Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
Please help with rates on old Cermark F16 prop jet
Reply
Old 12-04-2006, 08:44 PM
Fishinmagician
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Please help with rates on old Cermark F16 prop jet
I just picked up an older version of the Cermark F16 prop jet. This bird is ready to roll but I am unsure of the rates. I typically fly 3D and don't want to have a mishap. I went to Cermarks website but I did not see the manuals online. If anyone has any ideas, that would be much appreciated. Thanks in advance.
Fishinmagician is offline
Old 12-04-2006, 10:14 PM
Cyclic Hardover
Cyclic Hardover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Please help with rates on old Cermark F16 prop jet
I several propjets but not the cermark but some here do and will answer shortly I'm sure---but have you ever flown a propjet?
Cyclic Hardover is offline
Old 12-05-2006, 08:48 AM
rob r
My Feedback: (57)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No I have never flown a prop jet before. Any tips are much appreciated. Thanks.
rob r is offline
Old 12-05-2006, 09:14 AM
Cyclic Hardover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: rob r
Wells they don't float around like some (dual rate) 3d plane. You need to keep power on it constantly right down to landing or it will drop from the sky like a brick. They are a blast to fly.
Old 12-05-2006, 04:43 PM
MadScientist
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Let's assume that you have your CG set correctly first. I have mine set about 8 1/2 inches back from the root edge of the wing where it connects to the fuse. From there, your rates should be somewhere around here: Ailerons- about 5/8 is plenty, you might want to set that as your high rate and make your low a bit less. Rudder- as much as you can. Elevator- the tip of the leading edge closest to the fuse should travel about 1 inch for low rates, an inch and a quarter for highs. I use the high for short field takeoffs, and fly with everything else for the most part.
Remember- these things don't exactly hover all that great
MadScientist is offline
