Patriot=wow!!!!!
Reply
Old 02-26-2003, 09:52 PM
guntop
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Patriot=wow!!!!!
hi all, its a balmy 30 degrees here in sioux falls sd. just got back from the field flying my patriot. i love this plane. everything i have been looking for in a prop jet. speed, looks, retracts and easy landings.(nose high i might add) first flight was going ok then,,,,,,
went up for the second flight, everything good ok, so i sucked up the gear and turned her loose. what a speed demon. well i forgot to repair a minor tear in the monocote on the wing, i was cruising high and fast across the runway and then i hear this rip and a bunch of white pieces went falling to the ground. the plane was still flying. i did a slow pass to observe. the monocote on the right wing(underside) had completely ripped off. since it was still stable i was able to bring it in. learned a good lesson here!!!!
anyway, she is a keeper!!!!!
guntop is offline
Old 02-26-2003, 10:46 PM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default what engine
would like to know what engine pulls your Patriot...
thnx
vasek is offline
Old 02-26-2003, 10:50 PM
guntop
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default patriot engine
i am using the good ol ys 45. she makes the patriot pretty damn quick!!!
dave
guntop is offline
Old 02-27-2003, 12:04 AM
Pinch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a YS 45 with a pipe.
I agree, it really zips!
Pinch is offline
Old 02-27-2003, 05:07 AM
dwsc
My Feedback: (81)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default painting the patriot
you said you painteed the fuselage, did you also paint hte fin and stab along with the control surfaces?
dwsc is offline
Old 02-27-2003, 05:16 AM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Pics?
Need some pics.... I am shooting for the largest collection of Patriot pics in the world-
And no I am not a Trekkie
Razor-RCU is offline
Old 02-27-2003, 11:57 AM
Neil Guildford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
whats one of these like to build?
Also are the retracts strong enough for grass take-off and landings?
Flight times?
Weight?
Finally, would an Irvine 53 fit?
Many Thanks
Neil
Neil Guildford is offline
Old 02-27-2003, 03:46 PM
Pinch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's been a 10 years since I've built it, so I can not recall most.
I built the Great Planes Kit, so it really goes together very nice (i.e. washout for the wings, parts alignment, etc.)
GRASS: I used the hobbio (3) and had problems with take offs on grass. You may want to think about bigger wheels if you don't mind the nose wheel hanging out the bottom a little. I didn't see how I could have put bigger wheels so I installed very hard wheels, which helped. The plastic on the steerable nose wheel broke once and I had to replace it.
HARD SURFACE: It uses a lot of runway to take off, but no problems. I used foam wheels here so that it would slow down better on landing.
FLIGHT TIMES It seem to me that I never got 10 minutes out of it. The bigger problem is running out of sky before you lose it. It's fast.
WEIGHT: I'd need to weight again, but I think mine was under 6 pounds.
IRVINE: I'm not sure. I know the YS 45 was tight - and I had to really modify the plastic spinner to fit over the prop. Maybe an allimunum spinner would have worked better.
Hope this helps.
Pinch is offline
Old 02-27-2003, 07:35 PM
Neil Guildford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pinch
Much obliged for the info.
It sounds like a grass strip could be a problem for take-off as it would need to be very long.
Do you have any ideas on a plane, of this caliber, that would accept a grass runway?
Many thanks
Neil
Old 02-27-2003, 07:49 PM
Pinch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pinch is offline
Old 02-27-2003, 07:52 PM
Pinch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Let me try this again.
I don't have another recommendation - I really like my plane.
The only bad recommendation I can give you would be to not install retracts and put bigger grass wheels on it.
Sorry.
Perhaps you will others who will reply with comments.
Pinch is offline
Old 02-27-2003, 07:58 PM
Neil Guildford
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How long a runway, on grass, do you think it takes?
Old 02-27-2003, 11:33 PM
guntop
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default grass, no problem here
I used B&D retracts and have no problems. they are rock solid.
i am using the ys 45 and my plane got of the ground within 100 feet(estimation)
guntop is offline
Old 03-01-2003, 01:39 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default B&D retracts
grass, no problem here (post # 13)
where can one GET B&D retracts?
they are nowhere to be found...
vasek is offline
Old 03-01-2003, 04:46 AM
Dave Barrow-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a patriot with hobbico retracts that flies off a grass runway. I put 1 size larger wheels than shown on the plans. With a Super Tigre Como.51 10x8 wood prop and Mac's tuned pipe, it gets in the air in 100 feet or less with ease. The only thing I would do different is not to loop the fuel lines like shown on the plans, I had to pull the tank(no easy task after it's built), and reroute them normally. It's a straight forward, easy build. Patriot's fly great, you'll be glad you got one.
Dave Barrow-RCU is offline
Old 03-02-2003, 02:13 PM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default GUNTOP
are your B&D retracts pneumatic or mechanical?
any mods needed to install them in the Patriot?
THNX for helping
vasek is offline
Old 03-04-2003, 12:48 AM
guntop
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
vasek
no mods needed. they are pneumatic
guntop is offline
Old 03-07-2003, 01:24 AM
gtalbot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default B&D Retracts
Tower Hobbies only sells a few of B&D items.
For their full selection, contact them here:
B&D Enterprises
Route 81 Box 7
Ballard, WV, 24918
(304) 753-4636
I took me a few tries to get someone to answer the phone, but when they did, their customer service was superb!
gtalbot is offline
