If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 7 of 11 FirstFirst ... 56789 ... LastLast
Results 151 to 175 of 272
  1. #151
    Join Date
    Nov 2006
    lisbon, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Thanks guys!
    Is the motor going to be 'pylon-mounted'?
    Yes the motors will be pylon mounted. On this electric version Im mounting a left and a right with differentail thrust for turning.
  2. #152
    Troy-RCU's Avatar
    Join Date
    Jan 2002
    Oceanside, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    ...anticipating pics and vids!
    Can you feel that Buddy, HUH, HUH, HUH!!!??
    I Have EXORSIZED the electrons, this plane is clear.
    Revver Bro. #151
  3. #153
    Join Date
    Jun 2007
    Orlando, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
  4. #154
    Join Date
    Jun 2007
    Orlando, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Just read up on your progress. Your carftsmanship is fairly impressive! I've got build going on. I'm converting an old school outboard V hull; Only i'm thinking Hydro foils. So I've found your progress very interesting. I've concidered Gyros to stabilize my concept. But the whole topic high performance boats in RC has turned out to be rather captivating. I'm from The Airborn end of RC. Foamies, a helicopter, & I started with a SIG Kadet built from a pile of balsa. And, after reviewing your entire thread, my greatest fear for you is a high speed blowover [:@]. If the Japs got 100MPH out of a .46; Your talking about a ducted fan .91. Remember, that Japanese airboat is on some pretty solid looking pontoons & do they cut in & draft a little? also it has a long fuselage for axial stability. I am impressed with the cooperation i've seen in this forum. I hope you blow away the damn competition when you get this thing set up. You got me rooting for you! Anyway, I think I'm gonna go buy a fancy gyro or 2 for my high performance hydrofoil. I'll keeps tabs on your progress. Wild_Bill
  5. #155
    Join Date
    Nov 2006
    lisbon, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Thanks Wild Bill! I wish you the best on your build, Id really like to know how it turns out.
  6. #156
    Join Date
    Jun 2007
    Orlando, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    OFF TOPIC:MORE INFO ON HYDRO FOILS
    Been doiing some more research:
    think gyro
    Capacitive level sensor
    "Trampofoil A1 "
    [&:]click this link for sure!
    http://members.tripod.com/austin_ame...craft/id6.html
    Roll. The rear wing is in 3 parts, separated by the rear struts. The middle part is fixed, and the two outer parts, about 70mm of span each side, move in oposition for foll control. A pendulum angle sensor is used for slow roll control, with a gyroscope for fast roll control. These control a fast servo motor which moves the outer wing parts. There is also an input from the rudder, to alter the angle as a turn is started. This seems to work well, but there were a lot of bits to get working.
    http://www.foils.org/gallery/model.htm
    http://www.home-taylor.freeserve.co....lan%20man.html
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Attached Images Attached Images
  7. #157
    Join Date
    Nov 2006
    lisbon, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Very interesting!
    What are you going to use for power?
  8. #158
    Join Date
    Jun 2007
    Orlando, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Everythings in the research stage now. Previous rc hydrofoils utilized 2 different gyro systems. One for bow to stern attitude control, the other for port and starboard. What i've got right now is a 10 yr old 2 channel am V-hull outboard nitro. Runs like a top! But, it's no hydro foil. I'm going to emulate the "dynafoil" waterbike design with inline vertical foils, the best design i could come up with. But i'm not on a contest time table; so don't expect any amazing footage off the cuff. A lot of designs seem to over do the wing area of the foils, therefore a lot of them are kinda slow. "Dyna foil" seems to get the dimensions & scale about right.
    Anyway, about your project, at 100MPH You have to concider that your "boat" is going to behave a lot more like an airplane than a watercraft. The big idea is making your boat "fly" on the water or just skimming the surface. The latter is perffererable. Aerodynamics & Center of Gravity are primary concerns of any type of aircraft. But, i'm not one to preach. I think you need somebody who's well read on aerodynamics. anyway, thats my two cents for the day.[8D]
    As far as power goes, I'm going to try to stick with the motor I have attached to the boat. Perhaps I can use the gyro to do some mixxing with the rudder control. It's a .40 i'm guessing, I'm not sure about rc Boat Motor makes. Anyway whole engine pivots at fire wall rudder & all. It runns on 60% nitro. green hull. I'll try to get a picture posted.
  9. #159
    Join Date
    Nov 2006
    lisbon, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Well I got my lil electric rigger finished, here are a couple of pics.
ID:	817423   Click image for larger version.
ID:	817424   Click image for larger version.
  10. #160
    Join Date
    Apr 2005
    Calgary, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    ORIGINAL: hooty301
    Sweet! If it follows the aircraft rule of looking fast and being fast, you should have a winner.
    Mark
    Waco Brotherhood #4
  11. #161
    Join Date
    Nov 2006
    lisbon, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Thanks mmattockx
    Ive made a little progress on the nirtro version also, Ill post some pics, hope too have her done by spring time.
  12. #162
    Join Date
    Nov 2006
    lisbon, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Heres a pic of the frame for the nitro boat.
  13. #163
    Join Date
    Nov 2006
    lisbon, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Hello fellows, made some progress on the nitro rigger, here are some pics.
ID:	836788   Click image for larger version.
  14. #164
    Craig-RCU's Avatar
    Join Date
    Jan 2002
    minneapolis, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Very nice. Have you taken the electric for a spin yet?
  15. #165
    proptop's Avatar
    Join Date
    Oct 2002
    Rome, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Lookin' great Hooty...superior craftsmanship[8D]
    Is that horizontal tail on the elec. job fixed? (I mean, do the rules allow a moveable trimming device?) It looks like it's adjustable, but not controlled by a servo.
    We were talking about gyros, and moveable "elevators" but that would be moot, if the rules didn't allow such devices, aye!?
    < Wrongway Feldman's Kreider-Reisner KR-21...(on Gilligan's Island)
  16. #166
    Join Date
    Nov 2006
    lisbon, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Thanks Craig, yes I have run It and was pleased.
    Thanks proptop, yes a movable triming device is perfectly legal, Im gonna try it manual for now maybe try a gyro later on.[8D]
  17. #167
    Join Date
    Nov 2006
    lisbon, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Hello fellows. Heres a vid of my lil electric rigger in the snow. The wind was blowing just a little to much.
    [size=5]IN THE SNOW
  18. #168
    Craig-RCU's Avatar
    Join Date
    Jan 2002
    minneapolis, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Very cool!!! That looks like a lot of fun! I made some skis for one of my planes and tooled around the local park in the snow a few years back. There were too many trees in the park to safly fly, but I enjoyed slaloming between the trees caught some air for short distances going over bumps.
  19. #169
    Join Date
    Nov 2006
    lisbon, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Thanks Craig!
    Yes it is a fun little boat.
  20. #170
    Join Date
    Nov 2006
    lisbon, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Some more progress.
ID:	849724   Click image for larger version.
ID:	849725   Click image for larger version.
ID:	849726   Click image for larger version.
ID:	849727   Click image for larger version.
  21. #171
    Join Date
    Nov 2006
    lisbon, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    More build pics.
ID:	854237   Click image for larger version.
ID:	854238   Click image for larger version.
ID:	854239   Click image for larger version.
  22. #172
    Join Date
    Jan 2008
    Winter Haven, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Hey Hooty that is very cool!! How far have you come on the NITRO Rigger??? I am getting into the helicopters right now and still thinking about building a Airboat, due to the fact that I live near a hundred lakes. How are you liking the snow and all of the winter experience as a whole??
  23. #173
    Join Date
    Dec 2001
    Waseca, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Very cool indeed. Excellent craftsmanship on the little electric.
    Just out of curiousity, those tubes that hold the outriggers in place are pretty draggy. Would it make sense to either encapsulate them in some sore of airfoil shape? also, they could be adjustable to help trim the boat on step??
    Dave Norman
    29w
  24. #174
    Join Date
    Nov 2006
    lisbon, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Thanks guys!
    Slowly but surely making progress. Winter isnt to bad just waiting for the spring thaw.
    I thought of adding a trailing edge to them, do you think that would help? They will be adjustable by adding shims under the tubes, still need to slot the holes.
  25. #175
    proptop's Avatar
    Join Date
    Oct 2002
    Rome, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Fastest Engine
    Somebody will correct me if I'm wrong, but I think a round tube or wire strut has about 3 or 4 times the drag as a streamlined strut of the same thickness? I think you need something like a 4:1 aspect ratio though? So...a 1/4" thick strut would need to be 1" wide. (approx.)
    There is an airfoil shaped Alum. strut tubing available, but I don't recall who makes it? K&S maybe? Or you could use Carbon fiber?
    Years ago, I made some really strong, yet light struts with the thin wall Alum. airfoil tube with a Carbon fiber tube reinforcment inside it.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
