size of this prop ok to use
Reply
Old 08-02-2007, 09:52 AM
suzonka
My Feedback: (7)
suzonka's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default size of this prop ok to use
on my os 91 BB engine, the nearest prop I have is an 11x7.5 with a wide blades ,the recomend a 12x6, but being that the prop has such wide blades and is almost x8 in pitch will this be OK on this engine until I get a 12x6
suzonka is offline
Old 08-02-2007, 10:17 AM
Mike Connor
Mike Connor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: size of this prop ok to use
according to ThrustHP the 12x6 has about 10% more load then the 11x7.5 before considering the wide blade. I doubt it would hurt anything. People experiment with all types of props without problems if you stay in the recommended manufactures rpm range.
Mike Connor is offline
Old 08-02-2007, 01:01 PM
suzonka
My Feedback: (7)
suzonka's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Mike Connor
Thanks mike
suzonka is offline
Old 08-02-2007, 02:42 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its a little light for a .91 and will probably turn up some pretty good R's, but I wouldn't hesitate to run it. Just keep it a little rich and it should be fine.
daven is offline
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is a two stroke, right?
daven is offline
Old 08-02-2007, 06:22 PM
suzonka
My Feedback: (7)
suzonka's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: daven
yes bb fx os 61
suzonka is offline
Old 08-03-2007, 01:37 AM
i live for 3D
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
also what do you guys think about an 11x8 on a 91size engine?
i live for 3D is offline
Old 08-03-2007, 07:05 AM
suzonka
My Feedback: (7)
suzonka's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: i live for 3D
looks like Mike conner knows the right answer, by the RPM's Thats the bottom line, it it sounds like its winding out and screeming in the air its not enough prop
suzonka is offline
Old 08-03-2007, 10:06 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
prop size depends a bit on the aircraft it will be used on, as well as the engine....
What airplane ?
Stock muffler or something other ?
Typically a stock OS 91 likes to run around 12,000 rpm....
So in general, if you select a prop that hits that peak ground rpm, you are in the right ball park.
An 11x8 is ok, a 12x6 will run about the same.
No, you will not hurt the engine with the smaller prop. It is not going to turn up 'that' high in rpm.
Bob
bob27s is offline
