Shark 21
Reply
Old 04-03-2007, 11:55 AM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Shark 21
I am building a new fast model the Shark 21 with 115cm wingspan.
Engine Nova Rossi 21 with 2,4 HP and a muffled rear exhaust.
Wing is sheeted with 0,4mm thin plywood.
With an OS 32SX this model was very fast with an APC 7x6 wide prop.
Motormount CNC alu.
look is offline
Old 04-03-2007, 01:38 PM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Shark 21
Engine Nova Rossi 21 2,4HP
ID:	656153   Click image for larger version
look is offline
Old 04-03-2007, 01:39 PM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
CNC alu mount and spinner Tru Turn 1,75 inch:
look is offline
Old 04-03-2007, 01:41 PM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wing, stab and fuse:
ID:	656157   Click image for larger version
ID:	656158   Click image for larger version
ID:	656159   Click image for larger version
look is offline
Old 04-03-2007, 01:44 PM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wing is sheeted with 0,4mm thin plywood reinforced with glasscloth.
Stab is sandwhich 0,6mm plywood and 2x 2,5mm balsa.
Stab needs to be sanded in airfoil shape.
Now I can glue in the wingspar from 3mm plywood.
look is offline
Old 04-03-2007, 02:25 PM
RANIERY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
do you have the web page for that plane?
RANIERY is offline
Old 04-03-2007, 03:11 PM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
www.speedmodels.nl
look is offline
Old 04-08-2007, 05:12 AM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice
What is your pipe setup ?
Strykaas is offline
Old 04-08-2007, 07:04 AM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Do you mean the length ?
I use a S- shape header from Nova Rossi and a muffled Rossi tuned pipe.
At the moment wing and stab are ready for glassing.
Yesterday I have put in the middle of the wing some glasscloth.
I hope to paint the model in a week.
Happy Eastern !!
look is offline
Old 04-08-2007, 01:05 PM
Electric Delta
My Feedback: (13)
Electric Delta's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's a nice looking airplane! The fuselage looks like the Stinger 21/40, is it the same? I have a Stinger 40 waiting to be built, I can't decide whether to put on a Nelson Q40, Jett .50 or West .50.
Electric Delta is offline
Old 04-08-2007, 02:00 PM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, it is based on the Stinger 21.
Both come from the Stinger 40.
I have scaled down the Stinger 40.
The Shark is also made for electric.
It has an opening for cooling on the front.
I have designed the Stinger 40 for a Nelson FIRE.
It flies very fast, use 3mm rods for the Aileron or 4-40.
It my first flight 2mm steel was broken on one aileron.
I was lucky the engine was running rich.
Regards,
Look.
look is offline
Old 04-08-2007, 02:37 PM
fly4food18
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how did you get that engine? I am looking for the same engine with side exhaust.
Can you help?
Brian
fly4food18 is offline
Old 04-08-2007, 02:44 PM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ordered in USA by Performance specialities.
The Q (side) has less power.
Why not a rear exhaust ??
Regards,
Look.
look is offline
Old 04-08-2007, 03:10 PM
Electric Delta
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Stinger (and Stiletto and Kasumi) wings appear to be sheeted with abachi wood; how does the 0.4 mm plywood compare for weight and strength? Seems like it might be heavier, but then again maybe also smoother for less sanding and filling, and possibly more torsional stiffness. Thanks for the tip on the linkages. I would have used 2-56 (slightly larger than 2 mm) otherwise. I guess plastic clevises are also a bad idea, but 4-40 metal clevises or plastic ball links ought to be ok. I also was unaware that Performance Specialties was carrying the Novarossi engines.
Old 04-08-2007, 03:49 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok look, it was the pipe brand. This is hard to find stuff btw...
Strykaas is offline
Old 04-08-2007, 10:00 PM
fly4food18
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The plane i am going to put it on would take alot of work to run the pipe. It's easyer just to run Performance specialities tuned muffler.
Old 04-08-2007, 11:21 PM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: look
Regards,
Look.
Look,
You had to order a European built engine through an American company...?! [X(]
There's no way to get these things through a European dealer?
Rudeboy is offline
Old 04-09-2007, 04:12 AM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
@electric:
I think the plastic connectors will hold 1 minute.
Always use steel, thick as possible.
The thin plywood is some more heavy but stronger.
With strong engines I always use the thin plywood.
I ordered the Nova Rossi at Nova Rossi in Italy.
@Strykaas:
You are right.
Modellmotorentechnik.de sells some engines and pipes.
The most stuff you need they have in stock.
Roland Dieterle sells Rossi engines and he can repair an engine if broken.
I think he can advise you to tune up your engine.
@Fly4:
Yes, that is OK.
I did not know they are selling a muffled tuned pipe.
@Rudeboy:
I ordered the Nelson FIRE with Performance specialities and I ordered the Nova Rossi in Italy at the factory.
The second 160 gramms glasscloth has been put on the wing middle
with slow epoxy.
Today I can put some very thin glasscloth (25 gramms) with very thin epoxy on the wing and stab.
I use epoxy for rotten wood.
Regards,
Look.
look is offline
Old 04-10-2007, 08:59 AM
cmopar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have one that im not going to use!
Corey
cmopar is offline
Old 04-10-2007, 09:15 AM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look.
look is offline
Old 04-18-2007, 01:53 AM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing and stab are painted with a 1K base coat.
Next step is adding some black and white racing blocks and the 2k clear coat.
ID:	667024   Click image for larger version
ID:	667025   Click image for larger version
look is offline
Old 04-18-2007, 01:54 AM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sample racing blocks:
At the moment I am painting two models.
look is offline
Old 04-18-2007, 06:35 AM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Black and white ready.
Tomorrow a layer of 2K clearcoat.
ID:	667041   Click image for larger version
look is offline
Old 04-18-2007, 09:50 AM
ArmedZagi
ArmedZagi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats a really sharp looking scheme man...I like
ArmedZagi is offline
Old 04-18-2007, 10:31 AM
look
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you !
look is offline
