Now This is Fasttttttttt
Reply
Old 09-02-2007, 09:26 AM
Flyjets
My Feedback: (51)
Flyjets's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Now This is Fasttttttttt
Hi Guy's
I thought some of U might get a kick out of this little beauty.
My Buddy has been trying to get me to Fly one of these things for several years now.
After seeing several friends enjoying themselves I decided to Join In.
The Plane is the Original Sunracer Powered by an HET 2w 20 motor. Flight Power 2170 3s1p 25C Pack. Castle Creation 80amp controller.
The Prop is an APC 5 * 5 and she turns around 35,000 RPM. If my stuff reads correctly that high.
Amperage is 65 Static.
Here is the Fun Part Straight and level the Airframe is limited to 165 and then the Flutter starts at the Ailerons tips.
The cure is to Tape the tips closed so the Ailerons only Warp. No more Flutter with Speeds now of 189mph if U can believe the Doppler Radar.
If you Guy's like Fast then this will get U going. The SMALL foot print with the High Speed only allows 2 to 3 second burst of MAX power.
One other Fun fact if U Fly down the Center of the Runway and go to Idle Power and pull vertical she can still climb to approx 1500 feet at IDLE.
While I don't get that Rushed feeling from Flying it I do enjoy it.
Ian
ID:	755089   Click image for larger version
ID:	755090   Click image for larger version
Flyjets is offline
Old 09-02-2007, 09:51 AM
Flying freak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Now This is Fasttttttttt
Im not into the electric thign but that sounds luike a great setup iv been wanting to ge a little electirc throw around my only fear is this: when its all said n done how much does one ahve invested in the entire plane (ie after you but airfram all electronics rx battery basically everything but the tx)
Flying freak is offline
Old 09-02-2007, 10:33 AM
Flyjets
My Feedback: (51)
Flyjets's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When I was racing all kinds of Vehicles from Boats to Bikes to Planes there was always one overriding Question.
How Fast can U afford to go because Speed CosT.
Here is a breakdown.
This new Airframe I am told is just a trace slower and slightly stronger.
USD
Airframe $259
Motor KV is wrong on site HET2w 20 $70
Speed Controller Castle Creations 80amp $136
FltPower 2170 3s1P $77
Servos Futaba S3153 *2 $67
MPI Spinner 30mm * 3.2 $ 14.00
Total is $623 less Receiver
That's parts breakdown is below.
Ian
http://www.espritmodel.com/index.asp...OD&ProdID=5291
http://www.ejf.com/index.php?main_pa...roducts_id=232
http://www2.towerhobbies.com/cgi-bin...&I=LXRVZ3&P=ML
http://www2.towerhobbies.com/cgi-bin...?&I=LXGVS4&P=M
http://www2.towerhobbies.com/cgi-bin...?&I=LXNCV9&P=7
http://www.espritmodel.com/index.asp...OD&ProdID=2466
Flyjets is offline
Old 09-02-2007, 10:35 AM
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a Sunracer and absolutely loved it. It is all busted up now from some sort of RF interferance. I plan on getting another one going again someday. I took one out to a fun race at our club one day and lapped the field 5 times in 10 laps! Not only does this thing go fast , it loses hardly any speed in a turn.
vertical grimmace is offline
Old 09-02-2007, 11:01 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got one of those nearly ready to go. Mega 16-15-3 + 3S 2100 LiPo. Apparently good for 160. The claims of 160 mph are realistic, these things go like snot.
MJD
MJD is offline
Old 09-02-2007, 11:19 AM
Flyjets
My Feedback: (51)
Flyjets's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MJD
From what I have seen the Airframe Max speed unmodified is 165mph.
Flutter is very likely beyond that speed unless u Tape the Tips.
The 16 15 3 Mega might be good for 150s not sure U need large RPM to really get thing to crank to the upper speeds.
Either way your going to really like the way it Flys in the 150mph range it's very much a point and shoot Flying platform.
Ian
Flyjets is offline
Old 09-02-2007, 10:06 PM
vertical grimmace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As you can see the new version accomodates 2 aileron servos. The biggest problem for me was getting it slow down enough to land properly. If you fly over grass it is no problem but I would try to set it in the dirt areas to the side of our runway and it was a little tricky.
Having 2 servos will allow you to mix in something to get the plane dirtier and allow you to slow it down some. I always wished I had 2 servos on the wing.
Old 09-02-2007, 10:49 PM
Flyjets
My Feedback: (51)
Flyjets's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
vertical grimmace
There is no doubt that the SunRacer will eat a serious amount of Airspace and Landing in the beginning can be a bit tricky.
I have only flown mine 3 times and my two other buddies twice.
Seems it more Jet like that U have to basically Fly it into the ground at idle of course.
The ability to use Spoilers on the new version will let U land her in tighter Flying Fields.
Let me know how she Fly's I am curious about the different Wing configeration.
Ian
Flyjets is offline
Old 09-03-2007, 11:24 AM
rmenke
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
flyjets:
Love it even though I may not be able to see it well enough to control the thing at 150 mph plus. Now, need to figure out how to get that baby scooting around the pylons at the 180's for 10 laps. Would really enjoy doing/seeing some of the smug faces drop a little at the electrics outrunning their go fasters that are not really that fast. ENJOY
rmenke is offline
Old 09-04-2007, 07:50 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Flyjets
MJD
Ian
Yup, I found out about taping the tips beforehand so I planned to do that. Sounded odd to me at first but makes sense now. Looking forward to flying something as fast as my Magnum but twice as hard to see! Nothing like a challenge eh?
MJD
MJD is offline
Old 09-05-2007, 12:28 PM
SSGSPEEDMAN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In F3D your starting price to fly a new one is 2k.
Kevin
SSGSPEEDMAN is offline
Old 09-05-2007, 04:05 PM
Troy-RCU
Troy-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Sunracers are good bang for buck airframes. Though, you've discovered their limitations with glass wings.
Troy-RCU is offline
Old 09-25-2007, 01:37 AM
TIA
TIA's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Flyjets
Ian
Hi Ian!
What do you mean by this statement? Are you saying that after 2-3 seconds you won't be able to see the plane any longer? I've been flying a Stinger for a while and am unhappy with its lack of retention. I can run 6 - 10 seconds (if in a headwind) and is slows and drops pretty quickly. I've been deliberating getting the Sun Racer airframe and just moving my stuff over. (Mega 16/15/4 3S-2250) Sounds like a good move to me! I also Have a new 16/15/3 to drop in the new ship!
Thanks!
TIA is offline
Old 09-25-2007, 10:41 PM
TheTick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I loved my sunracers. I blew up my first 2 trying to go faster than 160. Even with the wingtips taped, it would flutter at the trailing edge of the wing near the root. Finally settled with a 150mph setup (aveox 27/26/1.5 on 3s2p tp 4200, 4.75x4.75 prop). Very fun setup with tons of runtime. Eventually, I wanted to go faster so I sold it and built a carbon nemesis which has proven to be rock solid at over 200mph, but I do miss my sunracer!
TheTick is offline
Old 09-25-2007, 11:42 PM
TIA
TIA's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How funny Ben that you found this thread! I think you were the one that originated taping the ailerons down.
SO what are you flying these days?
Just the Nemesis???
TIA is offline
Old 09-26-2007, 03:20 AM
Flyjets
My Feedback: (51)
Flyjets's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guy's
Finally had a day that I took just electric machines out to SRQ for Flying.
The Sunracer with the Taped Ailerons tips really did it's thing. She was ballistic no Radar Gun or Doppler sound charts just eye balling it she was very Fast.
Taping the tips closed stops the Flutter but she no longer will handle like I was used to and she Ate UP a serious amount of Sky on me.
I would say it was constantly Flying at visual limits to make those High Speed runs.
Tick do U have a link to ur new Carbon Nemesis????
Ian
Flyjets is offline
Old 09-28-2007, 12:00 AM
TheTick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Ian,
I only have the one nemesis and I think they all came in carbon with kevlar fuses. I haven't flown it in a while though. Nice to see you are having fun with the sunracer. I really do miss mine alot.
TheTick is offline
Old 09-30-2007, 03:07 PM
ElectricFlyboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone have a Sunracer Super V2? I am working with someone building this model and we are puzzled by the aileron linkages. They are bent in such a way to suggest that they lock themsleves in place. The problem we are having is finding a way to assemble them that makes sense. The servos should be laying on their sides with the linkages hooked directly to the bellcranks. If anyone can post a picture of how their aileron linkages are installed I would greatly appreciate it!!
ElectricFlyboy is offline
Old 09-30-2007, 04:04 PM
Airbourne in Japan
Airbourne in Japan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here's a link to the maker of the nemesis in Holland http://home.planet.nl/~zandv055/ENG/index.html i've got a gilette and sunracer, but i haven't built them yet. i'd like to get a demon if they work out well. n.b. prices from him are a lot cheaper than stateside sellers, even with shipping
Airbourne in Japan is offline
