the unbelieveable speed with a Weston Magnum
Hey
Well I just got here a while back as in last weekend from flying
my first Magnum with a Magunm.46w/performance pipe with well
this is hard to believe this bu um..... I have a 10x6
AirMasterscrew on there. Thoughs of you know what I'm talking
about, the reason I put one on there is that the durability is
better than an APC prop on landings. But My dad bought
a "Radar Gun"off of Ebay .ts a cop one that from the late 70's an
thoughs cost about 1grand apeice .But got it for $150. Well the
prop was flexable you know how thous props are well the
prop sounded like it was hiting super sonic but its not really.
Well I told my dad to go somewhere around 500ft. Well in that
dive I clocked !!126MPH!!.......An I'm like !!WOW!! thats hard to '
believe. An the funny thing about it was its not even @ its
Maximum speed that was just a dive. Well thats all for know.
O an one more thing.Is it just me or so far as the body styail of
the Magnum and the Patroit look kinda alike in some ways as in
one EX. the wing looks like a Patroit's wing
Now that is an impressive speed with a 10x6 prop. Try 9x9, 8x9, etc and really get some fast flying. If you mount the prop so it is horizontal when the engine is off, broken props aren't an issue and you can probably go faster with an APC prop. Hans
That old dog of a 46 and a MA, im surprise you got anywhere close to that. you NEED a APC and practice landing so you dont break props, the prop should stop just past flat, so if the grass wants to push it back up a little it can. Stop using it if you see white stress cracks on the front near the hub. I'd check the gun is ok too, drive along the road and point it at signs to check its about same as your cars speedo.
the 46 wont like much more than a 8x8
Its not like I break props. I have a spinner on there. An I have
over 80 APC props.but That prop was just for first starters.
An far the radior is almost as go as new.m Also you can hear
the doppler shift. what about an APC 8x9?
your a braver man than I, i wouldnt dare put a MA on an engine that quick. at least you wouldnt catch me standaing anywhere near it.
the radio is almost as good as new? i would hope so.....
you could hear doppler shift at any speed, hell, you could hear it as it deadsticked past you...
Actually there about the same . The GRRT @ first will do
21000rpms out of the box with an 8x5 APC . Well my dads
modified GRRT will do 23000rpms with an 8x5 APC.
and the West will do 21k in standard form with a 8x9.
a 5" pitch wont get you far, i'd rather have a 7x9 at 21k over a 8x5 and just hope it can get away on takeoff.
The GRRT has one advantage, but that also makes it alot harder to fit, tum de tum, ummmm laa laa laa
a MDS 15 is much lighter and that does 21k...
you realise the GRRT is meant to be nearer 30k....
be interesting to see pics of how you mount the GRRT, i've not measureed up yet so its all in my head
O yeah. I mean I'm just telling you what it's doing right out of the
box. Its still breaking in to. My dad's only ran about half a gallon
through it. The power prop is an APC 7.2x8.3 . the speed prop is
an APC 7.2x8.6
Also it might put out 21k. But the factor is, how much pull does it
allow you to have. If ya know what I mean.
an APC 7.2x8.6
My Feedback: (12)
MO
The disk area does make a difference you have to have enough prop to get air flow and enough pitch to get the speed you want. I have heard these plans can go over 200mph that is fantastic!!
GA
Try the .40 GRRT FAI Pylon rear intake and exhaust. It is used with a direct clip on header. This is the one I have and it really hauls. On the ground I can tac at 24,100 with a APC 7.2 X 8.6
Of coarse it was shaved on tips to get up the pipe.
One thing about this engine is that it takes a bit more rpm to get on pipe. I think it is around 17,000 to 18,000. I think it has been a while since i put it on tac and flown it. One reason is there is no adjustment of header-pipe length due to the direct clip on.
I think you will really be pleased with this engine set up. Here is the link to it.
http://morrishobbies.com/product_inf...8d0c489cc70933
and here is the pipe for it.
http://morrishobbies.com/product_inf...b89c430d341337
GA
one more thing to keep in mind is that this engine is set up with a WOT venturi and no carb. The carb is separate.
OK I have a ?ion for you. What are the differences between the
the normal GRRT, and the F.I.A.? O an my dad already has the
rear carb on there.
rear carb on there.
GA
honestly I am not to sure. This is just the one I chose to get.
I looked on the website and checked out the specs and they were equal. But I did notice that the FAI did not require a header before the pipe and had a round exhaust with it. On the other GRRT they had a regular exhaust and required a header to attach to the pipe. The only reason I went ahead and got the FAI is because I liked the round exit for exhaust. To me i figured it would have a better flow and would work a little better. Even though on the website is shows the same specs.
So this is why i went ahead and went with the GRRT FAI version instead. The only thing is since it does not have a header you cannot adjust the length to rpm's. The pipe is a direct bolt on setup.
I have been using this engine for a while on my DD and am very pleased with its performance. It really screams and going from a .46 sport engine to this is a huge difference once on pipe.
yay, i have the FAI version
i've got both types of carb, thinking about boring out a throttle version... bear with me..
if i just drilled out the middle it would work fine till i tried to close it, the idle stop will stop it way before its closed, IF i made the slot longer it would compleatly screw up the bottom end mixture becasue it would move too much, however... if i take the end of the slot and carry it on around the body in a straight line it will close and the bottom end needle will stay in the same place.
Correct or no?
OK non throttle will be quicker, but for first flights that scares the pants off me
7.2x8.6 hey... wish we could get those sizes over here.. had to convince the LHS to stock the 8x9, he brought one bag, lasted 30 mins, he stocks them now
Correct or no?
GA
i had to order those props directly from APC. They sent me the full catalog of the props they have so it is easy to pic the one i want and order it. They have a website at www.apcprop.com
try that out and select the props you want.... I also ordered some carbon fiber props but have not yet tried it. I will wait until the weather warms up before trying them out.I am to paranoid about my covering exploding off my wing with the cold temperatures we are having.
also the WOT venturi is much larger than the carb..... I have not used the venturi to see how it runs but with the larger intake in is almost the exact size as the exhaust. The carb I have is the Q500 which is the same one that fits on the .77 and up engine.. from what I have been told.
its runs, OH it runs, we had a DF fan on it the other day, wanted to see if we could get it over 20k to use for a fast DF, 20k.... easy, not sure where it was because there was no taco, but it was the fastest its ever ran.
it used to be in a fast delta with a 8x10 prop, alomst equal in speed to a £250 Jett 50 in a SAS Star Delta.
Anyone know of any reason boring out one of my carbs wont work? thought about it for my PSQ 40, that carb is too small for a Dust
My Feedback: (12)
MO
phillybaby I don't blame you for not wanting to fly without a throttle especially on early flights when you are getting to know and make friends with a new plane.
