Prop for 46 ax for some speed
Reply
Old 07-24-2007, 04:19 PM
manyu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Prop for 46 ax for some speed
Hi guys..
I have an ultra sports 40 plus with a 46 Ax currently swinging a 11x6. I wanted to extract the most speed out of the combo and have two props available 10x7 and 9x7 at lhs.
Wanted to know which one will be better. i have an iclination towards the 9x7 but doubt if it will takeoff ? dont know will it?
And also should i remove the baffle to gain some rpms?
manyu baweja
manyu is offline
Old 07-24-2007, 04:33 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Prop for 46 ax for some speed
Remove the baffle.
Try both the 10x7 and the 9x7. The 9x7 should be slightly faster, but you may enjoy the flying characterics of the 10x7.
My suggestions are based on using APC props.
daven is offline
Old 07-24-2007, 06:51 PM
Cyclic Hardover
Cyclic Hardover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: daven
Remove the baffle.
What he said My only little blurb to this is is to fly that prop 10/7 for 10-15 flights. Then when you go to change to another prop, you will see the difference instantly (better or worse). Changing props every couple flights may keep you confused.
Cyclic Hardover is offline
Old 07-25-2007, 08:25 AM
manyu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I thing i forgot to mentiion that my 46 ax is got quite old and and i get 500 rpms lower now..
i hope the 10x7 wont overprop the 46 ax.
also wanted to know the rpms on the both of them.
Manyu
manyu is offline
Old 07-25-2007, 08:37 AM
reincarnate
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try one of these mufflers for an instant boost. On my 46AX I got about 800 RPM more and about 500 on the 55AX.
http://www2.towerhobbies.com/cgi-bin...?&I=LXJB16&P=Z
reincarnate is offline
Old 07-25-2007, 08:41 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its pretty tough to overprop the AX.
An APC 10x7 should peak at or slightly over 14,000 rpm, not sure on the 9x7.
daven is offline
Old 07-25-2007, 02:13 PM
rmenke
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Manyu:
Listen to Daven, he's both, knowledgable, sneaky and tretcherous, a hard combination to beat. ENJOY
rmenke is offline
Old 07-25-2007, 09:10 PM
krs
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My personal favorite for the OS .46SF is an 8.50-7.50 or an 8.75-7.75 APC Pylon prop. I use this on a Miss Martha and can get a top speed of about 120+.
krs is offline
Old 07-25-2007, 10:16 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the newer AX O.S. motor is different from the revving motors in the past.
Use a prop that peaks somewhere between 14-14.5 RPM and you will be in its sweet spot.
daven is offline
Old 07-26-2007, 04:03 AM
Dauntae
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did you put retracts on yours, I had one when they first came out and it flew great at any speed BUT with the retracts air got into the wing on a high speed dive and actually blew out the covering top and bottom in the bays behind the retract. It wis like I had a M-80 in the wing but luckily it was still flying and I landed safely. I ended up losing it a few months later to a knife edge gone bad, (darn it..... the other up!!!!)
Dauntae
Dauntae is offline
Old 07-26-2007, 02:11 PM
manyu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks alot guys... i will go ahead with the 10x7
I dont have the retracts on nor the cowl....
the cheap aweful abs cowl from gp has developed cracks from all corners...
how many m/h will i get more by putting the cowl ?
Manyu Baweja
manyu is offline
Old 07-26-2007, 02:47 PM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: manyu
Manyu Baweja
An un-cowled engine can be responsible for as much 1/3 the entire drag of your plane. A properly designed engine cowl can increase your airspeed up to 12%.
Mike Connor is offline
Old 07-26-2007, 03:22 PM
manyu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
May be then i will make one.... of balsa soon
manyu is offline
Old 07-27-2007, 02:58 PM
manyu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got my hands on an MK 9.5x7 prop ... cant wait to get to the flying field.....
Manyu Baweja
manyu is offline
Old 07-27-2007, 04:46 PM
CrashPro
CrashPro's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Heres my Ultra Sport...I've always ran a 11x5 on it with an O.S. .46 FX I've never played around with props trying to get speed out of this plane. I have so dam much Monokote on it it flies like a brick.
CrashPro is offline
Old 07-27-2007, 06:08 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Crashpro- That is beautiful!
WOW
Razor-RCU is offline
Old 07-27-2007, 06:20 PM
CrashPro
CrashPro's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Razor.....I wish it flew as good as it looks. It was my first kit build and I really over did it with CA and epoxy and covering and everything else that made it a whole lot heavier than it should be. I only fly that one 2 or 3 times a year.
CrashPro is offline
Old 07-27-2007, 08:11 PM
rmenke
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MANYU; Quit pudtting around. Install robart spring air retracts. Pull off the 10 X 6 and install Jett 60 LX, take one bay out of each side of the wing, go 130 +. Blowing out the rear of a wing from retract hole is same as hole in builders head. This is why you must install a dam around the wheel well. 1/16 balsa or ply will curve around just fine and stay foreaver, epoxie fuel proof. EnJOY
rmenke is offline
Old 07-28-2007, 12:08 AM
Dauntae
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Blowing out the rear of a wing from retract hole is same as hole in builders head. This is why you must install a dam around the wheel well. 1/16 balsa or ply will curve around just fine and stay foreaver, epoxie fuel proof. EnJOY
Nice comment ding$&%@ Sorry if a early build does not have everything covered...OH that's right I'm shure your first build was perfect...Damn
Dauntae is offline
Old 07-28-2007, 07:39 AM
manyu
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rmenke
Then y dont you sponser me the robart spring air retracts and the Jett 60 LX.... I posted to gain the max speed of my current engine... k
Manyu
manyu is offline
