os 90 df speedplane
Reply
Old 05-17-2007, 09:42 AM
max plank
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default os 90 df speedplane
just got my new plane ready cant wait to get it airborne..
span 130 cm, weigt 2100 grams speed hope fore 300 km/h[>:]
ID:	686184   Click image for larger version
ID:	686185   Click image for larger version
ID:	686186   Click image for larger version
max plank is offline
Old 05-17-2007, 09:53 AM
BBJ
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: os 90 df speedplane
Nice Plane.
BBJ is offline
Old 05-17-2007, 11:12 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, you've got the power... so it should move along nicely.
But I doubt you're going to see 300 from what looks basically like a Novice on steroids.
It is as good a place to start as any though... it should give you a nice platform to explore the characteritics of the OS 91.
Get rid of the APC prop! Too dangerous!
Rudeboy is offline
Old 05-17-2007, 12:06 PM
max plank
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what prop should i use i have not seen any thing other then apc and have been flying that prop a lot whit out problems... i knov its not ideal so any help is welcome.. still hopeing fore 300
Old 05-17-2007, 03:12 PM
Flyer95
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A very smart design indeed. It should go very fast but as been said the apc:s are not strong enough for 15cc DF engines. A carbon fiber prop is the best choice or a strong wooden prop is also better than apc:s. Avoid chicken stick on all these props, a starter is much safer.
Flyer95 is offline
Old 05-17-2007, 04:24 PM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
R-C-Guy used that engine on a mustang with gear a few months ago and got a verified 180+ mph. Using a pitot tube and gps he convinced most of us it did happen. The thread is about 15 pages back if you want more info on what he did.
http://www.rcuniverse.com/forum/m_4898601/tm.htm
It would seem to me that 300 is in reach, especially if you could clean up the nose a little.
Mike Connor is offline
Old 05-17-2007, 08:22 PM
Lomcevak Duck
My Feedback: (14)
Lomcevak Duck's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would believe 300km/h is possible with this setup, but you'll likely need to cowl the engine.
Lomcevak Duck is offline
Old 05-18-2007, 12:49 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice plane!
Funny muffler tho, is that better than a full pipe?
V.
vasek is offline
Old 05-18-2007, 01:04 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's a "mini-pipe".... kinda like the pipes we use in Q500...
Rudeboy is offline
Old 05-18-2007, 07:05 AM
max plank
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes mini pipe from weston uk .. works wonderfull 20000+ rpm on a 10x7 apc at with out to mutch noise.. where can i get these carbon props please help ... and it is going to get a nosejob i just want to fly it first...[>:]
Old 05-18-2007, 10:02 AM
HaveBlue
HaveBlue's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
most of the speed freaks in Germany make their own carbon fiber props, it would be very hard to find commercially available CF props in the diameter and pitch that is used in the speed trials ..most use something in the vicinity of a 9 x 10
a brief overview of the process is to make a mold from an apc then use continous fiber strand and epoxy, cured under vacuum ( a very simplied explanation, but not overly technical either)
although that will be a fast ship as it is..like the others have mentioned that really needs to be fully cowled for serious speed, that engine is sitting high and would have considerable drag
HaveBlue is offline
Old 05-18-2007, 10:34 AM
max plank
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what is the problem with the apc prop they rate it at 19000 rpm fore a 10 inch so 25000 is just a small increese
Old 05-18-2007, 11:16 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There are few props here that should fit the bill:
http://www.supercoolprops.com/price_list2.php
daven is offline
Old 05-20-2007, 03:59 AM
max plank
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have not been able to find a sutiable prop anywhere so is it possible to take a larger prop and cut it down i diametre to get a stronger prop or is it a waste of time .... what are you other guys running on your engines??
Old 05-20-2007, 04:05 AM
Ed Smith
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When you have a prop blade sticking out of your ear you will fully understand the problem!
Ed S
Ed Smith is offline
Old 05-20-2007, 08:12 AM
max plank
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i do understand the problem ... i just dont understand that it is inpossible to get a prop that works!!
(what is the problem with the apc prop they rate it at 19000 rpm fore a 10 inch so 25000 is just a small increese) joke!!!!!
Old 05-20-2007, 09:45 AM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, it's not really a joking matter... if you always fly alone, and thus only risk hurting yourself and are prepared to take that risk, then go for it. Just remember that when one of them blades decides to part, it will do so at several hundred miles per hour...
These extreme setups are not a real big commercial succes, so no prop manufacturer is going to start making props that he can only sell a few of. There's your problem. That being said, Stuart at Supercool will make you basically anything you want... as long a you pay him
You could try contacting the German guys (there's plenty of extreme speed reading on the german forums), but I don't think their props are really suited for your plane. These guys are flying hugely "oversquare" props on very slick planes.
If you are willing to put in the time, it is perfectly possible to cut a very good wood prop by hand... but be prepared for a lot of trial and error!
Modifying a bigger prop is also an option, but you should source a carbon base prop just the same. The trial and error thing also applies here.
Rudeboy is offline
Old 05-20-2007, 11:15 PM
rcflyer1970
My Feedback: (212)
rcflyer1970's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some info here. http://www.clspeed.com/parts.htm
rcflyer1970 is offline
