Show your shrike pics
Reply
Old 10-14-2006, 01:54 PM
izzy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Show your shrike pics
I am just building my shrike, and wanted to see pics of shrikes, so that i could get an idea of how to cover it
show your pics gentlemen, dont be shy !!
izzy is offline
Old 10-14-2006, 05:11 PM
Electric Delta
My Feedback: (13)
Electric Delta's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Show your shrike pics
Here's my 1/2A Shrike and .40 Shrike!
ID:	541079   Click image for larger version
Electric Delta is offline
Old 10-14-2006, 06:46 PM
Radcom
Radcom's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
izzy
are you building a Shrike 10 ?
I just started building mine .
I ordered in a OS 32 SX ,Macs Header and tune pipe,
Hitec HS-475HB Deluxe Karbonite Gear Servos.
I was going to use Micro servos ,but I will make up the
weight somewhere else.
I thinking of Dark Blue Monokoke on the top,white underneath with
red stripes of some dimensions.
I havn't decided to go with Jett bubbles tank or a Hayes Clunk tank.
Heres a pic of my beginnings .
Radcom is offline
Old 10-14-2006, 11:59 PM
izzy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Radcom
izzy
i just started buiding mine too, same stage as you, changing the spars for carbon tube 1/4 " . ( heard they were weak)
also thinking of reducing the thickness of each rib by 1/8" each side giving maybe a thinner airfoil
not sure though how it would affect handling
i am waiting now for an engine mount , to continue.
izzy is offline
Old 10-15-2006, 04:09 AM
proptop
My Feedback: (8)
proptop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice lookin' airplanes E-D
How big an engine do ya think one of these would be able to handle?
Do you think a modified rear exh. MVVS .49 w/ un-muffled pipe would be over-overkill?
Would I even be able to balance it I wonder...(no, I mean Shrike...haha)
proptop is offline
Old 10-15-2006, 08:36 AM
cobratraxxas69
My Feedback: (31)
cobratraxxas69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's my .40
ID:	541330   Click image for larger version
cobratraxxas69 is offline
Old 10-15-2006, 11:02 AM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The second picture is not my Shrike but I really like it.
ID:	541395   Click image for larger version
Mike Connor is offline
Old 10-15-2006, 11:13 AM
cobratraxxas69
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's another one of my Shrike 40s
Old 10-15-2006, 12:53 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THIS IS NOT MINE BUT IT IS BEAUTIFUL
Razor-RCU is offline
Old 10-15-2006, 01:52 PM
Rebellion
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's my Shrike 40. Bought it from Jeremy a while back. Sorry, but the pics aren't too good since the paint is iridescent and doesn't show up well. She'll be getting a Jett 60L FIRE and full length quiet pipe this winter.
ID:	541456   Click image for larger version
ID:	541457   Click image for larger version
ID:	541458   Click image for larger version
ID:	541459   Click image for larger version
Rebellion is offline
Old 10-16-2006, 05:17 AM
izzy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thought of this color scheme
but i admit its not mine,
this origin is taken of a beautiful prop jet plane built here on RCU bu another person
izzy is offline
Old 10-16-2006, 09:57 AM
Radcom
Radcom's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
izzy
Heres one , when this Shrike is in the air from a distance .
It looks like the plane has swept wings . The lighting bolts
give it that appreance. Also the plane has neon pink on
the bottom.
Radcom is offline
Old 10-16-2006, 10:01 AM
smchale
My Feedback: (67)
smchale's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Izzy,
Here are a few pics of my shrike . It's the 10 sized version with a Magnum XL-15 and tuned pipe. I wanted to achieve a jet look to it so I moved the canopy forward and shortened the hatch. this also meant rotating the engine to run the pipe under the fuse and I made up a f/g belly to house the pipe and be strong enough to belly land on. Also modified a williams bros pilot to continue with the 'jet' look. All finished weight is 2lbs 8 ozs. Well, this experiment didn't yeild quite the results I had hoped for. With the added frontal area the shrike did not want to fly. I cleanly cut the belly pan off and left the set up as is, and it's a great flyer now. We fly off grass so landing on the pipe has not been a problem. It's a fun plane to fly at all speeds. Best of luck with yours!!
ID:	542019   Click image for larger version
ID:	542020   Click image for larger version
ID:	542021   Click image for larger version
smchale is offline
Old 10-20-2006, 12:58 AM
skull1971
skull1971's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my 40 size kit
ID:	544325   Click image for larger version
skull1971 is offline
Old 10-20-2006, 06:41 AM
nexxa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is mine
I modified it a little bit.
- Put 1X 1/4" carbon to replace wing spare
- Install firewall 1/2" back for CG (OS.32 with MAC tune pipe)
- Laminate the thin rudders with 1/32" balsa and glue it with an inclinaison, better looking I think.
- Wing ailerons are shorter by 1.5"
Try many prop from 7 to 9 inch. The best acceleration and speed ratio was obtain with an APC 8X7 running not far from 17 500
nexxa is offline
Old 10-23-2006, 06:39 AM
johnc1go
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is my shrike. Hope you find some inspiration.
ID:	546397   Click image for larger version
johnc1go is offline
