What is an OPS motor?
Reply
Old 01-08-2007, 09:15 PM
proptop
proptop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: What is an OPS motor?
Yep!
proptop is offline
Old 01-08-2007, 09:50 PM
I-Love-Jets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Julian537
How does the Rossi 65-81 DF motor and the BB rossi 90 Aero DF motor compare, if they compare at all?
So here are some Rossi speed and DF engines to complete the list. All are discontinued now.
Rossi .15 speed
This has been the very successful “prototype design” for many later 2.5 cc C/L speed engines from other manufacturers. Both pipe timed and non-pipe timed available at that time. A legend for over 30 years.
ID:	594003   Click image for larger version
ID:	594004   Click image for larger version
I-Love-Jets is offline
Old 01-08-2007, 09:52 PM
I-Love-Jets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rossi .40 FAI pylon
Not until as Mr. Ranjit Phelan has upgraded this Rossi (AAC + improved intake assembly + special head) in the 90s it eventually became a strong competitor to the Nelson .40 FAI and IR .40 FAI. This of course was the pre-MB .40 PROFI engine era.
ID:	594006   Click image for larger version
ID:	594007   Click image for larger version
ID:	594008   Click image for larger version
Old 01-08-2007, 09:53 PM
I-Love-Jets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rossi .53 fan
Offers better ducted fan performance (with Turbax, Thorjet e.g.) than the long-time discontinued OS .46 VR-DF. But I personally would prefer the OS .46 VX-DF which features a great carb.
ID:	594010   Click image for larger version
ID:	594011   Click image for larger version
Old 01-08-2007, 09:55 PM
I-Love-Jets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rossi .61 Speed
This powerhouse should be as strong as the PICCO .60 speed engine. Compared to the 5 port OPS 60 VAE the ROSSI .61 or .65 (both 3 and 5 port) runs not as smooth and seems to be slightly inferior powerwise. Also hard to find nowadays in new condition.
ID:	594013   Click image for larger version
Old 01-08-2007, 09:57 PM
  #31
I-Love-Jets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rossi .81 Fan
The Rossi .81 unfortunately is badly balanced. The crankshaft counterweight is too light to compensate for the relatively heavy .80 sized piston, because Rossi simply used their basic .65 crank layout for the 13 cc engine. For that the ROSSI .81 DF running characteristics are rather rough at about 20000 rpm.
Old 01-08-2007, 09:58 PM
  #32
I-Love-Jets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rossi .90 DF (later 5-port version)
See next posts
Old 01-08-2007, 10:01 PM
  #33
I-Love-Jets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ROSSI .105 DF
I believe this “heavy block” engine is way overrated at factory claimed 28000 rpm. 21000 maximum are more realistic IMHO. This should be a nice “torquer”. Good for bigger fans (Hurricane e.g.) and ample static thrust. Though again a painful carb.
ID:	594020   Click image for larger version
ID:	594021   Click image for larger version
Old 01-08-2007, 10:04 PM
  #34
I-Love-Jets
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: proptop
How does the BVM .91R compare (power and weight wise ) to the above engines? It's made by Nelson, right?
OK, so let’s compare several .90 DF engines:
BVM .91R
The BVM .91, which was released in the mid 90s, is the newest .90 ducted fan design of all ever available. The BVM .91 and the BVM .96.engines by Nelson thus do feature several „internal goodies“ the OPS, PICCO and ROSSI engines are missing (including OS .91 VR-DF and K&B). So only the BVM .91R is capable of rpms over 25000 in flight.
But: Directly compared to the other .90 sized ducted fan engines the BVM .91R by no means is „torquey“. It is more a pure „runner“.
PICCO P90 DF
Except for the mediocre Picco P90 R/C carb (which should be replaced by a good OS carb)
the only severe downside of the PICCO P90 is the stock conrod being too weak to reliably last about 50 runs. For that people liked to purchase the super sturdy RPM rods (aftermarket) in the past. However this engine is exceptional strong. It pulls the Ramtec fan better than any other engine.
ROSSI 90 DF
The ROSSI .90 ducted fan was the second winner in the class 10 to 15 cc during the last German Speed Cup (2006) and was only 4 kph „slower“ than the first placed BVM .91. The ROSSI 90 carb is a pain compared to the OS 9B carb for example. Other than that the Rossi 90DF is a powerbrute as well. I would say slightly weaker than the PICCO P90.
OS .91 VR-DF
This engine is quite easy to handle. Super carb. Forgives a lean run or two. The only downside are the too small head screws and exhaust adapter screws. By exchanging these stock screws with high steel grade ones you can eliminate this problem. Very torquey engine.
Engine weight in this .90 class generally is of no importance for straight line speed competition. Bad throttling carbs such like the ROSSI also are of less importance here since nobody intends to throttle. Important: A R/C mixture control for 90 sized DF engines is mandatory to avoid lean runs (busting the cylinder/piston assembly). At a given (maybe too) limited cooling area of housing and cylinder head these 15 cc engines run considerably hotter than 10 cc engines.
Old 01-08-2007, 10:17 PM
  #35
proptop
proptop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fan-Tastic photographs and information!
Thank you
proptop is offline
Old 01-09-2007, 09:43 AM
  #36
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: I-Love-Jets
Yes, PICCO made a bunch of aero speed and ducted fan engines in the 80s and the beginning of the 90s. After that era, these well made engines sadly discontinued.
I’ve added only the high performance types, although Picco also made some FIRE and FISE sport (pattern) engines.
I bought the .40 FISE sport engine when it first appeared - heck when was that, maybe mid 80's? The guy at the store told me "oh man, it's the strongest .40 I've ever seen, turns a 10-6 about 16 grand". Uh no, it did not turn a 10-6 that fast [I don't listen to sales people at LHS's anymore either]. But it was a reasonably strong motor and ran pretty well. Also, the muffler was pretty restictive and the welded joint between the muffler can and adapter was prone to failure. Still have it, though I must clean it up after digging it out of the dirt a while ago.. hey, that reminds me of another "that's not good" incidient..
MJD
MJD is offline
Old 01-09-2007, 01:31 PM
  #37
cncswiss1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anybody tried converting any of the current hot marine engines? some have crankcases that would allow turning the exhaust towards the back. a head would be a simple build, since watercooling might be a bit heavy, or you could fuel cool the thing. for limited runs.
by the way Thanks much I love jets that was very informative!
cncswiss1 is offline
Old 01-09-2007, 09:30 PM
  #38
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been thinking about the OPS .80 for a conversion... looks possible. Finding or making a decent integral spinner is probably the hard part...
Rudeboy is offline
Old 01-09-2007, 10:15 PM
  #39
Julian537
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great Info ! I love Jets.
Thank you for the pictures and your posts.
once again Great info!
Julian
Julian537 is offline
Old 03-10-2007, 09:02 PM
  #40
RC GOLF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In the case of a byron Mig 15, what engine would you recommend?
P80
YS.60 old but strong and it can scream.
OS.90
These I have.
Or is there something else.?
Dollars count but will not rule the situation,,,Power and RPM's make the MIG move.
Thanks in advance for your input,
Bob
RC  GOLF is offline
Old 03-10-2007, 09:59 PM
  #41
mylamo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The old OPS .40 was a good all around sport engine
but mine got a boat sleeve ( 190 deg. ) and nitro pipe.
I found out that it also needed an RPM rod.[]
Ralph
mylamo is offline
Old 03-10-2007, 11:57 PM
  #42
Crazy4Flight
Crazy4Flight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
about the same proportion and location of a Quickie 500
Crazy4Flight is offline
Old 03-11-2007, 12:31 AM
  #43
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mylamo
Ralph
That's a hard way to find out... but it's the best way... You probably won't make that mistake twice...
As for the Mig 15 three posts up: turbines are getting rather cheap these days: anything designed around a .90 size fan engine will do very well a on Wren 54 or even a 44 if you want scale flight performance.
I love the sound of a high strung two stroke, but for a jet, it just doesn't work...
Rudeboy is offline
Old 03-13-2007, 06:56 AM
  #44
RC GOLF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the scoop on the wren 54-44 I'll check into it I am 0 knowledge onn turbines.
For now I want to be nostalgic and build it with a two stroke just to do it right this time.
what are your thoughts on appropriate two stroke..
RC  GOLF is offline
Old 03-13-2007, 12:54 PM
  #45
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
The Nelson engine is a more modern engine and thus outperform all OPS and Picko engines.
jaka is offline
Old 03-13-2007, 06:03 PM
  #46
Lomcevak Duck
Lomcevak Duck's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Did you all notice the size and location of the aileron on those things?
Doesn't take much surface area to control a plane at 200+
Lomcevak Duck is offline
Old 03-16-2007, 08:46 AM
  #47
The Internet Killer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Internet Killer is offline
Old 10-14-2011, 03:18 PM
  #48
summerwind
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sorry to bring this one up, but since all the OPS related info is posted here, why start a new thread right?
anyways,
i'm looking into the purchase of the OPS .60 Super SPP VAE that is pictured below.
i know it is timed for running pipe and small high pitched props, but for our purpose (Free Flight competition)..........does anyone know if it would be capable of turning 11.5" x 4" CF props at around 20,000rpm?
summerwind is offline
Old 10-14-2011, 07:08 PM
  #49
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That engine is meant to turn at much higher RPM than 20K. These engines are inefficient for anything flying under 180 mph, even better used on a ship well over 200. An 11.5 X 4 prop, if it could turn where the engine makes power, would have it's tips supersonic. Very bad efficiency, noise and could shred even a carbon prop from centrifugal forces on a 11.4 diameter prop with a shallow pitch.
Wrong tool (engine) for the job.
freakingfast is offline
Old 10-14-2011, 07:13 PM
  #50
summerwind
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: freakingfast
That engine is meant to turn at much higher RPM than 20K. These engines are inefficient for anything flying under 180 mph, even better used on a ship well over 200. An 11.4 X 4 prop, if it could turn where the engine makes power, would have it's tips supersonic. Very bad efficiency, noise and could shred even a carbon prop from centrifugal forces on a 11.4 diameter prop with a shallow pitch.
hmmmm, i guess the whole Free Flight community should have you there....we run 40's with 10x4's at over 23,500...............duh so you really didn't answer the question at all.....just speculation..............[:-]
a simple answer is all that is needed, but if you have no clue, then please leave speculation out of the subject....thx
picture below was with older rossi .65 swinging 12x4 at 19,500............guess we didn't know better then too
Reply
Display Modes
