jett 40 qm engine
Reply
Old 07-20-2007, 12:29 PM
izzy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default jett 40 qm engine
can anyone shed light on this before i go fly tommorow
can the qm40 jett engine take a apc 8.8 prop x 7.0 ( the ines used on q500 planes
reason is i am deciding tonight wether to put a rossi40 with tuned pipe or the qm40 engine on a lanier predator 2 ARF
open for all suggestions
thanks
izzy
izzy is offline
Old 07-20-2007, 12:37 PM
Ed Smith
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: jett 40 qm engine
In the interests of safety do not use that prop on that engine. The Jett Q40 engine is meant for use in Q40 Pylon Racing. AMA rules set 422. In that rules set there is a specific set of rules for the allowable propellor. Basically the only prop allowed is the APC Carbon Prop. Read the rule for full details. The reason is that the grey props may not stand up to the power of any Q40 engine.
Ed S
Ed Smith is offline
Old 07-20-2007, 12:54 PM
izzy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
will the qm40 prop pull the q500 decently ,that is my actual question, will i get good top end speed ?
izzy is offline
Old 07-20-2007, 01:52 PM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I do not have actual experience with what you are doing but I do not think the Q-500 airframe is clean enough for the small CF props. I also doubt the engine would pull the load of the larger props to the engines designed rpm range.
But I think you should do it so we all would know.
Mike Connor is offline
Old 07-20-2007, 02:20 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I personally wouldn't run a gray APC prop over 21,000, I am not sure what RPM you would get with the 8.8" x 7 prop, but I would think it would be a bit more than 21,000.
These props were just not designed for that type of RPM, and I would definately not suggest trying one.
I would suggest trying a 8x6 Zinger wood prop, or take a 9x6 Zinger and sand about an 1/8" off the TE of the prop (narrow the blade). Then coat with thin CA, light sand and polish, and then balance.
daven is offline
Old 07-20-2007, 03:26 PM
rmenke
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Daven
I see Dave is not overly bussy at todays practice (assume he is in Min.) to keep up with the gang. Good timming here. Now obviously I'm not going t make it to this weekends race, don't even have a Q-500 in flying condition or decent Q-500 engine in the cabinet. Lets thnik a little about Tuson 08, and your second place thought process public embraceemt. Am thinking seriously of putting something togeather just to harass the gang a little in the inturm and respond to your sly challange. O wish you to to take a few things into consideration regarding giving a REASONABLE HANDICAP giving the following as a basis. 1. Have not flown a triangle cource in almost 40 years. 6'-4" against poor little shriveled 5'-8". Theory based on havilng 8" of flight advantage on each 3 directions. Something like 8X3=24 X laps add 24" time handicap. (I do the math) Aged senior of 73 against youthfull 40's. Home made thingy complying with the rules against a full out composit airframe. Any used older Jett or Nelson engine I am able to buy at auction, cheep, against new LS Nelson. Rapidly diminishing eyesight from developing cataracts from eye exam 7-16-07. As we begin negociations, I estimate that a reasonable handicap of 10 seconds at the finish line would be sporting on your part. You will also avoid the reputation of beating up on a poor old defenceless man who probably wont even be able to get it up (the airplane). Lozer buys dinner. Think about it after the weekend. If you won, overall, I give now, maby.
rmenke is offline
Old 07-20-2007, 06:49 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
IIRC, APC says their competition series [$3.95] gray props are safe up to 190,000 divided by the diameter. This means that a 8 inch prop is OK up to 23,750 rpm.
combatpigg is offline
Old 07-21-2007, 02:13 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
see this thread post #939
http://www.rcuniverse.com/forum/m_30...47/key_/tm.htm
ID:	727329   Click image for larger version
vasek is offline
Old 07-21-2007, 07:31 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Combattpigg,
That is correct, but you are not factoring in the unload off the pipe in the air.
21000 (slightly rich) on the ground will unload approximately 2,000 more in the air getting you very close to the max rpm of that prop.
Stick with Wood, it is safer.
daven is offline
Old 07-21-2007, 08:57 AM
izzy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
question is if the 8.8x7 or 8.8x8 will even reach these rpms on this engine considering it is much more load than 7.xx7.8 prop used in qm40 on the Short stroke engines
izzy is offline
Old 07-21-2007, 11:06 AM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The safest bet of all is to work around real speed set ups like the control line speed guys do...by working from behind the engine 100% of the time, uncluding pressing the spinner into the starter cone to get the engine started.
Old 07-23-2007, 01:04 AM
rmenke
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
vasek:
Just trying to understand what I am seeing in your pic.. I see a jett red carb with a jett remote needle and a engine I don't recognize. What?
rmenke is offline
Old 07-23-2007, 10:08 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: izzy
Short answer - no
The big prop will not permit the engine to unload in flight, and it will not needle properly on the ground.
The QM40 engine has to turn up over 22K rpm to run properly. It should best launch around 22.5K rpm (and that is about 800 rpm down from ground peak rpm)
And, as Ed noted, the only commercial props suitable for the engine are the APC carbom QM40 props, or a carefully prepared wood prop.
bob27s is offline
