antenna position for Patriot XL
Reply
Old 03-19-2007, 01:50 PM
le fou
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default antenna position for Patriot XL
Hello,
I am finishing my patriot xl and I mounted the receiver in the tail of the plane. The manual suggests to route the antenna towards the front of the plane. which I did. When mounted that way, the antenna has to be slightly routed in a circle in towards the front of the airplane. I will post a picture tonight. How are the other patriot xl owners mounted the antenna? Can you post a picture?
Thanks a lot,
Le fou
le fou is offline
Old 03-19-2007, 06:45 PM
kamakazie frank
kamakazie frank's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: antenna position for Patriot XL
Le Fou:
Follow the instuctions........you can't go wrong. Routed the black nyrod tube right up the side of the fuse from the receiver made a U turn and down a couple of inches. Works great!
Frank
ID:	645468   Click image for larger version
ID:	645469   Click image for larger version
kamakazie frank is offline
Old 03-19-2007, 07:00 PM
KC36330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dean's Whip Antenna = EZ installation
kc
KC36330 is offline
Old 03-20-2007, 07:44 PM
le fou
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kamakazie Frank,
Thank you for your pictures. I have a question about the tank setup, I was thinking to od the same thing but where can i find a bigger clunk for my tank as well as the fuel tubing? Any suggestions for the tank modification?
Le fou
le fou is offline
Old 03-20-2007, 10:43 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Frank, Pimp Patriot dude...That is sweet!! I dig the Hots also
Razor-RCU is offline
Old 03-21-2007, 05:55 PM
kamakazie frank
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Le Fou:
The biggest problem with the Patriot XL is it's main gear setup...............a little too far too the rear. A lot of weight sets on the nose, especially with a large tank forward full with fuel. With the tank forward she takes a lot of runway and speed to rotate when it finally does she jumps off the ground.
I don't know what you are looking for in the way of modifying your tank setup but what I have there as you can see is a 16 oz Hayes tank on the CG with a 4 oz header tank in the nose. I used the large fuel tubing feeding the 16 oz tank and standard tubing to the engine from the header tank.
Frank
Old 03-21-2007, 06:02 PM
kamakazie frank
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Razor:
Thanks for the compliment on both ships. That Hots is my favorite all around ship!!
I built that from the original kit..........one of my club members had it in his attic for 15 years and it took me one year of haggling for him to sell it to me...........lol.
Great flying.............fast ship!
Frank
ID:	646869   Click image for larger version
Old 03-21-2007, 07:16 PM
le fou
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kamakazie frank,
Thank you for your reply. So, you are not using a bigger clunk in the 16 oz. fuel tank? How did you mount the 16 oz. fuel tank? Did you build a special "bed"? Why are you using the header tank and not a direct feed to the engine?
Thank you very much for your help,
Le fou
le fou is offline
