Best speed prop for an OS rear exhaust ducted fan engine?
My Feedback: (34)
GA
What prop would give me the most speed on a piped OS46 ducted fan engine pulling a Lykajet? I'm running an apc 9x8 right now turning a little over 13000rpm. The turbine guys at the field think I'm going about 120mph. I'd like to go a little faster. Thanks.
RE: Best speed prop for an OS rear exhaust ducted fan engine?
Hi!
9x8 is way too much prop.Try a 8x6 or 8x7 APC !
13000 rpm is nothing for your engine and 120mph is not that much.
Show us pictures of your plane.
Does "Piped" mean a full tuned pipe or a tuned muffler? As Jaka says 13,000 is nothing, well, it is a sport engine figure. With that engine set up for pipe use and the prop sizes that Jaka recommends the rpm should be in the 20,000 + range.
Believe me, with an 8" pitch prop at 13,000 rpm you are not any where near 120mph.
Ed S
Ed S
