Fastest Engine
#205
OH
RE: Fastest Engine
Thanks fellows
I went back in and reloaded them to this sight, sometimes it gives me trouble so I just use photobucket.
(upload the photos here ... my firewall has fits with photobucket )
#207
RE: Fastest Engine
OK HOOTY ITS BN A WHILE WHATS HAPPEND?? HAVE U SAILED HER YET ??
IM IMPATINT[:@] I FELL IN LOVE WITH UR BOAT... I USETO MAKE FOAM FLAT BOTTOM AIR BOATS THAT REALLY LOOKED COOL !!
AND THEY R REALLY AWSOME IN THE SNOW (this was way b4 the flying boat came around)[img][/img] SO TELL US WHAT HAPPEND!!
#208
OH
RE: Fastest Engine
Hey thanks fellows!
Fastcrasher thats a nice lookin airboat, how did it run?
I havent put her in the water yet had a little challenge getting the Jett to run right with the tanks mounted so low, got it perty much dialed in now though.
Heres a little dry test run, running rich on the breakin prop.
Test run
[link]http://rcuvideos.com/item/HSQQ074MZN3FZ6MM[/link]
Test run
#210
RE: Fastest Engine
[quote]ORIGINAL: hooty301
Hey thanks fellows!
well if i recall it was slow on the water it only had a OS.15 on it and it was flat bottom so there was a lot of drag ..... but on the snow and ice wow it was fun!!
that boat of yours is going to haul ***** bro cant wate to c it on viedo on the step !!
#211
My Feedback: (19)
OH
RE: Fastest Engine
Sounds like its running very well ..... !
If you are going to change the prop up from a break-in size, now is the time to do it.
Don't over-tweek the midrange if you intend to upsize the prop a bit. Sound perfect as is. The extra load will be a different rpm transtion.
With an agressive pipe (yours is an agressive higher rpm setup), its hard to get a 100% perfect up-and-down throttle. It will never be smooth and linear. The pipe step is just a throttle position to be avoided. Throttling up onto the pipe is at a different rpm and different fuel draw than when you throttle down off of the pipe into mid/low power.
If you think you have the "up" size dialed in perfect, the engine will go lean and sometimes blow a plug throttling off of the pipe (engine is screaming, it is hot, higher rpm the pipe is demanding of it, and then you quickly throttle down and reduce fuel.... poof!). So take the best compromise. And then work with glowplugs to deal with a slightly rich "up" transition. (the OS type F plugs sometimes help in extreme situation here.... ).
Let me know when the first flight is. (its going to run in ground effect most likely )
Bob
Bob
#215
My Feedback: (59)
RE: Fastest Engine
Great... I'm right across the line in Pa. Used to do some drinking in Mr. D's country Lounge years ago. Met up with a few women from Lisbon.
I'd love to be there when you run it.
John
John
#223
OH
RE: Fastest Engine
Well guys heres a little water vid during some testing. The wind wouldnt let up, making the water a little too choppy for my liking.
http://rcuvideos.com/video/Testing-rigger-90-Jett
#225
MN
RE: Fastest Engine
Definately, that thing needs to stretch it legs
Always look forward to Hooty posts, as well as Rmenke's.
I think you need a body of water with Salt to get the most out of that motor.
Looks very nice.
Looks very nice.
