Jett fuel consumption
Reply
Old 02-16-2007, 06:23 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Jett fuel consumption
Hi,
is there a fuel chart for the Jett engines (sx 50, 60LX, 90LX)?
I am always searching for data when choosing an engine/ fuel tank/ for a project
Right now I want to find info on how much fuel the 60LX needs for full power run for 10 a min flight
Thanks for the info,
V.
vasek is offline
Old 02-16-2007, 10:42 AM
Cyclic Hardover
Cyclic Hardover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Jett fuel consumption
Too many variables to get accurate numbers. I have a 20oz in my 60size Ultra Sport with a Jett90. Not that I need it but I like having plenty of fuel.
Cyclic Hardover is offline
Old 02-16-2007, 10:44 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nope, there is no chart.
The 60LX burns just about the same fuel at full throttle as the 428 engine. With a 8.8x9 prop, roughly 19,000 rpm, figure on 1.5 oz per minute. We can typically start, launch, fly for about 4 minutes total on a 6oz fuel load in the Q-500 - that would be letting the tank run dry (usually you want to shut off before that).
Bubble-Jett or Tetra bubble tank will give you the best fuel usage for a given size tank, since you can use 100% of the available fuel. Conventional tanks - consider 20% of the fuel capacity as un-usable fuel (foam/air/lean danger zone)
On the 60LX, throttle back a bit when possible (starting, take-off, turns, downlines, etc) and you can get a bit more air time. So for 10 minutes of typical sport flying operation (start to shutdown) you can get away with a 12oz-14oz tank.
SJ-90L burns just about 1.8 oz per minute at full throttle.
90LX burns about 2 oz per minute at full throttle.
SJ-46 and SJ-50 with the standard jett-stream muffler (stock piece) burn closer to 1.3 oz per minute.
Just as a reference here ---- your milage (minutage?) may vary
bob27s is offline
Old 02-16-2007, 11:55 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks BOB, that means a 18oz for my LX60 sounds just about right
V.
vasek is offline
