Nitro Planes Falcon 120
RE: Nitro Planes Falcon 120
Has anyone flown the Falcon 120 with a large ST or Moki glow engine? With turbine power the airplane is impressive but turbines are not for me. Older eyes and reflexes no longer allow the desire for speed. Just want to fly something interesting an different.
Bill
Bill
I had the opportunity to fly this plane with a OS 120 2s (not mine). The owner used a MAS 3-blade pusher prop. Sorry, cannot remember size, but I can tell you that the engine was underpropped.
With full flaps (read that as close to 45 degrees), this plane takes off in a 20ft rollout on thick grass (suprised me). Landings with flaps were effortless (did not have to touch controls mush), without flaps require constant throttle management.
Plane does 80-90 mph (guessing) flat and level, vertical was decent to 200ft (rolled off pretty quick after that). Loops were not that good either.
The owner tried retracts (spring air) but they did not work out too well. This was his first time using retracts. He did say that he had to add glue to the landing gear mounts, then he modified them, making them more stout for the retracts. I can tell you this guy likes to build/modify planes to his standard (read that as tanks). I'm sure his version weighs more that the original, but he has not weighed it yet. Just for reference, I have one of his kit built Shrikes and it weighs close to 7lbs
