Dia Dust CG in inches?
Reply
Old 03-25-2007, 08:47 PM
stnick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dia Dust CG in inches?
Thanks for the previous replies but I need the CG measured from the trailing edge. Please indicate if your measurement includes the aileron or not.
stnick is offline
Old 03-25-2007, 11:37 PM
KC36330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Dia Dust CG in inches?
13.5 inches from the trailing edge of the dust, ailerons NOT included. you might wanna go with 14-14.5, most people who have tried, can't fly mine.
kc
KC36330 is offline
Old 03-26-2007, 12:35 AM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: stnick
The instructions call for 14 1/4" thru 15 7/8" from the trailing edge of the wing, not elevons. Mine few best when balanced at the most aft position which is also on the front spar. I ran out of elevator with the forward cg setting while landing. They tend to come out nose heavy with a 40 size engine. If you can find the front spar just balance there or just in front of it and you will be in the limits of the plans.
Mike Connor is offline
Old 03-26-2007, 01:49 AM
KC36330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Mike Connor
.................They tend to come out nose heavy with a 40 size engine.
only when used with a side exhaust and the 'stock' type muff, rear exhaust with a pipe line mine balanced just about perfect according to your by the plans location with the Jett 60LX, i used a 750 mAh NiMh to get it on back where I've got it at.
kc
KC36330 is offline
Old 03-26-2007, 10:22 AM
Mike Connor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: KC36330
only when used with a side exhaust...
kc
Despite my efforts I still had to add 2 oz of lead for a decent balance. I was happy with the MT weight of 2 lbs 12 oz though.
Old 03-26-2007, 01:20 PM
mfracer@itctel.com
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also laminate your motor mount to 1/4" & cut motor back 3/8" that really helps the balancing.
Move flat battery pack all the way back behind rear spar.
I agree a tuned pipe makes balancing easier than a side mounted muffler.
Mike
mfracer@itctel.com is offline
