CERMARK F-18 HORNET, BUILT IT BETTER, STRONGER, AND FASTER!
Reply
Old 06-06-2008, 07:12 AM
  #251
Sniper.308
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: CERMARK F-18 HORNET, BUILT IT BETTER, STRONGER, AND FASTER!
I am going to be selling my F-16 and my F-18 do to I am going all Electric. Pics upon request.
My F-16 $350 + shipping to lower 48 states only.
Would make great for a beater.
w/servos O.S. 91 FX about a gallon, No receiver or battery.
small cracks on belly off of the landing gear holes about 1 inch each, crack in top spine and needs new front retract. Not from a crash or anything just bad landing. All glassing is really easy fix, just have no time to do it.
F-18 $750 +shipping to lower 48 states only.
w/servos no receiver or battery. Sport Jett 90 less than a gallon.
no major damage that I am aware of other than front wire LG has been replaced. OEM one snap on an easy fast landing.
I will take best offers on both planes combined. Will seperate planes, not parts, yet. May part out if I can't sell them. Keep in mind shipping will not be cheap so local pickup is preferred. Shipping to lower 48 states Con US. ONLY!!!!
Sniper.308 is offline
Old 06-19-2008, 09:09 AM
  #252
Blade47
Blade47's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone tried a OS 55AX with a Jett muffler? I have one in a AKM F-16 weight at 7.8 pounds and it gets up and goes ...it sure would be a lot lighter and a lot less cost.
cheers
Blade47 is offline
Old 06-19-2008, 09:44 AM
  #253
bob27s
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mmmmmmm.........
the Hornet is a bit big and heavy. And no way to get it much lighter.
Flys great, good wing loading..... but it needs to HP up front.
That 55 approach on the Juno F-18 might be worth an experiment though....
bob27s is offline
Old 06-19-2008, 09:53 AM
  #254
Blade47
Blade47's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mmmmm you may be right .... may be a winter project coming up gees almost the longest day and I am already think about sliding back to winter.....crap.....
Blade47 is offline
Old 08-02-2008, 05:22 PM
  #255
Sniper.308
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Has anyone tried to make their jet electric yet? If I can't sell mine I need to know how to get an inrunner or outrunner in the nose and at what KV?
Jason
Old 08-04-2008, 03:50 PM
  #256
stevenchao
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alex, member of Cermark, had flown with Power 60 with 10s battery (around +6000mah and 3800mah). Power plant is okay with either NEO-60 or Power 60. However the battery kills. At 10s, it is a pretty expensive pack. The 7000-7600mah is a bit heavy for the airplane - increase wingload. The 3800 and 4000 is much better for wingload, but short flying time (3+ to 4.3 min). We flew with the same glow setup (no weight reduction) and without spinner.
Peace,
Steven Chao,
Cermark
stevenchao is offline
Old 08-04-2008, 11:39 PM
  #257
Sniper.308
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Battery is not a problem I'm going A123 anyway. I just need to see how he mounted the motor, wing loading I can deal with.
Jason
Old 08-29-2008, 10:04 PM
  #258
jetpilotrich
jetpilotrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys,
Been gone a while since I started the thread... I always seem to finish these planes a year or so after I plan to. Anyway, thanks to "XPHSTOS" and the truly graphic "in-flight breakup" pics he provided. This plane does seem to have a structural flaw in the underside due to the holes that are cut in the underside for the main gear. The pics show where the underside skin buckled and caused the whole fuselage to bend and ultimately fail. I slightly Tested/flexed my fuselage during the assembly process to see what would happen..... and the skin did begin to buckle right between the main wheel well holes.
This weak area between the main wheel wells does seem to be a major flaw and probably should be corrected at the manufacturer with something to make the bottom of the plane more rigid!
Here is the fix I used to hopefully prevent such a failure....
I added 2 carbon fiber rods (to keep it light) between the forward main gear bulkhead and the aft nosegear bulkhead. They are braced in tightly and glued down with a mixture of epoxy and millfiber. I used some small strips of balsa to act as a dam to create a triangular "tub" to fill with epoxy and secure the Rods to both the bulkheads and floor of the plane at the same time. I ran the epoxy the full length of the rods and secured them to the inside/bottom of the fuselage. The lower skin of the fuselage is super rigid now!
The rods are intentionally A-symetrical to allow for the offset nose wheel well.
Here are a few pics of the fix!
Also, I added some pics of the servo arrangement thus far and the retract table I made to cut down on weight and improve the planes balance! As usual, all servos are in the tail except for the Aileron servos.... this should allow for a not so massive battery and lighter weight!
Note the hardwood doubler for the nosegear blocks and the throttle/NWS (NOSE WHEEL STEERING) tubes.
Anyway... plan to finish and fly the plane in a few weeks.... more pics of improvements to come!
ID:	1021985   Click image for larger version
ID:	1021986   Click image for larger version
ID:	1021987   Click image for larger version
ID:	1021988   Click image for larger version
ID:	1021990   Click image for larger version
ID:	1021991   Click image for larger version
ID:	1021992   Click image for larger version
ID:	1021993   Click image for larger version
ID:	1021995   Click image for larger version
jetpilotrich is offline
Old 08-30-2008, 02:25 PM
  #259
jetpilotrich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are pics of the weak area from the outside. The underside of the plane between the main wheel wells is thin and weak! It needs to be stiffened up! I should have taken the pics before I added the carbon rods .... it was pretty thin!
ID:	1022324   Click image for larger version
Old 09-03-2008, 02:25 AM
  #260
SpeedBoy
SpeedBoy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The new and the old age , both with the same power plant OS 91 FX and 12x10 .
ID:	1025186   Click image for larger version
SpeedBoy is offline
Old 09-03-2008, 08:52 AM
  #261
bob27s
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does that F-4E have inlet condoms on it or something ? [&:]
bob27s is offline
Old 09-03-2008, 09:14 AM
  #262
mk1spitfire
mk1spitfire's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
, Ha I saw that too. didn't think it was a phantom at first!!!!!!!
mk1spitfire is offline
Old 09-03-2008, 09:52 AM
  #263
envallm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SpeedBoy,
Who makes the F4 Phantom you have pictured here with the F/A 18?
envallm is offline
Old 09-03-2008, 01:11 PM
  #264
SpeedBoy
SpeedBoy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: bob27s
Hehe yes just a pieces of plastic ..... you know to reduce some drag , once in the air they're invisibles and the difference between with and without is very notable = more speed .
SpeedBoy is offline
Old 09-03-2008, 01:16 PM
  #265
SpeedBoy
SpeedBoy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: morganew
SpeedBoy,
It was Great Planes but some years ago , unfortunately now is discontinued [>:] .
SpeedBoy is offline
Old 09-03-2008, 01:19 PM
  #266
envallm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Speedboy,
I know its a bit off topic, but can anyone out there recommend a good F4 Phantom prop ARF? Pickings are slim as far as I can tell. I figured this is the crowd to ask. I cant find the Cermark F/A 18 in stock ANYWHERE.
Thanks guys.
envallm is offline
Old 09-03-2008, 02:22 PM
  #267
bob27s
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cermark should have planes in stock again shortly. And with any luck their F-15 will show up this winter too.
Vmar (richmond) and NitroPlanes both have an F-4 Phantom available as an ARF....
But based on feedback, Id be hard pressed to really recommend either as a "good phantom prop arf".
The Royal F-4E and the GP F-4 both fly very well. Often enough kits for both show up for sale now and then.
There was an excellent Phantom build thread about a year ago (scratch) ... MustangFever ? Cant seem to find the thread...
bob27s is offline
Old 09-03-2008, 04:34 PM
  #268
envallm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob,
Inquired with the sales rep at Cermark about Hornet availability...the response..."Its going to be about 3-6 months before we get them back in stock.." Its a sad day for me. Guess I will just outfit my Sundowner 50 with a Jett 60 to get my speed fix until then. Hmm...wonder if a Jett 90LX would fit in my sundowner....
envallm is offline
Old 09-05-2008, 10:00 AM
  #269
bob27s
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: morganew
Bob,
I do not recommend the 90LX in the sundowner. Just not a very clean installation when you are done, and its heavy. And from reports of a couple of people who have tried it.... Dub's 60LX powered sundowner is still faster.
bob27s is offline
Old 09-18-2008, 08:53 AM
  #270
bob27s
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone else get their summer project F-18 in the air yet?
Bob
bob27s is offline
Old 09-19-2008, 10:49 AM
  #271
xphstos
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well...im back my second cermark f18 is flying well with 50 flights ........will post pics soon
the plane was clocked at 151 mph.. sooooo every time i take offfffffff i give it its last rightssssssssss lol
xphstos is offline
Old 10-13-2008, 11:50 PM
  #272
jetpilotrich
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am getting ready to fly mine... what kind of Stab throws are you using? Also.... does the 7" CG in the instruction manual work ok?
Rich
Old 10-14-2008, 10:27 AM
  #273
nazzop
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the raptor behind the f-18 and the f-4, it got plastic covering the "jet intakes"?
can you put a pic showing it, please?
thanks
nazzop is offline
Old 10-14-2008, 01:19 PM
  #274
SpeedBoy
SpeedBoy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: nazzop
thanks
Yep , no problem .
These things really help to reduce some drag .
The airplane is of a friend of mine.
ID:	1051797   Click image for larger version
SpeedBoy is offline
Old 12-26-2008, 02:15 AM
  #275
P 51 MAN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thinking about getting the Cermark F-18. I have an OS 91 on the bench that wants to play.
P 51 MAN is offline
Reply
Display Modes
