Phenom Assembly
Old 01-07-2007, 08:58 PM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Default RE: Phenom Assembly
The wings were fitted and epoxied today. 30 min with milled glass fibre. Sanded with care to get the fit to the wings to the spars to align with the fuse.Sanded prime of mating surfaces for good bond. Dremel tool put some crosshatching in on the spars to hold the epoxie. Still waiting for my pipe. servo hatches are done. Radio hatch requires a swith-charge jack mouniting hole and the deans antenna hole needs to be drilled. Once the pipe is fitted and battery installed. CG will be checked then off to paint.
ID:	593289   Click image for larger version
ID:	593290   Click image for larger version
Old 01-07-2007, 11:20 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Lookin' really good! [sm=thumbup.gif]
Old 01-08-2007, 12:14 AM
ChuckL
Glued my wings on tonight probably get the stabs on in the morning try to get some pictures tommorrow, I needed a break from my other projects so I dug into this one tonight.
Old 01-08-2007, 12:45 AM
vasek
vasek's Avatar
If it flies as good as it looks > you've got a winner!
Old 01-08-2007, 11:00 PM
ChuckL
I got a little bit done today wings are glued together fins are glued on. Cleaned up the wing joints with a little body filler the wings fit together nicely but now the joint wont be visible.
Old 01-09-2007, 07:31 AM
  #31
ChuckL
heres a picture
Old 01-09-2007, 09:47 AM
  #32
bob27s
My Feedback: (19)
bob27s's Avatar
Looks good.....
it appears that the designer paid good attention to details
Old 01-09-2007, 12:01 PM
  #33
Mike Connor
Mike Connor's Avatar
Would it be possible to get a picture straight on to see the wing thickness? Has anyone calculated the % wing thickness?
Old 01-09-2007, 01:31 PM
  #34
Details 4 Scale
Mike,
I believe the Oakdale website says it's a 5.5% ailfoil. Russ said the wing root thickness is 1.2" with a chord of 22.25".
That calculates out to 5.4%.
Dan
Old 01-09-2007, 05:24 PM
  #35
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
1.2 sounds about right... I just got mine yesterday. Looks sweet!
Old 01-09-2007, 06:00 PM
  #36
Mike Connor
ORIGINAL: Details 4 Scale
Mike,
I believe ....... calculates out to 5.4%.
Dan
Thanks Dan
Old 01-09-2007, 11:14 PM
  #37
Rahlberg13-delete
Rahlberg13-delete's Avatar
Chuck/Crazy,
Lookin good! You're really going to be fired up once it leaves your bench!
Keep up the good work,
Russ
Old 01-11-2007, 11:04 PM
  #38
Crazy4Flight
My Feedback: (540)
Filling in the seam of wing and fuse....
ID:	595990   Click image for larger version
Old 01-18-2007, 10:11 PM
  #39
cmopar
Any more updates ?
Corey
Old 01-18-2007, 10:19 PM
  #40
Crazy4Flight
My Feedback: (540)
I just started smoothing the fillets at the base of the fins. Next the fillets on the servo hatches. Headder and pipe will be here Monday. Once the pipe support is placed I will be ready for paint. Also I cut the hole for the switch-charge-jack in the radio hatch.
Old 01-18-2007, 10:38 PM
  #41
ChuckL
I must have got lucky doing my fins while the epoxy/microballoons was still wet I just ran my finger along it and it came out smooth as could be. I haven't got anything else done I'll get to it this weekend I've been spending to much time on my helis this week to get any airplane building done. I hope my cowl comes out as nice as yours I'm on hold on that though until Dub sends me an engine.
Old 01-21-2007, 06:47 PM
  #42
Crazy4Flight
My Feedback: (540)
Painted the Phenom. Note this is the base coat.
Final colors will have an anodized aluminum look.
ID:	603516   Click image for larger version
Old 01-23-2007, 10:33 AM
  #43
ChuckL
Wing joint is sanded servos are installed and the pushrod covers are glued on. I used goop to glue on the covers and the mounting blocks for the covers. The pushrods are 4-40 rods inside a carbon tube, ball link on servo end and steel clevis at the elevon hooked to HS5625s. This has been a very simple build I haven't spent much time on it at all just a little here and there when I get a chance everything fit exactly like it is suppose too.
ID:	604906   Click image for larger version
ID:	604907   Click image for larger version
Old 01-24-2007, 10:40 PM
  #44
cmopar
I got mine today. Now i need to decide on an engine !!!
ID:	605991   Click image for larger version
ID:	605992   Click image for larger version
ID:	605993   Click image for larger version
Old 01-25-2007, 01:12 AM
  #45
Kmot
My Feedback: (24)
Kmot's Avatar
The DF engine looks pretty impressive in there!
Old 01-25-2007, 09:20 AM
  #46
cmopar
Ya im leaning towards the 91 !! Ill have to see whats under the fiberglass to mount it to >
Corey
Old 01-25-2007, 03:38 PM
  #47
Crazy4Flight
My Feedback: (540)
The 91 D/F sounds great, but I think you will need to add tail wieght. Do a trial balance with the plane dryfit assembled. You could cut a hatch between the fins to place your battery back there. to avoid adding useless weight.
What Size are the Jetts and Rossi?
I think the plastic internal engine rails go back to the 1st former across the fuse.
Email Russ at Oakdale and ask him.
bob
Old 01-25-2007, 06:04 PM
  #48
cmopar
I emailed russ waiting for him to reply. The rossi is .45 tuned piped timed and the jetts are sj.50 and a qjett .40 im sure any will work .
Corey
Old 01-25-2007, 08:10 PM
  #49
Rudeboy
Rudeboy's Avatar
Thanks for the pics Corey! That makes things very clear. It is going to be nearly impossible to shoehorn a big RIRE engine into that plane (in a graceful way)
This thing is clearly designed around 40 size power plants. I'm going with either one of Dub's practice F3D engines, or with an OS 46 VXDF. Leaning towards the VXDF at the moment... I would like to have a throttle on a hand launching delta.
Old 01-25-2007, 09:24 PM
  #50
Crazy4Flight
My Feedback: (540)
my BME 44 did not look to fit well. [&:]
