Prop size
Prop size
Hello all,
I have a OS MAX FX .46, and I just got the Macs tuned pipe outfit for it. I understand this is not really a purpose built speed engine, but should still be able to produce a descent turn of speed. My question is, what size of prop would anyone recommend? I have some 9x12's (too big I expect) and some 7x9.5's (too small?). I have a feeling I may need to get something in between.
Chris
Chris
My Feedback: (50)
RE: Prop size
The 9x7 is a great place to start...Depending how slick your airframe is would make a difference here- 9x8 might be good and there are a lot of pylon porps to choose from in between.
Let us know the airplane and maybe we can offer some better info.
RE: Prop size
Thanks guys
I am building an airframe around the engine. It is similar to the F3S Speedcup airframes in appearance - the engine and pipe will be cowled so it will be very sleek.
Chris
Chris
RE: Prop size
I ran the same engine with a UltraThrust tuned muffler and a 9 x 7 worked great. An 8.5 x 9 would have the same load and may be faster on your plane if it is slippery enough.
