Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
juno rc f-20 tiger shark
Old 03-02-2007, 12:04 PM
dragonfly24_24
dragonfly24_24's Avatar
Default juno rc f-20 tiger shark
i just recived a juno rc f-20 tiger shark and from what i can see the spars are balsa i do not see any hard wood for them can some one help.[sm=spinnyeyes.gif][sm=spinnyeyes.gif]
Old 03-02-2007, 11:59 PM
setxws6
setxws6's Avatar
Default RE: juno rc f-20 tiger shark
If you're talking about wing spars, there should be any because it's foam core with balsa sheeting.
Old 03-03-2007, 08:03 AM
dragonfly24_24
my juno rc f-20 is a built up wing.
revver bro #174
Old 03-03-2007, 09:18 AM
dk823
Dragonfly,
What you have is correct. The spars are balsa. No need for hardwood. However, as stated in the instructions...............glass the center section with 6 oz. cloth and resin. I like Z-poxy b/c is sands so easily, but you can use whatever you need.
Setxws6,
The Juno R/C kit has no foam. Perhaps you are thinking of the old DC kit (ARC version) which did have a foam wing.
Old 03-03-2007, 04:05 PM
dragonfly24_24
thanks dk823
Old 03-08-2007, 12:26 PM
setxws6
setxws6's Avatar
[:'(] euuuuugh, another reason I'm sad to see the SA F-20 go away....
Old 03-08-2007, 05:45 PM
john d in texas
Will an K&B .61 fit in the plane or is it to big...
Old 03-09-2007, 07:56 AM
fred685
My Feedback: (67)
Dragonfly,
Looks like you have the trailing edge shim in backwards. You're building wash in instead of washout. I built one of these last year and found the directions are wrong. I told Juno and he knows about the problem. Change it if you can before you finish.
Old 03-09-2007, 08:43 AM
dragonfly24_24
I dont think its going to matter anyway the guy who gave me the kit lost some very important stuff out of the kit. most of the formers for the fuse. i am missing about 8 formers i am going to see if i can cut them out but i have not had sucsses in the past with cuutting parts from scratch.
Old 03-09-2007, 12:31 PM
dk823
Dragonfly,
Send me a PM with the formers you are missing. I can supply you with them.
Derek Staha
Juno R/C
Old 03-09-2007, 12:39 PM
dk823
John D,
The engine compartment is approximately 3-5/8 x 2-1/2 x 2 (lengthxwidthxheight). Does this help?
Derek Staha
Juno R/C
Old 03-09-2007, 04:36 PM
john d in texas
Derek, It looks like it will fit, Fixin to order one from you. Thanks, John D...
