ultra thrust mufflers
Reply
Old 03-19-2007, 11:07 AM
BigBadJon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ultra thrust mufflers
is it better to go with a ultra thrust sport muffler or a ultra thrust plyon muffler on a rossi 53 thats going into a prop jet?
plyon http://shop.vendio.com/RossiEnginesU...897/index.html
sport http://shop.vendio.com/RossiEnginesU...895/index.html
BigBadJon is offline
Old 03-19-2007, 11:17 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ultra thrust mufflers
John,
You would want the sport muffler. The pylon one is only effective at higher rpms than would be practical on your Rossi.
Also, go to www.pspec.com and save some money over the site you listed.
daven is offline
Old 03-19-2007, 02:15 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't beat me up for asking the following question!
The Tower Hobbies muffler looks very similar in design to the UT muffler. How similar is the performance?
ID:	645347   Click image for larger version
Kmot is offline
Old 03-19-2007, 02:21 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Geesh, what a stupid question Tom!
I like the Tower muffler myself but the Ultrathrust does yield better performance, about 800 rpm's in my book. Not sure why... Bob?
Razor-RCU is offline
Old 03-19-2007, 04:33 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Ultrathrust is tuned, the tower muffer is not.
Many have said that the Tower muffler does tend to increase rpm over stock mufflers, but not nearly as much as the ultrathrust.
daven is offline
Old 03-19-2007, 05:56 PM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We did some testing of the Tower vs UT on a TT 46 Pro a couple of years ago. The Tower did give close to 1000 rpm increase but the UT gave almost 1500 rpm increase. The Tower is cheap but it was not uncommon to lose the back half in flight.
Mike Connor is offline
Old 03-19-2007, 06:46 PM
proptop
My Feedback: (8)
proptop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The way I understand it, or at least I think I understand it is...
The U-T is a tube within a tube, right? The exh. pulses go back, then bounce fwd. then back again and out, correct? It's kind of like a compact version of a tuned pipe. (what is it, a half wave, or ???)
The Tower is an empty chamber that just happens to be the correct size and configuration to provide a tuned effect on engines of around the .40-.50 displacment.
proptop is offline
Old 03-19-2007, 07:13 PM
Ed_Moorman
Ed_Moorman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are correct about the Ultra Thrust. Here is a photo of one I cut apart after I broke the mounting ear in a crash.
The Tower muffler is a large, expansion chamber that gives a good bit of tuning. I have gained 800-1000 rpm on .46-.52 siezed engines. You can gain 1500 rpm or more with an Ultra Thrust provided you use the correct size prop. The Ultra Thrust, and the Jett, which is similar, are cut to length for a fairly high rpm range. You need to use a prop that lets your engine run at that rpm. Generally, they need to turn a minimum of 13,500-14,000. You can definitely hear when they stage on the pipe.
ID:	645504   Click image for larger version
Ed_Moorman is offline
Old 03-19-2007, 08:53 PM
BigBadJon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Already have a plyon muffler for it, but will order a sports muffler if needed. i just got the engine. but anyone got any ideas for a plane and a prop size to run the rossi 53 with plyon UT muffler?
Old 03-19-2007, 09:40 PM
KC36330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
8.8x8.75 APC Pylon would get you into the RPM range to benefit with the pylon muff and will give some impressive speed on the right airframe.
kc
EDIT: make sure you get the APC is a 'D' hub (thicker for the higher RPM), the Pylon series are.
KC36330 is offline
Old 03-19-2007, 10:17 PM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Ed_Moorman
Wow... the Tower sounds good... you can gain 1000 rpm with this thing on a seized engine...
Rudeboy is offline
Old 03-19-2007, 10:27 PM
Julian537
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make sure you do not use more than 5% nitro in that rossi, or you will have all kinds of tuning problems!!
Julian537 is offline
Old 03-20-2007, 04:58 AM
proptop
My Feedback: (8)
proptop's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the pics Ed [sm=thumbup.gif]
Hey...about how thick is the casting? Specifically the area where, oh, let's say a Q40 typically grinds down when it noses over on landing? My guess would be about .060 or so or maybe a frog hair more?
proptop is offline
Old 03-20-2007, 09:02 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The ultra-thrust and jett-stream mufflers are very similar. These are both tuned exhaust systems, and include porting and internal geometry that basically make them a 1/4 wave tuned pipe. Part of the design consideration is the gas velocity and backpressure - which is why these mufflers have carefully sized exhaust outlets, and great consideration is given to the muffler/tank pressure fitting location. Most importantly, they are assembled as a one-piece unit, and neither of them is going to come apart.
Both the Jett-Stream and Ultra-thrust mufflers are available for different rpm ranges (different applications) and of course various sizes and types of engines. As example, the standard Jett-Stream .46 size muffler will boost a TT40, 46 or OS 46FX by and easy 1300-1700 rpm on a 10x6 prop. Target range for this muffler is 14,500 up to 17,500 - with the best boost in power noted over 16,000 rpm. Jett also offers a similar muffler, tuned for about 1000 rpm lower for slightly bigger props, and the SS or LX muffler tuned for 1500 rpm higher for smaller props. (from my test notes, the OS46FX ran between 14,100 and 14,300 with a 10x6 and stock setup - with the jett-stream it ran from 15,800 to 16,000)
The tower muffler is similar in external appearance, but does not have the same internal design consideration or gas flow path. However, it does has demonstrated an 'inadvertant' tuning effect none the less, and aside from the through bolt it is a fairly well designed muffler. Boost of around 800 rpm is common. A bit more on smaller props. The tuning effect for this tends to be right around 15,500 rpm - and can boost up to around 16,000. So if you use this muffler for the Tower 46, or other engines, and prop for something 15K or higher, the muffler does kick in and can give you a few hundered rpm boost (as opposed to a shell and baffle type muffler).
Bob
bob27s is offline
Old 03-20-2007, 12:17 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the excellent info about the differences in these mufflers.
Kmot is offline
Old 03-20-2007, 12:32 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was gonna post that but I don't have time since I am at work- [X(]
Old 03-20-2007, 04:24 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Razor-RCU
it took most of my lunch time
bob27s is offline
Old 03-20-2007, 04:26 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
9am lunch
daven is offline
Old 03-20-2007, 05:27 PM
DHG
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, would you look at that -- it's lunch time AGAIN!
Bob,
I'm curious about how critical the placement of the pressure tap is. On a double-tapered ( "full" ) pipe I put it at the widest point, or sometimes right on the exhaust stack next to the engine. Either way seems to work, although I've always assumed the wide point gives the highest & most stable pressure. Do things get spookier with a folded pipe? For example, are there places on the exhaust stack that work better than others?
Mr. Part-Time Resonant
DHG is offline
Old 03-20-2007, 06:05 PM
Happy Feet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you take a flight from the east coast to the west, you could have a 4 hour lunch!
Happy Feet is offline
Old 03-21-2007, 12:41 PM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Duane,
the pressure placement is not super critical, but there are a few places where the pressure is "higher". Mainly the pressure location has to do with the structure - where you can tap for the fitting. Turns out that is a higher pressure, lower velocity area anyway.
bob27s is offline
Old 03-21-2007, 03:22 PM
DHG
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob,
Thanks, that's reassuring.
Duane
DHG is offline
