V tail design
WI
V tail design
Why do Q500 planes like the Great Planes Viper use the V tail setup? I have flown the viper on the sim and find its flying characteristics rather annoying. Are there Q500 planes like it with a standard tail?
RE: V tail design
In racing competitors are always looking for the next little trick for speed.
Now the story -
A really long time again there was a local left coast racer named "Iron Oxide". He was a very competitive fellow, pretty good flier and modeler with long sleeves on his shirt. You got to have long sleeves, because that's where you keep the tricks. Anyway, it was his nature that he had to win our one dollar trophies by any means possible. So he did what he did towards that goal. Quite often he outran the next fastest model by a lap or more with his model with a V-tail. Well, there must be something about that tail, and the usual blather about less junctions cause less drag were expounded upon with great care. But the actual truth was the creative grinding on the sleeve, and excessive amounts of nitro he put into the fuel tank were the real reasons of his success.
Now the story -
RE: V tail design
It seems to me that the benefit of one less surface in the breeze would be lost by the opposing forces generated when you moved the stick. A full up pylon turn would also have the drag of left and right rudders at the same time.
RE: V tail design
Combatpig,
We need 3D pictures for this! The picture shows my method. The pushrod has a ball socket on the end. The funny bent horn has a threaded end. On the end of that is a Dubro #189 ball link. The top left of the horn is the part that goes into the elevator, the middle part of the horn is on the hinge line, The last section is vertical to the push rod. The fuselage width at the horn location has to be 5/8"min. It is a tight fit. I make my tails detachable.
Ed S
Ed S
RE: V tail design
ED, yes that is tight! I am amzed that you can get both levers to cooperate in such a confined space. There must be less side to side movement than I visualized. Those levers are nice and long, looks like you will get maximum control resolution and leverage mechanically. Should be able to fly the plane with a $50 radio if you wanted to.
MN
RE: V tail design
Combatpigg, there are some pretty detailed instructions at www.supertrc.com under Hurrikane instructions.
Here are a couple pics that should help, there are plenty more on the site.
RE: V tail design
Dave, that's another real good look at it, thanks. This time we see how it's done with a wood fuselage. I've looked at those ball links on the shelves and never had the courage to try them. Do they tend to stay tighter longer than a clevis type linkage?
RE: V tail design
Ed S
My Feedback: (13)
CA
RE: V tail design
Guys:
What amazes me is how you can get both V sections perfectly alligned with the proper incidence relative to the datum line and wing. I can see how to make jigs to keep the two in line with respects to each other, but the attatchment to the fuse has evaded me foreaver. If I can't see how something can be accurately measured by instrument, I flat won't do it. Have thought of building a jig to hold a steel rod along the datum line, then the fuse could be turned to a point the position of each V could be measured with a inclinomeater. Yes, I am insane about getting incidence lines perfect, and will take things to a extreem to insure things are correct, but the attitude has served me well through the years. Must be a genitic thing with german ancestry? Don't everyone measure with a digital micrometer? ENJOY
My Feedback: (94)
RE: V tail design
ORIGINAL: 1fasthitman
Maybe the sim is wrong. I have a viper and it doesn't fly too much different than any other sport plane.... btw the linkage is an easy direct pushrod from servo to tail surface, no tricky ball sockets required.
MN
RE: V tail design
I use bulk 4/40 rod (threads just on one end) and have bent so many that I can get them nearly perfect on my first or second try it is a piece of cake without any fancy measuring devices. TLAR works for me, then again, my eyesight is pretty good
My Feedback: (13)
CA
RE: V tail design
CP:
Thats a little harsh, but yet, true. But, if your gonna do it, do it right. Guess a cnc machine shop could build you a perfect jig that may work well on a perfect work bench. Do all your V tail quickees fly the same? If you say yes, "pants on fire". If not, what is the most likely variable? Ok, I might as well admit it. I'm just to lazy to build another crutch just for V tails when storeing one is such a pain. Hard to teach old dogs new tricks.
WI
RE: V tail design
I think it's just like anything else.. Once you do it a few times it gets easier.. I can't tell you how I set the V-tail on my quickies before making a mold for them.. I just lined it up and eye-balled it for about an entire evening before I glued it.. Did they all fly the same, no, not exactly but pretty darn close..
RE: V tail design
MJD
