Confused about YS
Reply
Old 11-10-2006, 01:35 AM
slojoe
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Confused about YS
I have a problem with a ys 60 the engine runs good from idle to 3/4 throttle anything after that it dies like lack of fuel. The confusing part is that I have a ys 45 the pressure line is connected to the fitting closes to the carb and the feed line is connected to the other one next to the prop. The 60 will only run with lines reversed from how the 45 is connected. I'm using wildcat 20/20 fuel,OS #8 glow plug, and a macs 1160 tune pipe trying to turn a 10x10 prop. Please help me with my confusion
slojoe is offline
Old 11-10-2006, 10:19 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Confused about YS
It sounds like you're not getting enough fuel. My two YS's have always run nicely, so I never had to play with the pump part, but I would make sure your fuel lines are as short as possible, and as large as possible. I would also take the high-speed needle valve out and with some fuel in the line blow through the line to see if you can blow any crap out. I'd also back the idle screw out some, then test the top end. I have a ST .40 FAI motor that had the same problem and it was the idle screw was in so far it could be used like the high-speed adjustment, I don't know if it's applicable to the YS though.
soarrich is offline
Old 11-13-2006, 12:17 AM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is you're check valve in the right line, direction and working properly?
freakingfast is offline
Old 11-13-2006, 09:56 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
open up the regulator about 1/8 of a turn
bob27s is offline
Old 11-14-2006, 07:57 PM
slojoe
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The check valve is in correctly. The weird thing is this motor is running with the fuel lines crossed It will not run with lines like they are suppose to be as per directions. It runs flawlessly from idle to 3/4 throttle but at wot it just dies. It doesn't lean out and die, it doesn't sputter and spit and die. It just like the fuel was shut off and glow plugged died all at the same time. Engine is not hot nor is the carb dripping fuel. I can't figure it out.
slojoe is offline
Old 11-15-2006, 11:36 PM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think that the 10x10 prop may be too much for it. My numbers show it should hit the wall at 14,500 on the ground, best case. You got me with the crossed lines thing.
Old 11-16-2006, 09:34 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
did you replace the plug ?
if it shuts off rapidly, it may mean the regulator is blocked, or damaged, or out of adjustment.
bob27s is offline
Old 11-16-2006, 10:58 AM
petec
My Feedback: (58)
petec's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make sure the regulator housing is on in the right direction. I for one have put them on backwards when not paying attention.
petec is offline
Old 12-13-2006, 10:57 PM
slojoe
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was told that the diaphram may have a hole in it. I ordered a few of them since they don't make these motors anymore. I keep ya posted. I might have to give these up and get a Jett .60 to replace it
slojoe is offline
Old 12-15-2006, 02:42 PM
buzzingb
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make sure you don't have a restriction (kink, pinch, tank moved or narrow turn) in your fuel line. Another thing to check is the tank and all fuel system before you start the mechanic work on stuff. It is amazing how this stuff can cause a problem yet be so simple.
buzzingb is offline
Old 12-22-2006, 07:31 PM
slojoe
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its not the tank the end of it sticking thru the firewall the lines are right there I checked all the lines and even replaced them at the field. I checked the check valve and the filter no obstructions in neither but the check valve was hard to blow thru at first. I even changed it out with a new one still having the same problem gonna go in and change the diaphram. If all else fales I'm buying a Jett. I have a ys 45 also not one bit of problem with it from day one.
slojoe is offline
Old 04-01-2007, 06:19 AM
slojoe
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just to let you guys know its running like a top now. Its alittle hard to start at first but when shes hot shes HOTT
slojoe is offline
Old 04-01-2007, 06:37 AM
proptop
My Feedback: (8)
proptop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[8D]
So....
What did you have to do to get it running better?
proptop is offline
Old 04-01-2007, 09:59 AM
Gray Beard
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Right, you shouldn't just leave us hanging. What did you find wrong?
Gray Beard is offline
Old 04-13-2007, 12:57 AM
hummingbird111
hummingbird111's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Inquireing minds want to know ,,,,,hummm??? wonder how he got it going??
hummingbird111 is offline
