Its Bobcat nice
Reply
Old 08-07-2007, 12:54 PM
  #326
Carsten Groen
Carsten Groen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Its Bobcat nice
Auch Terry,
it is a 11x8 I have
When I try to press on the end of the booms (just at the rudders) I need to apply much pressure to raise the front wheel, thats probably why it sticks to the ground. I also see the bumping when taking off, makes it a "bit" hairy....
I completely removed the stock (rear) gears, and put on a alu "bracket" type of gear, used the 4 bolt holes for the engine. I moved it to the front two holes then, this helped a little with the roll, but not near enough. I think I need to move the rear wheels 2" more forward. I'm just afraid that there is nothing in the fuse to put the bolts into at that point....
Regards,
Carsten
Carsten Groen is offline
Old 08-07-2007, 12:58 PM
  #327
MMallory
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Carsten,
It doesn't matter where your wheels are if the plane is set nose high on the gear. If your CG is set per the "revised" instructions, just make the nose a bit higher and the plane should rotate smoothly. The good news is since this is a pusher you can simply hold full up on the entire roll out as long as you remember to relax the elevator as soon as it breaks ground.
MMallory is offline
Old 08-07-2007, 01:26 PM
  #328
Carsten Groen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mark,
I just moved the wheels 1" further forward, and changed the thrustline a little (moved 4 mm spacer to the "rear" screws on the engine (rear as seen on the plane, that would make them sit near the prop)
My plane is just a little nose high, how much "is ok" ?
Carsten
Old 08-07-2007, 01:32 PM
  #329
MMallory
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine is approx. 10 degrees. If you set it on a table and the nose is obviously high, it is good enough. Once again your large prop may wind up being the cause of the problems. I am using a 10" and I plan to drop down to a 9".
Mark
MMallory is offline
Old 08-07-2007, 02:16 PM
  #330
still4given
still4given's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm using an APC 11x6 and I haven't noticed any pitching when I reduce throttle but I've only flown it three times and the second flight was full throttle from start to finish since my throttle barrel locked up at wide open and I had to fly until it ran out of fuel. [X(]
I'm running the Tower 75 and I made aluminum blocks for motor mounts and they are perfectly even so I have only the thrust that was built into the frame. I'm maybe 1/8" higher than stock. Well, Maybe 1/4" when you figure the engine is a bit larger diameter as well. I have to fix the landing gear before I can fly it again. I tore the blocks out on the last landing. It was 6" off the ground when it ran out of air speed while landing. If I can get it fixed before the weekend, I'll do some low passes and reduce throttle to see if I have that problem.
Blessings, Terry
still4given is offline
Old 08-07-2007, 02:42 PM
  #331
Carsten Groen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great Terry !
I'll try my "new setup" tomorrow at the field (weather and work permitting ) and post the results
Do you use the 11x6 on an OS61 ? (seems like a small prop ?)
Carsten
Old 08-07-2007, 02:57 PM
  #332
still4given
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Carsten,
No, I am running the 11x6 on a Tower 75. Yes it is a bit small but we are so limited with pusher props. The engine is turning about 15,500 on the ground. That is OK with the this engine as it is an RPM engine. I think it is rated at 17,000 peak. I just received a couple Graupner 11x8 pushers so that is what I will be trying on the next flight.
I'm looking forward to your results.
Blessings, Terry
Old 08-08-2007, 04:01 PM
  #333
Carsten Groen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just came back from the flying field!
The "drop" of the nose when removing throttle did not change (maybe it did, but then it was so little I did not notice it !)
The change of the landing gear helped a little on rollout, but the biggest help is to keep a little down elevator while it builds up speed on the runway, and then lift it off. WIll try again tomorrow (I'm not _that_ shaky anymore when flying it )
Regards,
Carsten
Old 08-19-2007, 05:14 PM
  #334
Grumman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[8D] Hello Gents!!! Does anyone have any information on flying the Falcon 120 with a 1.30 Nitro Engine???
I would like to know what size prop to go with... Also 2 or 3 bladed???
Thank You,
Mojo
Grumman is offline
Old 08-20-2007, 02:40 PM
  #335
gooseF22
gooseF22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thrustline offset above the fuselage can cause those problems for sure. recommend you bring er back down stock value, with about 8 degrees downthrust. most of the thrust is at the tips of the prop anyway. You are forcing downpressure on the nose during takeoff. and you are haveing hi velocity air over the tail. bad combo.
gooseF22 is offline
Old 08-20-2007, 02:46 PM
  #336
gooseF22
gooseF22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nitro, I saw posts that the GMS 120 wouldn't push it. You may not be satisfied either with the 1.30, I think there areonly
There are not many to choose from . Im not sure, if it can handle the rpm maybe a 14x8 zinger, or 14x6 APC. the next one up is a 16x10 mairscrew 3 blade. Im seeing 1.60's on it.
good luck. do a google search on pusher props, there are not many to choose from.
g
gooseF22 is offline
Old 08-20-2007, 11:42 PM
  #337
angelrcdesign
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For the Falcon 120 ........... put a Byron fan on it with a OS .91 0r Rossi
with 4-1/4 talicone.It will do a loop from level flight and take off is under 100 feet. And the C/G is perfect where it is. I have 10 flights on it and its getting better each time.
angelrcdesign is offline
Old 08-22-2007, 08:14 AM
  #338
Grumman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Gents!!! Can someone measure the width between the 2 Booms please and give the distance from the engine mount to the ground... I am still away from my plane and I would like to continue to round up all the parts necessary to complete it.... I have everything to turn it into a Wren-54 Turbine Machine but I want to fly it with the Nitro 1.30 first..... PROP SIZE??? is the only issue left...I think the 3 Bladed is the way to go.... 14x10 or 15x8 have been suggested.....
Thanks Mojo
Grumman is offline
Old 08-22-2007, 02:19 PM
  #339
Flyboy Dave
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
....if you are talking about the original Nitroplanes Bob-Cat....a 12" prop is all you
can put on it because of the distance between the booms, and the ground clearance.
FBD.
Flyboy Dave is offline
Old 08-22-2007, 04:09 PM
  #340
Grumman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Flyboy Dave
FBD.
Hello Flyboy!!! The propeller is for the Falcon 120 or it's been called White Falcon as well... Just a bigger version...
Thanks for checking in...
Mojo
Grumman is offline
Old 08-25-2007, 08:17 PM
  #341
Nightpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is my Bobcat.
Jett .60LX Turning A 10-6,.......you can only imagine the RPM.
Spring air retracts 300
Removable wings
Very stable
Servo canoes
Crisp roll rate, however, it does require all up trim and still have to hold a touch of up elevator. Yea, its CG properly.
Even with the Jett its still not exactly a real speedster, just stable and does neat flybys.
ID:	749609   Click image for larger version
ID:	749610   Click image for larger version
ID:	749611   Click image for larger version
Nightpilot is offline
Old 08-25-2007, 08:20 PM
  #342
Nightpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Whoa! wasnt expecting that big of pics to come thru!!! Sorry guys!!!
Old 08-25-2007, 08:38 PM
  #343
Flyboy Dave
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
....I fixed it.
....set your picture size at 640x480. [sm=thumbup.gif]
FBD.
Old 08-28-2007, 04:06 PM
  #344
zenoah11
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hello my name is Jacar (spanish) brocker (dutch )
I wanna build a very small bobcat like plane for a cox golden bee (so I mean really small...)
could someone help me with plans (mainly for an offeral idea, dimensions and stuff)
thanks
zenoah11 is offline
Old 08-29-2007, 07:16 AM
  #345
MMallory
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look in the electric forum. There are many Bobcat like planes made for electric which would work well with Cox Bee.
MMallory is offline
Old 08-30-2007, 11:26 AM
  #346
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FBD.
I cut a 14" 3 blade prop down to 13" and it fits with about 1/2" to 1/4" clearance.
opjose is offline
Old 08-30-2007, 11:27 AM
  #347
opjose
opjose's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Out of curiosity...
Are you guys balancing the plane for C.G. using a FULL or empy tank?
opjose is offline
Old 08-30-2007, 11:56 AM
  #348
Flyboy Dave
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
....empty....the tank sits almost on the C/G.
FBD.
Old 08-30-2007, 01:29 PM
  #349
thebluemax
thebluemax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Since it is a low wing I would assume it would be balanced upside down? Also, if it has retracts, the retracts are in the down (landing) position?
thanks...
thebluemax is offline
Old 08-30-2007, 01:47 PM
  #350
Flyboy Dave
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
....yes, you would balance it up-side-down....and no, it doesn't have retracts.
FBD.
Reply
Display Modes
