Magnum crash
Reply
Old 01-12-2003, 05:58 PM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Magnum crash
A Magnum crashed today while doing a slow roll, the wing expolded from the fuz just as down elevator was applied leaving the fuz at 200MPH in a shallow climb which took a few hundred feet to come down at full throttle and no control.
first look the engine is ok, nothing left of the plane.
This ISNT a defect in the plane, it was one of the first built and had two hard years, possible cause could be the central wing bolt added that could have over stressed the centre of the wing.
the impact site.
Cactus. is offline
Old 01-12-2003, 06:02 PM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the remains
Cactus. is offline
Old 01-12-2003, 06:34 PM
ChuckAuger
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Oooopppsss.
Nice divot.
ChuckAuger is offline
Old 01-12-2003, 07:11 PM
Rocket
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default smacking balls
should'nt you REPLACE YOUR DIVOT ?
Rocket is offline
Old 01-13-2003, 12:14 AM
Rocketman612
My Feedback: (84)
Rocketman612's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Next time use a post hole digger
Phillybaby,
must have been somthing to see. Better luck with the next one. Pete
Rocketman612 is offline
Old 01-13-2003, 04:15 AM
RampRat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now that's what i call a lawndart!
RampRat is offline
Old 01-13-2003, 10:33 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default WHEEEEEOOOOW...BHOPH
Don't you just love the way the sound keeps on echoing over the field after the fuse of a speed machine takes off on its own and digs a hole several hundred feet away...?
Also the dry BHOPH on impact is quite noticable...
Was this yours? Sorry for your loss...
Rudeboy is offline
Old 01-13-2003, 11:33 AM
johnd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no it wasnt phillybabys it was mine never mind new one on the way for more high speed fun!!!!!!!!!!!!! it had a lucky life that probably lasted too long anyway
johnd is offline
Old 01-13-2003, 12:21 PM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Central wing bolt?
Where (and why) did you add that bolt exactly John?
How is the wing mounted standard? One or Two bolts?
I have one underway too, so I'm a bit curious as to what mods people make, and why they do so...
Rudeboy is offline
Old 01-13-2003, 12:49 PM
cabanestrut2002
cabanestrut2002's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thats a fine trench it dug john.
cartman
cabanestrut2002 is offline
Old 01-13-2003, 05:42 PM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
During the build he didnt like the idea of those machine bolts so he replaced it with a nylon bolt. this has worked well but when we found the wing Barry noticed the wing bolt was pinching the central brace and could have pulled it too tight to the fuz causing the top of the joint to fail, this would be fine during normal flight but let go inverted. This is only a guess but looks plausable.
As for other mods... the nose floor needs reinforcing.
RampRat...
this is a lawn dart... My Pheonix in the first week of the year
Cactus. is offline
Old 01-15-2003, 01:18 PM
johnd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i replaced the 2 m3 screws because i have seen planes with metal wing bolts have them shaken out and the result is a loss of wing so i put 1 6mm nylon bolt in and what hasnt been said yet is that i have had the plane for arround 2 years and comes out every time i went flying so it got used not like some planes that make it out once a year and last for 10 years dont matter now new one is here give it a week i will do it all again
johnd is offline
Old 01-15-2003, 05:49 PM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well i said hard years mate was just thinking.. if the wing bolt plate is low in the fuz, some block balsa to fill to the wing seat may stop the bolt pulling the wing down too hard and take pressure off the joint.
right, im off to find that thread about A GRRT in a Magnum
Cactus. is offline
Old 01-16-2003, 02:22 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
....I thought this was standard procedure...
Rudeboy is offline
Old 01-16-2003, 05:11 PM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it will be for me when i get one
Cactus. is offline
Old 01-17-2003, 07:02 PM
johnd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
new one is half built and im going to use the kit way of holding the wing on cos it is quite well proven i know the first one is still in one peice so it cant be that bad
johnd is offline
Old 01-17-2003, 07:36 PM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
already! sunday first flight maybe? how was the old one fitted? but that was a solid balsa wing... i think the balsa block bit maybe still be a good way
Cactus. is offline
Old 01-18-2003, 05:43 PM
gigglepig
Location: too far away from phillybaby\'s shed but back real
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes, that could be a possible cause
just dont crash the sabre, i wont accept any possible cause lol
gigglepig is offline
Old 01-18-2003, 07:03 PM
Cactus.
Cactus.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks, now you've jinxed it.
anyway, you just watched me build that one, i've already crashed Pheonix, but it wasnt bad.
See you soon Gigglepig
Cactus. is offline
