cermark f16 prop jet
RE: cermark f16 prop jet
hi
can any one offer me any advise? i've got the cermark f-16 prop model, with the standard elevator linkage set-up i was getting 5mm play at the leading edge when the system was running, now i have changed the elevator to seperate servos using direct m3 links and clevis's, this gives me 3mm play at the leading edge of each elevator. should i get any play on the elevator? i am just waiting for this information before test flying! all the bits when held by hand show no signs of play. any suggestions?
many thanks
many thanks
My Feedback: (61)
AL
I will agree any play is to much. I ended up with about the same amount in mine, I'm changing it to double ended ball links bolting everything together. Also using digital servos so it will hold center.
I just finished building the Cermark F16. I'd like to get an idea what other builders are getting on finished EMPTY weight. I'm using a Jett 90 with the Jett muffler. The airplane also has a lighting kit from Electro Dynamics which required a 3 oz. battery. Coupled with a 3000 mah rx battery in the back, the CG came out exactly at 7 1/2" back from the leading edge as it should.
All that said, the finished weight is 10 lbs., 15 3/4 oz.; heavier than I thought it would be. Cermark says this plane should be 9 lbs.
What are you guys seeing in the weight department?
Rick
Rick
#31
My Feedback: (71)
Anything under 11 pounds is good for this plane. Remember you got a few extra ounces from lighting stuff. 9 lbs is unrealistic for any plane with 91 size motor up front. Mine also has Jett 90 and was clocked at around 130's coming out of a dive. You'll be happy. That engine is pretty loud if you have any noise restrictions at the field.
#32
Thanks for the feedback. I became a bit concerned when I checked the weight spec for the plane at the Cermark website. I think 9 lbs may have been correct at one time for an older version with a .60 and no retracts. The Jett 90 is certainly heavier than any .60, agreed. If Saturday May 2nd is a good weather day, it'll go up to for the initial flight.
#33
CA
Sorry, the 9 pound is unrealistic given that is was done with 60 size glow. You can fly it with a 60/75, but it will be such a dog.
Peace,
Steven Chao,
CERMARK
Peace,
Steven Chao,
CERMARK
#34
My Feedback: (19)
OH
ORIGINAL: k8svrick
The Jett 90L with jett-stream muffler, plug, and spinner nut - ready to fly - is 26 oz. Engine only is 20oz.
OS 91FX is 24.5oz with muffler , 19.4 naked. (not including spinner nut)
OS61FX is 19.5 naked, and about 24.6oz with muffler
ST G-90 is 26.5 with muffler, and 20.5 naked
Magnum 61XLS is 23oz with muffler (published, but I have not weighed one)
Rossi 60 is about 21oz naked
