it electric with the following setup
AXI 2826/10 brushless outrunner
Phoenix 45 ESC
4 cell 4000mah Lipo
It has been suggested that, with the 35 deg swept wings, I may have tip stalling issues at low speeds. Wing fences have been recommended.
My questions are:
How do you determine the best location, for the wing fence? (The full scale F-86 doesn't have them, so I can't use that as an example.)
Also, does anyone make an adjustable and/or removable wing fence, or example of how to make one?
Any suggestions are welcome.
Haze
haze_b is offline
Old 07-08-2006, 08:37 AM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Wing Fence placement
you could make a winglet on the wing tip like the Gulfstream G5.
even a flat plate on the wing tip to keep air flow over the wing in stead of rolling off the end.
Crazy4Flight is offline
Old 07-08-2006, 10:39 AM
Kmot
My Feedback: (24)
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow, that plane does look good! [sm=thumbup.gif]
Kmot is offline
Old 07-09-2006, 01:50 AM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would do a search on that airplane on here... I don't remember any issues with tip-stalling but I never had that airplane, I did have the lanier F-4 which flew pretty well... I would think the wing tips are washed out???
You gonna use retracts? To be honest I have no idea what the electric stuff means, can you tell us what RPM and what prop. you will be using?
Razor-RCU is offline
Old 07-09-2006, 01:54 AM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is one of the threads I found with a quick search on here- I am sure there are more...
[link=http://www.rcuniverse.com/forum/m_261511/anchors_261511/mpage_1/key_lanier%252CF%252D86/anchor/tm.htm#261511]CLICK ME!![/link]
Old 07-09-2006, 03:05 AM
proptop
My Feedback: (8)
proptop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about some (clear) lexan or plexiglass about 1/16" thick? Maybe make tip plates about 1/2" larger than the tip airfoil, all the way around...you know, if your tip airfoil for example is 1" thick, make the tip plates 2" so you have 1/2" above and 1/2" below...(ahead of the L.E. and behind the T.E. too)
Over the years I have experimented with tip plates, "SFG's" and fences in various locations on the wing, stab and fin, and fuselage, and for what you want, the tip plates IMO would be the best. They might look kinda goofy on that airplane though, that's why I thought maybe clear plexi or Lexan?
Your low speed will be more stable, and the ailerons will be more effective...for starters...
I read an interesting article in Model Aviation a month or two ago, and Don Lowe suggested that the tip was the best location...he was talking about pattern flying and aerobatics mainly.
I think that depends on what you're looking for...and for what you want, I'd agree that tip plates would would be the most effective.
Do you have last months MA? I'll have to look now and see exactly which issue that article is in...
I put some side force generators I cut out of styrofoam meat trays, on my E-Flite Tribute (about a year ago, after I bought a Showtime [8D]) and I noticed a faster rate of roll, and it slows down more for landing...especially when it gets into ground effect. They are about half way between root and tip, kind of like huge fences.
If you want to experiment, get or make a profile foamy and do the old "cut and try"
I "sawtoothed" the entire leading edge the other night...looks awesome, and flys even better! They act like vortex generators...
proptop is offline
Old 07-09-2006, 04:15 AM
haze_b
haze_b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys,
Thanks for the input, It looks like I have a lot of experimenting to do. I noticed another thread regarding tip stalling and refereneced this plane. Appearantly, a bit of reflex helped to reduce the effect.
http://www.rcuniverse.com/forum/m_30...tm.htm#3066973
All recommendations are welcome.
Razor-RCU,
I started flying electric from the beginning, all my planes have an electric power system. The AXI 2826/10 is a common motor used to replace a .46 2 stroke and will fly a plane upto 6.5lbs
The power system I specified should weigh about 32 oz total:
Phoenix 45 ESC
4 cell 4000mah Lipo
A 10x10 APC prop has been recommended, I'll give it a try. It should produce the following output:
rpm: 10553
static thrust: 109.1 oz
prop pitch spd: 99.9 mph
watts: 611 (100 watts per pound provides good sport performance. More is always better)
I expect about a 6 min flight at full throttle.
haze_b is offline
Old 07-27-2006, 01:30 AM
haze_b
haze_b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Aloha,
I made some wing fences out of birch plywood and mounted them with hot melt glue. (in case I need to re-position them)
I used a BVM 60" F-86 as a reference. Gonna maiden this weekend. I hope they help with low speed flight.
Find out soon I guess
Wish me luck.
ID:	497495   Click image for larger version
ID:	497496   Click image for larger version
haze_b is offline
Old 09-19-2006, 04:13 AM
haze_b
haze_b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The maiden went very well. The Lanier F-86D is a great flying plane. It appears that the wing fences worked as planned. The model exhibited none of the tip stalling or low speed handling issues that others have reported. IMHO, Fly it scale and you will enjoy this plane.
I also widened the main gear track about 3 in. Ground handling was fine as well.
Aloha
haze_b is offline
Old 09-19-2006, 09:38 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the update Haze.....
Looks like the fences did work. Something to definately keep in mind.
bob27s is offline
Old 09-19-2006, 12:08 PM
Troy-RCU
Troy-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So you didn't fly the plane before the wing fences? Maybe you are a better pilot than the guys who are tip stalling it and the wing fences are a plasebo. Either way they look good! Nice E-conversion....
Troy-RCU is offline
Old 09-19-2006, 03:42 PM
haze_b
haze_b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Troy,
I wish I could take credit for being a better pilot, however all the "atta boys" i got for the F-86 flight, from the jet jocks, were wipe out by the "Aw Sh#t" of crashing my H9 Pulse XT later that day[:@]
Oh well, lose your fear, lose your plane...
haze_b is offline
Old 09-19-2006, 04:06 PM
Troy-RCU
Troy-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DOH! Bummer. I think the wing fences do help...they work on Migs as well.
Troy-RCU is offline
