Enforcer No More!
Reply
Old 03-17-2007, 04:20 PM
webtech
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Enforcer No More!
It's a sad sad day for me. Just lost my Enforcer. I just finished putting in a bubbless tank and did some rolls and inverted flying to see how much better the new tank fed fuel into the engine. It was working beautifully. I did some loops and rolls and took her way up high for a steep split s dive. As I was pulling out of the dive the elevator popped off and she lawn darted straight into the ground at full speed. Not even a screw was salvagable. Absolute confetti. The wood was buried at least 8 inches into the ground. Shoulda heard the applause. So I took some pics (will post soon) and played taps. Time for the new and improved Byro Enforcer to be built! C ya in a few months bois!!!!
-Webtech
webtech is offline
Old 03-17-2007, 08:05 PM
TEAMERICA
My Feedback: (77)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Enforcer No More!
Our thoughts are with you.[]
TEAMERICA is offline
Old 03-18-2007, 09:49 AM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why did it pop off ? What kind of hinges did you use ?
Strykaas is offline
Old 03-18-2007, 10:43 AM
rcplaneworld
rcplaneworld's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats why I pin my hinges, I dont own a plane with the correct recomended size engine!
rcplaneworld is offline
Old 03-18-2007, 10:23 PM
rmenke
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys:
The culpret here, I will bet, is that a knife was used to cut the covering from the tailfeathers in the typical fashion as needed with arf's. Even with care, a week spot is created in the surface fibers that either over time or immediately fail when stressed. Try using a 20-40 watt soder iron and metal streight edge. With less care, you can get the covering off the desired area without damage to the structure. I have done the same thing and when I saw the iron tip, wondered why I never thought of it. Do not use a iron with a very sharp edge, or you will now burn the surface rather than just remove the covering. ENJOY
rmenke is offline
Old 03-18-2007, 11:41 PM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Enforcer doesn't have tailfeathers... It's a delta.
And as far as I know, it's not offered in ARF form either...
Other than that, you're absolutely right. The soldering iron thing works. I also use it to finish the covering around hinge slots: set the iron hot enough to melt the covering, slit the covering over the hinge slot with a sharp blade, use the soldering iron to open up the slot and seal the edges in one go.
It is also a great way to make holes in shink covering for servo output splines (like on a Dust for instance). Trying to cut a neat hole with a knife or a die is an exercise in futility.
Rudeboy is offline
Old 03-19-2007, 10:32 AM
webtech
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your right RudeBoy, the Enforcer is a kit and I should have reinforced the elevator better. Since it uses a pusher prop the air is pushed directly over the elevator and there is a lot of vibration. A learning experience to be taken into my next Enforcer 2.0!
webtech is offline
Old 03-31-2007, 04:45 PM
webtech
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry, but I forgot the before and after pics... I took these with my camera phone, so the resolution is not so great!
ID:	653813   Click image for larger version
webtech is offline
Old 03-31-2007, 09:31 PM
ArmedZagi
ArmedZagi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice! Around here when someone describes there plane as confetti its generaly an exaguration.. not this time
ArmedZagi is offline
Old 04-01-2007, 03:19 PM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Web,
did you lose the whole elevator? elevator clevis? or elevator with the trailing edge?
Enforcer 2.0 you might consider running elevons mix on your ailerons and a center elevator.
Crazy4Flight is offline
Old 04-04-2007, 08:44 AM
joeflyer
My Feedback: (47)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rocky,
Sorry to hear about your Enforcer. I've had good luck with Hayes Polypropylene Hinges on both of my Enforcers. http://www2.towerhobbies.com/cgi-bin...?&I=LXK840&P=7
Joe
joeflyer is offline
Old 04-17-2007, 08:27 PM
webtech
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Joe,
Thanks for the link on the hinges. I will definitely use them. Can't wait to finish and fly the new enforcer.
-Rocky
webtech is offline
Old 04-17-2007, 08:34 PM
savage haley 14
savage haley 14's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ouch that looked like it could hurt
savage haley 14 is offline
