FiberGlass'n and Painting a Patriot
Reply
Old 03-14-2003, 01:13 PM
Rubbie
Rubbie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default FiberGlass'n and Painting a Patriot
I have a half built Patirot on the workbench and I am considering Glassing it and painting it. I know it will probably come out heavier than mono-cote. I am sure someone has done this? Any suggestions? Should I even bother? I don't mind it being a little heavier as I am going to try and get use to higher wing loading airplanes to move to DF. Plus I have learned that I am better with the air brush than with the covering iron, anyway that is the method behind my madness. let me know what you think.
Rubbie is offline
Old 03-14-2003, 05:22 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hmm
I heard something about this awhile back- try a search...
If you use .75 oz. glass and you go real thin with the Z-Poxy (or whatever you use..) it should not be too bad-
What engine are you gonna use?
james
Razor-RCU is offline
Old 03-16-2003, 04:09 PM
Rubbie
Rubbie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Engine
Razor....
Thanks for the help I'll do a search for it. I was planning for a MVVS .49 to start then move to and Enya .80 or MVVS .77 or just start with the .77 (with an 11x10) i'll probably have to add weight to the tail. With the exchange rate the way it is I can't justfy a Jett engine.
Rubbie is offline
Old 03-20-2003, 01:51 AM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Wow-
The MVVS 77 is pretty big for the Patriot- might take some work stuffing it on there...
Are you sure the bigger displacement is the way to go? It seems like a YS-45 w/tuned pipe would be more RPM's vs weight- also a Rossi 45 or 53 would turn some RRR's
Best of luck and keep us posted!
