Magnum Look A LIKE!!!
My Feedback: (9)
Ok here is my [link=http://www.nitroplanes.com/4fa3034unsta.html]nitro planes model [/link] that came today.
Wing is identical to the Magnum, except that the ailerons are a bit smaller.
Fuse is different internally, but almost identical on the outside, except for it does not have a half fiberglass fuselage.
The fuse is also more rigid longitudinally. It is more rigid all the way around.
Also you have a rudder, that was not on the magnum. I may not use a rudder.
Most certainly not going to use any landing gear either.
My Feedback: (13)
NC
RE: Magnum Look A LIKE!!!
Outward appearance aside, how sturdy is the wing? Nitroplanes only lists up to a .36 sized engine, while most Magnums are flying with .46-.60's.
Also curious how the weight compares. And of course the general ARF quality, straightness, finish, etc. It does look like a good deal!
My Feedback: (9)
I am planning on using my west 50 v-1 from my recently departed magnum.
Wing is more rigid than the magnum. My magnum wing was skinned with some soft or spongy balsa.
This wing has a harder skin on it.
The stars will have to go, sorry if this offends anyone. Just not my thing.
the fuse is nice and straight.
julian
julian
ORIGINAL: Julian537
julian
julian
I have my doubts about the visibility of the overall color scheme. Then again, yellow and black kind of sucks in that regard too.
PLEASE post more pix, are the elevators moved by seperate pushrods like the Magnum or is there a wire joiner and one pushrod? Is the engine area the same? With the Weston .50 fit? What kind of covering? I recovered my last Magnum and it was a pain to get the covering to stick to the fiberglass, the wood turtle deck is a plus for that. You say the wood used looks like better quality? Same wing thickness and airfoil? please, more info....
My Feedback: (9)
Yes seperate pushrods for the elevator. uses the same exact setup as the magnum. uses the plastic plate as a joiner.
The weston 50 fits like a glove. Same exact engine bay.
Airfoil is identical also. thicker plywood on the sides of the fuse. not at flimsy as the magnum.
NB, CANADA
It lool like the Flying weight: 7.8lb / 3540g is wrong, what should I expect for total weight?
Let me know. Anybody flew one yet?
Let me know
Let me know
My Feedback: (9)
Have not even started it.....
Been working on an outlaw. It is all boned up, but now I have to cover it and put on the control surfaces.
could be a week or 2 before the Magnum/lookalike is ready.
The first magnum i put together, was ready in 2 evenings. Could have been the reason for the elevator coming loose too
FL
If anyone has one of these planes in air yet, please let us know.
I'am still waiting for nitroplanes to get them back in stock.
John
John
My Feedback: (9)
John,
I think that weston UK has the Magnum R now for sale in the US through their US distributor.
The last time I called and talked to Weston before xmas. they said that their distributor in the US would have them available in January. The magnum retails for $95 or $98. This is really not that much more for the real thing. Call them , they are slow at responding to email. The international call cost me $3 but it was worth it and very informative on their products.
All in all though, this plane from nitro planes is the exact copy of the magnum. If they were both naked without covering, you would never know the difference. Ok maybe the nitro model has a rudder.......
And a wooden turtle deck, and a windscreen, and landing gear, and who knows what else?
They are not the smae plane though they copied alot of the Magnum...
Note that the changes are not neccisarily bad things...
ORIGINAL: evan-RCU
Now if I could just get the prop to stop horizontally every time.. even though I set it to just kiss compression as it goes horizontal, it seems to have a tendency to stop vertically anyhow. Is there a technique/trick to shutting down the engine that helps prevent this? Problem is when you fly on sod, it's great for belly landings when the prop is horizontal. But when it stops vertically or close to it - bad things things happen with flat low wings and high approach speeds.
MJD
I agree, but was pointing out that there are differences. I have the prop hit good compression at the 11oclock- 4 oclock poisition because it always moves a bit more while coming in. If the prop hangs down at the 4 oclock position the blade angle allows it to bump level if it does contact the ground. I do know taht if you run the engine lean that it's hotter and looses compression alowing it to bump around a little more too. I usually fly around on low to mid throttle for a lap before I set up the landing to allow the motor to cool off a bit.
4-Channel Falcon 30 - 34.3" United States Air Force USAF Nitro Gas Radio Remote Control Airplane Jet Glider
i just dunno why they call it a glider! i guess when you dead-stick you can say to everyone> it's OK it's a GLIDER
but it's sold out so i guess it must be good
ORIGINAL: evan-RCU
It puzzles me why the basic design would be copied so closely, but I suppose rather than inventing the next best thing the idea was just to hop on the bandwagon. Kind of like the copies that G---t Pl---s shamelessly brings out of other people's designs that become popular - which is the reason I refuse to buy their products and am only too glad to say so.
On prop stoppage location: yeah, I suppose it is not bouncing back and stopping under compression, but just not making it through the last compression stroke before stopping. Your idea for prop location covers both possibilities, off and on compression - I might just try that. I don't run lean IMHO - I use a Jett bubbleless tank, and during flight I have a decent smoke trail, in fact I think I may have a few rpm left to go and still be on the safe side of peak.
I can't correlate my prop problems with the manner in which the motor stopped - i.e. run out of fuel, stopped it myself from full bore, or ran slow to set up for landing then killed it, I have not payed attention to that to know. But I will check it out once the ice cap moves out of here and I can go flying again. I know all three scenarios have gone on though. Hmmm. I can say that I have landed after running out at full bore and had the prop stop in the right place, but of course it is going to do that sometimes so that alone tells me nothing. Looking forward to testing this out. I've always used somewhere between 8:45 - 2:45 and 9 to 3.
MJD
My Feedback: (9)
Evan,
Your right.
I forgot about the top half of the magnum being fiberglass. the only part of my last magnum that survived was the wing and the fuse section in front of the wing. I think the nitro plane fuse is stronger over all. does not feel so flimsy.
Your right.
