Now I'm ready for some speed..
RE: Now I'm ready for some speed..
ORIGINAL: combatpigg
MJD, how much vibration does your motor put out? If I had one of those, I'd head out to eastern Washington's high desert and find 50 square miles with nothing around. Up where you live it shouldn't be too hard to find some place to light it off, just keep driving North .
They all shake pretty good, in this case probably about like a hard mounted one-jug gassie at 9000 rpm or thereabouts. I don't think the transients are too severe, but I'll look to see what I can find on that topic. I haven't heard of radio problems in the write ups of the various pulse jet RC projects I've read about. Naturally I will pad the Rx and battery very well in low durometer foam, and they will be very firmly restrained in their own compartment with no room to move about.
I do note that the MAAC turbine rules do not allow IV bag fuel tanks (d***it).. so presuming the same applies here I will have to make a fuel cell with bladder. Or I might try a clunk type fuel cell with a BVM air trap. I plan on 1 - 1.5 litres of fuel, there are BVM fuel cells available I could use. Or maybe 4 Jett 12 oz bubble-free tanks in parallel. All such problems can be overcome, just add money..
MJD
ORIGINAL: MJD
They all shake pretty good, in this case probably about like a hard mounted one-jug gassie at 9000 rpm or thereabouts........
you mean about 2000 RPM?? gassers smooth out at RPM, it's idle where they shake.
kc
ORIGINAL: KC36330
kc
ORIGINAL: MJD
kc
#31
My Feedback: (13)
CA
Well, here we go again, no pic in the box as its supposed to be, but pic uploads with a message. Now, how do you get a series of pics in this same box?
#33
ORIGINAL: Ed Smith
MJD,
When you fire this project up let me know. I want to be there.
Ed S
MJD,
Ed S
The safety code for turbines includes a few things:
- no IV bag tanks (prone to rupture in a prang)
- two means of shut off required (throttle command to the fuel pump plus a manual shutoff in the fuel system will do)
- externally mounted engines must not touch the ground in the event of belly landing or a retract failure, i.e. put the engine on top
The IV bag tank thing is a pisser, because it's a great way to get a lot of fuel on the CG via two compartments near the wing root. Oh well, I'll have to buy or make a 1.5 liter fuel cell and fit it in there somehow.
I'll screw an old propellor to the nose to qualify it for this forum..
#34
half inch boat prop will have the least drag
Way to go
possibly next year will do pulse
The price of turbines is just toooo much
I can drive into stickville which each year gets more empty as everybody leaves the land top go live in big towns and mostly fly guerilla style set up fly and find a new spot the next week so spreading the noise print around and i can do a pulse for a lot less as even at eu prices of $6 a gal takes a lot to use up $2000 in gas prices
no chance any club can take the 150db more than 1 time a year if that
No issues to use pulse in EU generaly in the stickvile but problems noise ristricions close to habitation and pulse still very popular pre turbines and sure the tubine guys still use them occasionly
Spain big issues forest fires so lots of clubs wil have no turbines and pulse for fire risk in summer time
No issues to use bladder tanks in planes
keep us posted on this motor and might get one next year as not to many manuftuers out there
The throttle bit is unusual but not realy interesting feature for me
keep me posted on how much work to keep petals working and replacement rates or similar
What is the best way to make a wand that you know
Balsaeater
Way to go
Balsaeater
#35
ORIGINAL: balsaeater
Balsaeater
Balsaeater
The throttle is mandatory, because you feed it with a turbine fuel pump with speed control. You need to be able to set the maximum flow rate to the manufacturer's specification and make this the 100% throttle setting.
I will know about reed valve life once I start using the motor regularly.
The only makers I know of for large pulsejets are Zanin in Italy and the company making this Maxjet.
MJD
