JETT 90L feul pump?
Reply
Old 03-24-2007, 06:51 AM
smoknrv4
smoknrv4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JETT 90L feul pump?
I have a BSE JETT 90L in my Patriot XL, I know Jett doesn't reccomend a pump but what one would somebody reccomend if I was to use one on my plane?
smoknrv4 is offline
Old 03-24-2007, 08:41 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: JETT 90L feul pump?
I'd recommend a Tettra Bladder Fuel Tank before going down the pump route.
daven is offline
Old 03-24-2007, 09:49 AM
Mods-R-Me
Mods-R-Me's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: daven
I second that. I'm using a Jet 0.90 for the Modkat and my bubbless tank is 10" away for the engine (ran on test stand). I thought it wouldn't work too but the bubbless tank requires very little pressure in comparison to regular tanks to operate efficently.
Mods-R-Me is offline
Old 03-24-2007, 10:04 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The fuel system pressure developed by the jett-stream and turbo-jett mufflers, combined with their balance backpressure make a pump unessecary for 98% of model applications.
The Jett carb does not work well with a perry pump. Rarely works with the Cline or IronBay regulators too (little suction demand).
Its not impossible, it can work with the Perry, but it takes a bunch of work on the test stand to get things set up. Unless you are ready to commit at least a couple of hours of bench time to setup of the system before installing it in the aircraft - AND you 100% know how to adjust both the engine AND the pump.... its not going to work.
Underlying thing is..... a pump is very rarely necessary. Especially on the 90L engine. Folks whol have tried (and failed) to use a pump with this engine all had underlying fuel system problems, and the pump doesnt fix those - in most cases it makes the problems worse.
Alternatives...
The bubble-free fuel system is a first step. Works great, as others will attest to. Eliminates 90% of most fuel system issues by design. The other 10% of problems are easy enough to deal with.
If it is a situation where you want to relocate the tank - carefully consider why you want to do that.
If it is for adding fuel capacity... or installing a larger tank - go this route. Use a small hopper tank right at the firewall, fed by the larger main tank, is the way to go.
There are a few threads on here about the bubble-tanks and the hopper tank setups. Look back in the forum threads.
Bob
bob27s is offline
