Flap setup for patriot xl
Reply
Old 02-06-2007, 02:23 PM
le fou
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Flap setup for patriot xl
Hello,
I am finishing my patriot xl and I am trying to setup my flap servos. I am using a Y connector and I was wondering if anybody could post pictures of their setup - how the servo arms are connected to the flaps. I think that I didn't mount mine correctly...
Thank you,
Le fou
le fou is offline
Old 02-06-2007, 07:44 PM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Flap setup for patriot xl
Are you using four servos in the wing....two for the ailerons, and two for the flaps ?
FBD.
Flyboy Dave is offline
Old 02-06-2007, 08:30 PM
le fou
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, and since my receiver has only 8 outputs, I need to use a Y connector for the flaps. Do you have any pictures of your setup?
Le fou
le fou is offline
Old 02-06-2007, 09:19 PM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They just mount like the aileron servos. You can mount them straight onto the
wing....make some nacelles to cover them....or bury them into the wing.
These are on my Ultra Stick, a very simple flap set-up.
FBD.
ID:	615403   Click image for larger version
ID:	615404   Click image for larger version
Old 02-06-2007, 11:28 PM
le fou
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flyboy Dave,
Thank you very much for the pictures. My problems is that the way I mounted the servos (and using a Y connector) made the flaps move like my ailerons instead of moving in the same direction.... I changed the arm on one of the servos but now I have different displacement and velocity on my flaps... Do you have any ideas on how to resolve the problem?
Thanks again,
Le fou
le fou is offline
Old 02-07-2007, 12:10 AM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look at pic #2....see how the linkage pulls from straight on....when the servo is actuated (flaps)
the arm moves to a 90 degree position. This gives me about 45 degrees of flaps. (I never measured
it)....both flap servos move the same way....there is no need for special reversing switch's or
anything. Do you see what I mean ?
Dave.
Old 02-07-2007, 11:37 AM
le fou
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flyboy Dave,
I understand waht you mean but I am not sure that I am explaining my problem correctly. I will take some pictures when I am at home to make things easier to understand.
Le fou
le fou is offline
Old 02-07-2007, 12:26 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can use a reversing Y harness to reverse one servo ......
Or since this is for landing flaps only.... you can probably get away with just swapping the servo arm to the other side..... the deflection offset is not enormouse.
bob27s is offline
Old 02-07-2007, 10:11 PM
le fou
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I swapped the servo arm to the other side and I followed the setup as illustrated in your pictures and it works
Thank you for your help,
Le fou
le fou is offline
Old 02-07-2007, 11:27 PM
Flyboy Dave
My Feedback: (21)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
....[sm=thumbup.gif]
....good luck with the plane.
