Diamond Dust Carbon pushrods???
Reply
Old 02-06-2007, 03:34 AM
Xardas26
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Diamond Dust Carbon pushrods???
What kind of carbon tubes do u guys use instead of the heavy 4-40 pushrods?? What type of couplers do you use and how do you glue it in the carbon tube?? Questions over questions, i know, but my maiden flight is coming up soon, and I wanna make sure my D-Dust survives it. The Rossi 46 with a Macs Tuned Pipe is a screamer, it's gonna take a toll on her.
Xardas26 is offline
Old 02-06-2007, 10:23 PM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Diamond Dust Carbon pushrods???
Check out [link=http://www.darrolcady.com/]Darrol Cady's[/link] store... he carries a lot of the fast stuff. Click the C/F pushrods link. Nice guy to deal with.
Rudeboy is offline
Old 02-07-2007, 10:09 PM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The factory DD 4-40 push rods are fine and weight at the rear is what you need. The DD should balance on the high spot formed by the two main spars when you set the plane on a flat surface. You do need to stiffen the rods if the DD will see high speed/ high torque servos. I epoxied short lengths of .156 OD X .093 ID carbon tubes around the push rods leaving 1"on each end bare.
freakingfast is offline
Old 02-07-2007, 10:44 PM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used CF tube and titanium ends, for my whiplash, from Art's hobby, but he closed shop. I glued the ends in with Loctit Hysol 4692. you can look for these at:
http://www.dreamworksrc.com/catalog/
Crazy4Flight is offline
Old 02-07-2007, 11:10 PM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As for the ends of the push rods, one end has the factory rolled 4-40 thread and the other end needs something after you glued the carbon tube on.
Hobbie shops carry "solder on clevis" and work fine if you do it right. First sand the end of the rod and make it bright, then clean it with alcohol or acetone. Now "tin" a thin coat of solder in the area were the clevis will go, this helps to wick in more solder later when you solder the end on. The push rod should be in to the clevis so far as that you can get some solder on each side of the clevises solder body as long as it won't interfere with the servo arm throws. Don't use a die and thread the end because the major thread diameter will be too small and may pull out any clevises you use (unless you thread and solder).
Old 02-08-2007, 02:36 AM
Xardas26
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you guys!!! I just ordered a C/F pushrod set from centralhobbies:
http://www.centralhobbies.com/contro...e/pushrod.html
Xardas26 is offline
Old 02-08-2007, 07:06 PM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup, that will work. $$$$
Make shure you get the CG right and plenty of up eleveron (high rate). If you have a dead stick with a full fuel tank you'll need every bit of it.
